Go Back   XBimmers.com | BMW X6 Forum X5 Forum > BIMMERPOST Universal Forums > Classic BMW (Pre-2005 Models)
      11-20-2023, 09:43 AM   #1
540fan
540fan's Avatar
33
Drives: BMW M4 F82, BMW 540iT E39
225,000 mile 540iT Propeller shaft issue
My 540iT with 225,000 miles with a full refresh including new engine, transmission, etc… has developed a rotating noise from a stop under heavy acceleration. I can feel the vibration bottom of the driver’s seat and it lasts about 6 clunks and then goes away. Under normal acceleration or high speed acceleration, it doesn’t happen.
I’m thinking it’s the center bearing starting to go bad. Shaft is original to the car. The rubber “weird” named disc was replaced a few years ago. The CV joint at the rear by the differential is starting to sling small amounts of CV grease.
I’m thinking of ordering a new propeller shaft (BMW speak) or driveshaft for us ‘Mercian’s…. but wanted to know if anyone has rebuilt and just replaced the center bearing and rear CV joint. Probably a few hundred dollars over a new replacement from FCP. I’ll do the work myself but just wanted to know if anyone has:
1. Experienced this noises before?
2. Replaced or rebuilt the propeller shaft?
It’s a BMW so I have already put more into it Thant it’s worth so the extra dollars are not a show stopper but was wondering what others have done in this case.
Thanks in advance!
      11-20-2023, 11:39 AM   #2
Chihuahua
Chihuahua's Avatar
4076
Drives: E30 329iS, E65 Alpina B7
Yes, had very similar symptoms in my E30 many years ago. I resolved them by replacing the driveshaft with a new guibo as well (the weird rubber thingy.
Good luck.
      11-20-2023, 10:49 PM   #3
e61it
Drives: bmw 545it
Also replaced the guibo but not the driveshaft on my 540it. It was a sweet ride.
      12-03-2023, 12:54 PM   #4
540fan
540fan's Avatar
33
New Propeller Shaft, i.e. Driveshaft arrive from on Bimmerworld and installed and problem was eliminated. Rather easy install taking 3 three no rush hours working with my QuickJacks and creeper on the garage floor. Did not encounter any of the usual BMW headaches.
Here is the source of the noise and rotating knocking. 221,000 miles and it’s in good shape other than the center carrier bearing. I could probably rebuild it but these shafts seam pretty easy to get. If anyone is around the Charlotte, NC area and wants it, it’s free if you pick up.
Thanks for the feedback.
