      03-12-2020, 07:37 AM   #1
Dawgz
2022 M4 Comp Xdrive
1057
Drives: 2022 M4 Comp Xdrive
Can you fit a 10.5" wheel on the front of the x5m?
I got new wheels for the x5m, it has a 74.1 center bore and are 10.5 inch for all four.
I got a center bore conversion for the rear to go from the 74.1 wheel bore to the 72.56 hub bore, also incorporates as a 20mm spacer since the stock rear wheels are 11" and these are 10.5.
My issue is with the front, mainly the size. The stock fronts are 10" and my new wheels are 10.5".
Will it rub anywhere? Do I need to use a spacer to put the front wheels out a bit?
      03-13-2020, 07:12 AM   #2
Dawgz
2022 M4 Comp Xdrive
1057
Anyone?
      03-13-2020, 07:34 AM   #3
Spyro235
Drives: '10 X5D, '04 330i ZHP
If you got them, why don't you jack the car up and throw them on? Maybe even just buy one tire, and have that one mounted, so that you can throw it on the car and turn the wheel side to side to check clearance.
I suspenct it'll be fine, though it might take out a fin or two in front of the wheel from the little oil cooler passthrough. That's what happens wiht oversized tires, and the swing arc will probably be nearly the same as an oversized tire.
The major worry is if it's spaced out enough to not hit the inner strut/ balljoint. If it does, you just need a bigger spacer.
Personally, I'd bolt the wheel (with no tire) up and see how it looks. With some common sense you'll be able to look and see for yourself.
Daily/ Tow: 2010 X5 35D - 340k, Deleted w/DUDMD Stage 2, Sutphin Trans tune, Comfort seat retrofit
Fun car: 2008 e90 M3- 6mt, slicktop, AW, cloth
      03-13-2020, 11:49 AM   #4
95wildtt
Need mo $$s
95wildtt's Avatar
Drives: 2020 X4M Competition
Do you know the offset of the new wheels?
If so, you can use a wheel fitment calculator like this:
https://www.1010tires.com/Tools/Wheel-Offset-Calculator
To see how your clearance looks...
2020 TRM-BLACK X4///M Competition
1995 Dodge Stealth TwinTurbo
Past: 2020 Macan, 2020 X3M, 2019 TTS, 2008 X5 4.8 M Sport
      03-13-2020, 11:51 AM   #5
Dawgz
2022 M4 Comp Xdrive
1057
Likely will be to do that
      03-13-2020, 11:52 AM   #6
Dawgz
2022 M4 Comp Xdrive
1057
I believe the offset is 30.
With stock being 35 I entered the specs on that website and it shows only a 1mm difference.
(Stock front width of 10", new wheel width of 10.5")
      03-13-2020, 07:50 PM   #7
95wildtt
Need mo $$s
95wildtt's Avatar
You should be OK then...
      03-16-2020, 11:58 AM   #8
Doctor///M
Doctor///M's Avatar
Drives: 2023 AUDI RS6
2023 Audi RS6 Avant  [0.00]
BMW M2 Competition   [10.00]
2009 BMW 335i  [0.00]
2015 M3  [9.52]
You should be fine. The 22" BBS SV runs 11" in the front and 12" in the rear with similar offsets to stock. No rubbing issues.
2020 F87 M2 Competition /l\ LBB /i\ Executive Package
2013 E70 X5M /l\ Space Grey /i\ Full Silverstone Leather /l\ LED Headlights /i\ Comfort Access /l\ HUD /i\ Ventilated Seats /l\ 22" BBS SV
BMW CCA Member
      03-16-2020, 04:51 PM   #9
Dawgz
2022 M4 Comp Xdrive
1057
Thanks guys
      03-21-2020, 01:57 PM   #10
nistech11
Drives: 10' X5M
Im running 10.5 front and a 12.5 rear. Clears fine and sits dead flush with the fenders lowered on h&r springs
      03-21-2020, 10:02 PM   #11
Dawgz
2022 M4 Comp Xdrive
1057
Sweet! Got pics?
      04-01-2020, 07:17 PM   #12
Y13LD
Drives: E36 M3, E70 X5M, 997.2, Ghibli
I'm on 22x10.5 front and 22x12 rear. No issues on lowered springs as well.
      04-02-2020, 10:40 AM   #13
Dawgz
2022 M4 Comp Xdrive
1057
Awesome thank you
      04-02-2020, 12:35 PM   #14
95wildtt
Need mo $$s
95wildtt's Avatar
+1
      04-02-2020, 12:47 PM   #15
95wildtt
Need mo $$s
95wildtt's Avatar
Originally Posted by dawgz View Post
sweet! Got pics?
      04-02-2020, 10:30 PM   #16
Dawgz
2022 M4 Comp Xdrive
1057
Looks great
