06-06-2019, 08:04 PM | #1 |
Rep 3,036
Drives: BMW/MERCEDES/PORSCHE
Common issues on the x5?
Hi
I'm looking at purchasing a used X5 and was wondering if there are any issues/problems to watch out for. Are there any differences between the earlier models? only considering the X5 3.0 or X5D (diesel), not the v8 ones. Thank you
BMW E93 M3 / Mercedes Benz W209 CLK500
BMW E64 650I(sold) / BMW E92 328I(sold) / BMW E46 M3(sold) / BMW E92 335I(sold) Porsche 996 911 C2(sold) / BMW E46 325CI(totaled) |
06-07-2019, 09:41 AM | #3 |
Rep 601
2011-2013 BMW X5 xDrive35i will be the best choice if you want a E70.
Common issue: -Valve Cover Oil Leak -Water Pump Failure -Leaking Oil Filter Housing Gasket -VANOS Solenoid Failure Stay away from the 50i - lot of issue Good luck !
- 2015 F85 BMW X5M = SOLD
- 2012 E70 BMW X5 35i - M Sport = SOLD - 2008 E71 BMW X6 35i - Sport Pack = SOLD - 2007 E70 BMW X5 4.8i - Sport Pack = SOLD - 2007 E70 BMW X5 30si - Sport Pack = SOLD |
06-09-2019, 08:13 AM | #4 |
Rep 9
Keep an eye on the valve cover oil leak as I did encounter that issue along with air suspension leveling and VANOS error. All issues were covered under my warranty which helped. Good luck!
06-10-2019, 09:00 AM | #7 |
Rep 714
I'm partial to the D- so much more motor than the 35i will give you, especially preLCI without the 8 speed.
I can really only speak to the diesel in this chassis, but it's a GREAT motor for the X5. Major common issues are mostly related to the emissions systems, but those now have an extended 10 year 120k mile warranty on them from BMW. So if buying a low mileage one, you could be covered for a bit. I deleted and tuned, since I bought mine with 204k. Delete and tune gives HUGE increase in performance and reliability by removing all the emissions junk. Other than that, the common problem on the M57 diesel motor is the thermostat failing- if you notice a drop in mpg's, the thermostat probably failed open, causing the motor to run cold, and therefor rich. This also ends up potentially harming the glow plug control module, since the glow plugs run when the engine is cooler than it should be, and they aren't meant to run for extended periods of time. The diesel is the way to go to have an a,ply powered, reliable X5. Its not the quickest suv out there, but it sure hauls when you want it to. Also, great MPG- before my delete and tune, I was getting 27 highway, and after it I'm usually getting 29-30mpg, with a high of 31.4 at 70mph. I also tow 6000 lbs fairly often, so it's nice to have the power to hold speed up hills. |
06-10-2019, 09:52 AM | #8 | |
Rep 1,755
06-10-2019, 11:42 AM | #9 | |
Rep 714
When mine failed, my car was struggling to hit 70C. I was towing 3k lbs up hill, in 65 degree ambient temp and my temp was sitting at like 65C, just way too cold. Mine seems to be a fairly severe case of where it stuck open, most claim 70-80C steady temps. If it's holding less than 85 coolant temp, I'd be concerned. |
06-10-2019, 12:04 PM | #10 |
Rep 3,036
currently looking at an 08 and 09, similar millage, same color, similar options, I can't really notice any differences aside from the 09 didn't have a spare, has an electric tailgate. were there any other differences? based on my research the 08s came in s drive only where the 09 came in xdrive only? mpg looks the same so I'm not too concerned about the xdrive, am i missing anything? thanks for all the help so far guys
06-11-2019, 10:51 AM | #11 | |
Rep 1,755
If it is just losing couple of mpg, I will live with that as this is a tedious change and I have to remove EGR cooler ..etc to get access. I prefer to do this job when deleting the emissions. |
06-11-2019, 02:18 PM | #12 | |
Rep 531
Drives: 2007 E70 4.8i, 2008 E90 335i
The engine choices are different in different years, the diesel didn't exist until 2009? in the US and the turbo petrol engine was 2011?. The 3.0i/si without the turbo was a bit under powered for the X5 IMO. It isn't terrible but it has to rev a bit to make its 260hp/232tq. The 4.8i (which I have) doesn't get great gas mileage, I get mid to low 15s in mixed driving and can get into the high 18s on the highway. It has the coolant transfer pipe and valve stem issues that need to be addressed before I would consider it a good choice. The iDrive is also nicer on the newer e70 X5s. -Rich
2007 E70 X5 4.8i with 10" android screen Running 265/60/18 AT34s All Terrains (Mainly for road trips)
2008 E90 335i with 10" android screen, 7" intercooler, inlets, Dinan intake, JB4 BEF, E85 conversion, Mfactory LSD, M3 suspension, EDC shocks with custom controller. |
06-11-2019, 02:55 PM | #13 | |
Rep 491
I have 2011 50i and I am quite happy with it. As usual the seller skips on maintenence when they decided to sell. I changed battery, coils, plugs, MAF sensor, fuel pump, vacuum pump, and flushed brake fluids, coolant and engine oil. It runs like new now. Paid $15k for a 110k miler and put in another $6k and it as good as new |
06-11-2019, 08:23 PM | #14 | |
Rep 714
Long story short, this is my opinion: If you're deleting within a month, maybe even 3... go for it, drive on it. Especially if you don't drive many miles in the first place. But if you drive a TON, or plan on pushing it 6months to a year? Just pay a mechanic the $450 it costs to replace the thermostat and have the peace of mind you're not going to damage anything. |
06-12-2019, 02:40 PM | #15 | |
Rep 1,755
I have been reading & researching this and it doesn't seem to affect anything other than mpg. For glow plugs, engine temperature has to be below 60 C Do you have any link where it says it will kill the glow plugs controller? I am just researching this to get more idea |
06-12-2019, 05:51 PM | #16 | |
Rep 12
Noticing you are also from the States, most places removing the EGR is considered illegal - so are you able to pass the SMOG test after having it deleted? Second, when you guys talk about the EGR thermostat, is it the EGR temperature sensor? I've replaced mine but just want to know if they are really the same thing. Thank you. |
06-13-2019, 09:07 AM | #17 | |
Rep 1,755
Spyro235259.50 |
06-13-2019, 01:36 PM | #18 | |
Rep 714
NJ is just OBD checks, and it's possible to get by that. Not technically legal, so I wont mention how. |
06-14-2019, 05:02 AM | #19 | |
Rep 714
I personally was not referring to an "EGR Thermostat" I've been referring to the coolant thermostat. It happens to reside behind the EGR cooler on the front of the engine. |
06-16-2019, 07:37 PM | #20 | |
Rep 10
06-17-2019, 07:29 AM | #21 | |
Rep 714
06-18-2019, 08:03 PM | #22 | |
Rep 3
Signed papers on Saturday and still haven't taken delivery yet. They said it was something to do with the DEF System. So today I followed up and they told me the active reservoir was leaking fluid or cracked or something to do with it, and they had to replace it. So... tomorrow they are going to test drive it and make sure that's taken care of the issue. Needless to say I'm ready to drive it home! Can't forget the torque it had when I took off. Think I'm going to really enjoy driving it. |
