06-03-2019, 09:04 AM | #1 |
Rep 47
Can this be fixed?
OK; spent enough time searching.... And this is likely the rear hatch creaking/groaning culprit (latch as in the video). It is not the rear seats (checked).
Can I remove the surrounding hardware and expect to reasonably tighten whatever has come loose or is a purchase of the entire part that comprises this 'U latch' required? Thanks. |
06-03-2019, 06:42 PM | #2 | |
Rep 254
From what I recall... This tightens right up. Actually better than that even... I remember when I was tightening it being concerned with alignment to make sure it would close and latch. I'm positive this is a position-able and tighten-able component. Last edited by greddy91; 06-03-2019 at 07:38 PM.. |
06-04-2019, 02:41 PM | #4 | |
Rep 47
Anyone? |
06-04-2019, 04:40 PM | #5 |
The Quiet One
1711
Rep 624
I’d go through the WSM (workshop manual).
https://www.newtis.info/tisv2/a/en/
2013 M6 Coupe Sakhir Orange Metallic / Sakhir Orange \ Black Merino - The Prince
2013 X5 LCI 35i Jet Black / Black SensaTec - The Horse 2013 X5 LCI 35i Space Grey Metallic / Black Nevada // Sport Pkg - Daughter’s 2013 X6 M Sapphire Black Metallic / Black Merino \ Carbon Fiber - Son’s |
06-09-2019, 08:40 AM | #6 | |
Rep 120
If winning isn't everything, then why keep score?
I feel like every day is the Kobayashi Maru and my name's not James T. Kirk |
06-09-2019, 08:41 AM | #7 | |
Rep 120
06-09-2019, 03:28 PM | #8 |
The Quiet One
1711
Rep 624
The attached link is the only one I have. I keep it bookmarked as my WSM.
06-09-2019, 03:32 PM | #9 |
The Quiet One
1711
Rep 624
Clarification:
Mine is the E70 on the X series. Select which ever one you have.
06-09-2019, 03:32 PM | #10 | |
Rep 120
If anyone has had any success repairing it, please post. Thanks. Here's the link to the part. https://www.ecstuning.com/b-genuine-...h/51247233909/
06-11-2019, 09:46 PM | #11 | |
Rep 78
If so, this is a common and known problem with too much play in the upper portion of the tailgate. The solution is to adjust the bumpers outwards enough to to cause create enough tension as to stop the noise, but not too much noise to prevent the tailgate from closing. Keep searching Google, there are tutorials for fixing this. Good luck! |
