Go Back   XBimmers.com | BMW X6 Forum X5 Forum > BIMMERPOST Universal Forums > Off-Topic Discussions Board > Video + PC Gaming / Computing
      08-09-2007, 10:00 AM   #1
YULY
YULY's Avatar
10
Drives: 2008 328i coupe
2006 325xi  [0.00]
PS3 1080p or 1080i advanced question
I have a sony 60 tv, model # KDSR60XBR1, which is advertised as 1080P, does any body know why my ps3 only wants to transmit at 1080i, if you do please let me know what I am doing wrong. I bought the $50 HDMI cables from sony.
here is a link the my TV specs
http://www.sonystyle.com/webapp/wcs/...uctId=11038061
Thanks!
      08-09-2007, 10:35 AM   #2
tjnptel1
Cunning Linguist
tjnptel1's Avatar
Drives: 335i
2007 335i  [0.00]
something must be up with the TV, as far as i know, Sony's do 1080p only thru HDMI, components are 1080i.
Bottles are for babies, Real men get blown.
      08-09-2007, 10:40 AM   #3
tjnptel1
Cunning Linguist
tjnptel1's Avatar
Drives: 335i
2007 335i  [0.00]
your best bet would be to check avforums.com
      08-09-2007, 11:08 AM   #4
YULY
YULY's Avatar
10
2006 325xi  [0.00]
thanks for the info, someone told me it depends on the native resolution, but the manual claims its 1080p
      08-09-2007, 12:14 PM   #5
gtb75
gtb75's Avatar
9
Drives: 2006 Corvette Z06
I've got a KDSR50XBR1 which uses the same display unit as your set and I've done a bit of research on this issue...
The XBR1 series sets do indeed use a 1080p display unit (it's a 1920x1080 LCoS), but only have 1080i inputs... There's an internal scaler that takes any input signal and scales it to 1080p - the native resolution of the display unit. In the case of 1080i, it takes the 1080i/60fps signal and converts it to 1080p/30fps... There's no loss in quality doing this - only a loss in framerate (which supposedly can't be seen). A number of people on avsforum have said that the scaler in the XBR1 series sets is about the best that's ever been put in a TV, and is better than the scaler used in the "true" 1080p XBR2 sets. Since most things aren't using 1080p (yet), having the better scaler is more important to me than having the 1080p capable inputs.
Sony had talked about releasing an upgrade to allow the inputs to support 1080p, but they ended up scrapping that idea. So you do have a 1080p set, but it only has 1080i inputs. Actually, it has one 1080p input - the FireWire/iLink port on the front, but nothing uses it... That's the only one.
Hope that makes sense...
2006 Corvette Z06
Black / Ebony - 459RWHP / 438RWTQ
2005 Subaru Legacy 2.5 GT Wagon
Brilliant Silver / Tweed M5 - 229AWHP / 260AWTQ
      08-09-2007, 01:19 PM   #6
YULY
YULY's Avatar
10
2006 325xi  [0.00]
gtb75,
smart man.
I just hate the fact that that my playstation 3 tells me that my TV max resolution is 1080i.
      08-09-2007, 01:41 PM   #7
hl0m4n
hl0m4n's Avatar
i have this tv here also by sony. http://www.sonystyle.com/webapp/wcs/...uctId=11040753
i only got 1 hdmi port which is used for my hd cable box. so when i use the factory ps3 hd cables i am not gettint a true 1080p?
      08-09-2007, 01:43 PM   #8
Brunotheboxer
Brunotheboxer's Avatar
Drives: 2014 Shelby GT500.
you will only get 1080p if you hook up a cpu to your tv.
"...I maybe drunk, but you're ugly, and I can sober up..."
      08-09-2007, 02:31 PM   #9
DesiGUY
DesiGUY's Avatar
Drives: Crazy
Thanks!
Can't answer why "ps3 only wants to transmit at 1080i", but return those $50 HDMI cables.
I'd been using a couple of $15-$25 HDMI cables since 8mons and they work just fine.
      08-09-2007, 04:05 PM   #10
BeeEmDubU
BeeEmDubU's Avatar
18
Drives: AW 325i
Syour PS3 to output to 720p (if your TV supports it). I think it would look better than 1080i
      08-09-2007, 04:15 PM   #11
gtb75
gtb75's Avatar
9
These guys have great prices on good cables: http://www.monoprice.com/home/index.asp
Lots of people on avsforum use / recommend them... Great service too!
2006 Corvette Z06
      08-09-2007, 08:13 PM   #12
Brunotheboxer
+1
      08-10-2007, 12:17 PM   #13
YULY
YULY's Avatar
10
2006 325xi  [0.00]
BeeEmDubU
I agree 720p is looks better than 1080i but evryone else says 1080i
who knows??/
      08-10-2007, 02:28 PM   #14
tjnptel1
Cunning Linguist
tjnptel1's Avatar
Drives: 335i
2007 335i  [0.00]
very informative,
It's odd that my non-xbr (SXRD: supposedly lower line then XBR) has HDMI inputs that takes 1080p. My XBOX looks pretty darn good over HDMI and so does Blu Ray.
      08-10-2007, 02:30 PM   #15
tjnptel1
Cunning Linguist
tjnptel1's Avatar
Drives: 335i
2007 335i  [0.00]
also check http://www.firefold.com for cables. they are pretty good priced as well.
      08-10-2007, 02:40 PM   #16
T Bone
T Bone's Avatar
536
Drives: 2008 335xi Coupe
Originally Posted by tjnptel1 View Post
very informative,
Most of the new Sony TV's take native 1080p through HDMI, the OP unfortunately has an earlier model Sony that is a non-XBR
"Aerodynamics are for people who cannot build engines"......Enzo Ferrari
      08-13-2007, 02:50 PM   #17
hl0m4n
hl0m4n's Avatar
hey tbone may i ask why you got 3.91 gears on your m6? n/a m3 are 4.10 and f/i are 3.91. is it vice versa on m5 and m6 models?
      08-13-2007, 05:33 PM   #18
T Bone
T Bone's Avatar
536
Just a little off tangent for this thread but 3.91 and 4.1 gears are standard BMW Motorsports gears.
The 3.91 is a good compromise that works on the street and track.
The running gear for M5 / M6 are identical, stock rear end is 3.62.
      08-13-2007, 05:45 PM   #19
hl0m4n
hl0m4n's Avatar
isn't the general aspect of 4.10 gears on a n/a car true so you can accelerate a tab better and stay in gear longer, thus installing it on a s/c is no good b/c you have to shift too soon like in the m3 s/c which most members use 3.91.
      08-13-2007, 05:51 PM   #20
T Bone
T Bone's Avatar
536
You cannot look at rear end gearing in isolation of the transmission gearing and the engine powerband.
You cannot make generalizations such as 4.1 gearing is better on an N/A car.....
      08-13-2007, 07:39 PM   #21
gtb75
gtb75's Avatar
9
very informative,
SXRD is actually just Sony's name for LCoS technology - Liquid Crystal on Silicon. Some TV's use LCD's, others use DLP's, while any Sony that says SXRD uses LCoS. IMO LCoS is the best picture out there for rear projection TV's and is as good or nearly as good as the best Pioneer Elite plasmas (much more money).
But yes, I believe Sony started putting 1080p inputs on SXRD sets starting with the A2000 series (first non-XBR to offer SXRD) for their standard line and the XBR2 series for the XBR line. Those of us with the original SXRD XBR's are the only people with sets that use the SXRD image engine but don't have 1080p inputs.
2006 Corvette Z06
