      03-14-2019, 07:39 PM   #1
Lviv777
Drives: f30 330e, C8 Vette
Questions about oil change.
Looking at doing an oil change for the first time as an owner of the e70. On my e39 I always used pennzoil 5w-30. However in the owners manual I see that bmw recommends anything from 0w-30 to 5w-40 for the n55. Which viscosity do yall use and would recommend for me to use?
FCP Euro has liquimoly, I'm thinking about ordering that. Anyone using it and how does it hold up?
Got past 110k Miles this past weekend, thinking that pennzoil high mileage platinum would work best but I am open to suggestions.
      03-14-2019, 08:27 PM   #2
Sophisticated Redneck
Drives: 2012 BMW X5 50i
140k here, HIGHLY recommend liquimoly 5-40, link below. Toss in 1.5cans of the Mos2 additive also. You will notice smoother idle and cold starts as well as a minor but noticable mpg gain (about .5mpg). This is a true synth oil and can take the abuse. I have 30k on this oil changing it around 5 to 8k each time. Was running Castro and Pennzoil before.
https://www.amazon.com/Liqui-Moly-23...gateway&sr=8-3
      03-14-2019, 08:37 PM   #3
Lviv777
Thank you! I'll give it a shot. 5-40 probably better for the SoCal summers. Is Mos2 a must?
      03-14-2019, 08:38 PM   #4
pdX5M
pdX5M's Avatar
Drives: E70 X5M
2013 BMW X5 M  [0.00]
Also using Liqui Moly 5w-40 and their additive. Good stuff. Averaged 18.5mpg over a 200 mile drive this week just seeing if there was improvement and I think there was.
- 2013 X5 M - Silverstone Metallic w/ Black Perforated Complete Merino - All OEM Options - 12.5mm/20mm Spacers - Velos Stage 2 - xHP Stage 3 - AA Catless - Megan Racing Supremo - PTP Blanket - K&N Drop In -
      03-14-2019, 09:10 PM   #5
Happy to help. Definitely not a must, it's just "icing on the cake" the biggest difference I noticed was with idle quality and startups, super smooth now without that mild yet noticable mechanical grinding sensation for the first split second and the little bump in mpg. It honestly feels a bit faster but that's probably just the placebo effect lol. The mpg Numbers don't lie though, I average 700-1000 miles a week often on the exact same roads with long stretches (100+ miles) without stopping and it's something I noticed right away. I average 19.8mpg overall (60/40 split city/hwy)and I usually cruise at 90+ (it's AZ, people drive 80 in the slow lane cause the heat down her does things to ya....)
      03-14-2019, 09:15 PM   #6
quick
Drives: '12 X5M, '01 E55, '91 964 Trbo
Why an additive, does BMW recommends that?
      03-14-2019, 09:26 PM   #7
pdX5M
pdX5M's Avatar
Drives: E70 X5M
Have only changed my oil once so far but I used Liqui Moly Ceratec for an additive. Not sure if BMW specifically recommends it but it certainly doesn't hurt. Anything that will reduce friction and as a result temperatures is beneficial. Didn't know about the MoS2 but if it does the same thing as the Ceratec it seems more cost effective.
https://www.ecstuning.com/b-liqui_mo...xoCKWcQAvD_BwE
      03-14-2019, 09:39 PM   #8
Nope but then again BMW also says the oil only needs to be changed once every 12k or something silly and that the transmission oil is lifetime I've come to the conclusion that BMW is compromised of absolutely brilliant engineers and assholes from Mercedes posing as BMW engineers engaging in Sabotage....it's the only thing that can explain so much amazing engineering and so many stupid missteps in the same vehicle!
      03-14-2019, 09:41 PM   #9
That's a great one too, I've used them both (not at same time). But I do have additive fetish lol the Mos2 is temporary where the ceratec actually forms a chemical bond.
      03-14-2019, 09:59 PM   #10
Lviv777
Thank you all for the help! Ordered 5-40 liqui moly from FCP along with Mos2.
Any recommendations for transmission oil?
      03-14-2019, 10:01 PM   #11
Lviv777
I do mostly city driving, with rare long 700 mile drives through the desert. Any improvement in MPG would be a blessing. Looking to keep the car for as along as possible and great oil is the way to start.
      03-14-2019, 10:03 PM   #12
Lviv777
18.5 in a M? Wow those are pretty good numbers.
      03-14-2019, 10:09 PM   #13
Ravenol is a great name and get the 6HP flavor if you have the 6 speed or the 8HP if you have the 8. You will need about 5 liters for the 8 speed (can't speak for the 6). (Avg is about 4.5 liters back in. Oh and grab this:
https://www.amazon.com/gp/aw/d/B0119..._pd_title.html
It's worth every penny, you will thank me later, makes filling the transmission a breeze and easy, the LAST thing you want is to be fumbling with some silly pump while your under it and engine is running, the exhaust pipe just waiting to burn ya all while trying to get that blasted last pint in.
      03-14-2019, 10:12 PM   #14
pdX5M
pdX5M's Avatar
Drives: E70 X5M
Basically babied it the whole way not really getting into boost but still averaged 60-80mph most of the way. Total for the 400 miles was 17.9mpg but I went manual mode through some snow on the way home.
      03-14-2019, 11:19 PM   #15
Lviv777
That's excellent, I averaged that in my 35i for total of 700 miles. However I do have a leadfoot.
      03-14-2019, 11:19 PM   #16
Lviv777
Ill give it a try, thank you!
      03-19-2019, 01:27 PM   #17
yco
i'm just saying
yco's Avatar
5735
Drives: E71 X6M '10 (sold)
no need for 0w in California.. i d go for 5w-40..
      03-19-2019, 08:49 PM   #18
Poppyboy
1976 Triumph TR6  [10.00]
1993 Bentley Turbo R  [10.00]
2011 X5  [10.00]
Any concerns about using 5W-30 provided it’s LL-01 spec? I only change 1x/yr, and half the year it’s cold. I figured 40W may be too heavy for the cold weather.
      03-19-2019, 09:52 PM   #19
pdX5M
pdX5M's Avatar
Drives: E70 X5M
Originally Posted by Poppyboy View Post
Any concerns about using 5W-30 provided it's LL-01 spec? I only change 1x/yr, and half the year it's cold. I figured 40W may be too heavy for the cold weather.
The 40 in 5w-40 has to do with how well the oil performs when hot. 5w is the ambient temp rating and is just fine for cool winter days in Cali. 5w-40 is the way to go.
Edit: saw your other post and looks like I chimed in late. Next change I'd say go with 5w-40.
      03-19-2019, 10:16 PM   #20
TwinSnailz
TwinSnailz's Avatar
75
Drives: 2011 X5//M
Not all brands of oil have the same specs for 0w-40. Mobil 1 0-40 is as thin as 30w. While castrol 0-40 is somewhat in the 40w category.
Whats more important is HTHS being no less than 3.5 is what makes it suitable for bmw or Germans.
Liqui moly 5w-40 is really thick hence why most people notice smoother quieter.
Read the specs for each company and pick your likings.
If you must use high mileage oil for leaks, Mobil 1 10w-30 is your best bet,with 3.5hths, but I wouldn’t go over 5k miles.
Pennzoil euro 0w-40 seems to be in middle and this is what Im using.
      03-20-2019, 08:25 AM   #21
Nyc Dito
Nyc Dito's Avatar
113
Drives: BMW X5 35d
When I worked "back counter" at a BMW dealer we had bottles of Ceratec. It was so long ago, I do not remember when or why certain cars would receive the additive. If BMW recommended it or not, again i'm not sure but that wasn't really a decision that was made the parts/service manager.
I do know that now I see a lot more indy shops using their products. LM has been pushing harder in recent years to make their additives known.
E70 LCI 35D
Sutphin trans tune///xDelete///What EGR?
      03-20-2019, 08:29 AM   #22
Bilbofraggins
Bilbofraggins's Avatar
Drives: 2013 X6M, 2019 X3 M40I
I average 16...to 19mpg....so quite happy...but it is what it is...5/30, LL04...no additives. No oil consumed between oil changes....at 10,000Km intervals...
