      04-02-2019, 10:02 AM   #1
passthetongs
Drives: E70 X5 Xdrive35i
Too late to change my trans fluid?
I'm sitting around 124k miles on my '11 e70 35i and have yet to change any fluids in my trans, diffs, TC. Should I go ahead and do it? Anything I have to worry about? No issues that I am experiencing(knock on wood) aside from an occasional slightly bumpy shift from 1-2 at low speed.
      04-02-2019, 10:11 AM   #2
pearlpower
Drives: 2013 328i
Nope, I would not flush it, but nothing wrong with dropping the pan, swapping filter, and putting in fresh fluid.
With that mileage I would also pull the valve body and change all of the rubber seals.
If there any shifting concerns, might as well put in a set of solenoids-a weak BMW area.
      04-02-2019, 11:48 AM   #3
Poppyboy
1976 Triumph TR6  [10.00]
1993 Bentley Turbo R  [10.00]
2011 X5  [10.00]
Fear of changing the fluid, even at this mileage, is nonsense. Go ahead and drain, not flush, the fluid. Fluid gets dirty. It should be changed. I’m actually waiting for a transmission pan from FCP Euro. Just know that their pans have a no-time use drain valve (plastic, can’t be torqued) and you’d need to install a specific drain plug.
      04-02-2019, 12:14 PM   #4
pdX5M
pdX5M's Avatar
Drives: E70 X5M
2013 BMW X5 M  [0.00]
Was just looking through the FCP website and didn't see that they had a transmission pan for an E70 X5 M. I'm going to service my transmission soon and was thinking of just buying their Liqui Moly service kit that runs about $240. Out of curiosity what's the reason you're replacing the entire trans oil pan?
- 2013 X5 M - Silverstone Metallic w/ Black Perforated Complete Merino - All OEM Options - 12.5mm/20mm Spacers - Velos Stage 2 - xHP Stage 3 - AA Catless - Megan Racing Supremo - PTP Blanket - K&N Drop In -
      04-02-2019, 01:34 PM   #5
TwinSnailz
TwinSnailz's Avatar
75
Drives: 2011 X5//M
On the M, the filter is not integrated to the pan. Therefore you reuse the awesome M pan that’s got the cooling fins. Just replace the filter and metal gasket.
pdX5M111.50
      04-02-2019, 01:44 PM   #6
pdX5M
pdX5M's Avatar
Drives: E70 X5M
OK that's what I thought but was second guessing myself. Looking forward to getting some fresh fluid in there...and in the diffs and transfer case...and doing a coolant flush. Lots to do.
      04-02-2019, 02:18 PM   #7
pearlpower
Drives: 2013 328i
I exchange emails with them last week, they do not have the filter separate, they sell it with the wrong gasket, so you need to get the rubber gasket separate from them also. Just toss the paper gasket that comes with the filter.
      04-02-2019, 02:24 PM   #8
pdX5M
pdX5M's Avatar
Drives: E70 X5M
Did they say why they include the wrong gasket? That makes no sense at all lol
      04-02-2019, 03:23 PM   #9
X5 MAN
Drives: 2011X5 50iM-Sport;2016X3 35i M
If it ain't broke, don't fix it
      04-02-2019, 03:34 PM   #10
pearlpower
Drives: 2013 328i
Yes, that is the only way they sell it.
This thread might help you.
https://www.xbimmers.com/forums/show...t=transmission
I plan on doing mine next month.
      04-02-2019, 09:34 PM   #11
Poppyboy
2011 X5  [10.00]
For my N55 (35i), it has the 8-speed trans (GA8HP45Z). The filter is integrated into the pan, necessitating it be replaced at the same time as the fluid.
      04-03-2019, 10:39 AM   #12
FastCletus
Drives: BMW X5
2010 BMW X5  [0.00]
I just watched a vid on how to change transmission filter and mechatronic sleeve, etc. and thinking about doing this myself. Only problem is I don't have a level ground to work on. My driveway is pitched and my car wont fit in garage (too many motorcycles and scooters) only solution is to put car halfway in drive way and half on street to maybe make it level. I pull my camper about once a month so I am thinking probably a good idea to change fluid. I am at 100K miles and I don't think PO changed it since around 50 or 60K
If it?s cheap it ain?t good, and if it?s good it ain?t cheap
      04-03-2019, 11:08 AM   #13
Poppyboy
2011 X5  [10.00]
Just grab some wood planks to drive up on to get level. It doesn’t take much since the car is relatively high already.
      04-04-2019, 07:57 PM   #14
jcattletown
Drives: 2013 X5 E70
I have a 2013 X5 35i with the same transmission as yours. When you do transmission oil change, do you need to reset the oil level and adaption? Here is what I read from the manual:
IMPORTANT: To set the correct level, it is mandatory that the service function "Transmission control unit: oil adjustment" is performed using the diagnosis system. Failure to comply with this requirement will result in serious damage to the automatic transmission.
If this has to be done using ISTA+, do you have detailed step by step instructions? Thanks.
      04-04-2019, 08:03 PM   #15
Poppyboy
2011 X5  [10.00]
I believe all of that is simply to ensure that the transmission fluid is at the proper temperature for the final fill. Instead, use an infrared thermometer gun pointed at the transmission pan to ensure the temperature is between 30 and 50°C before the final fill. There’s nothing to reset. I did the job yesterday. Just be mindful that three of the perimeter pan bolts are almost impossible to remove due to them being located an inch above a transmission brace. You’ll need to use some ingenuity to loosen, then tighten them. I shaved down my T40 bit and taped it to a tiny wrench to accomplish the task. Took lots of patience.
      04-04-2019, 09:29 PM   #16
jcattletown
Drives: 2013 X5 E70
Have you measured the amount of oil drained? if you put back the same amount of oil in the transmission, the oil level adjustment may not be needed. Thanks for the heads-up for the three screws. I will take a look and see what I can do with those. I can use ISTA to monitor the oil temperature continuously, and do the final fill when the temperature falls between 40 and 50C.
      04-04-2019, 09:52 PM   #17
Poppyboy
2011 X5  [10.00]
You don’t need to check the level. It is full at initial fill when fluid trickles out as you pump it in. At that point, close the fill plug finger tight. Then, run the car, foot on brake, through the gears, including M1, M2, D and R, 10 seconds each. Then, put it in P and bring the car up to temperature. While running at temperature, open up the fill plug and fill again until fluid trickles out, taking care to not burn yourself too much on the exhaust. At that point, button it up and you’re done. You must do both an initial and secondary fill since the fluid changes under temperature.
      04-05-2019, 11:51 AM   #18
jcattletown
Drives: 2013 X5 E70
Sounds a good way to go. Thanks.
      04-10-2019, 06:18 AM   #19
Makaveli69
Drives: BMW X5
i did mine the other week, changed oil, filter, and mechtronic seals, was pretty easy and took about 7L of oil, i also had to top it up 3 times the first time it wouldnt change out of park due to not enough fluid. To get the 3 back bolts i loosened (dont take them right out) the brace bolts and held it out of the way with a big screw driver.
      04-11-2019, 08:49 AM   #20
jcattletown
Drives: 2013 X5 E70
That's a good idea to loosen the bolts of the cross bar without removing it to gain access to the three hidden bolts. Thanks for sharing.
      04-19-2019, 05:01 PM   #21
Alex Ander
Drives: BMW X5 xDrive3.5i 2013
Hi,
I assume with "brace" you mean what the manual calls the "cross member".
as per the second photo on this link:
https://www.newtis.info/tisv2/a/en/e...l-sump/QCnlmZc
Did you just loosened the bolts marked in the picture?
No danger of dropping the transmission?
I have found this ultra low profile T40 wrench that should be able to get through the space and access the 3 pan bolts, although there is no way to torque correctly those 3 bolts and maybe still not enough space to extract the bolt.
https://www.amazon.com/Neiko-01328A-..._wg=1hiWS&th=1
If you can answer it would be of great help.
      04-19-2019, 09:41 PM   #22
Poppyboy
2011 X5  [10.00]
I didn’t even mess with the transmission brace. I simply ground down my T40 to make it very low profile, then taped it to a tiny crescent wrench to work those three bolts. As it turned out, there’s really no need to check the torque values anyway. 7.5Nm is not much at all.
