04-16-2019, 07:26 PM | #1 |
Rep 269
Engine Malfunction time to time.
I was driving on the freeway light throttle about 30-40 mph and got Engine Malfunction, Power reduced. Came home turned the car off, message disappeared, went to my indy shop, the car was showing no codes. Been coming on an off for a few days now both in street driving and freeway but always when im at city speed.
Carista is showing code 2c57 Car doesn't drive any different and I can't feel anything. Boost builds as normal and it drives perfectly fine. Anyone know what the issue could be? Did some research and checked older threads but couldn't find concrete solution. Thanks! |
04-16-2019, 08:04 PM | #2 | |
Rep 369
04-16-2019, 08:15 PM | #3 |
Rep 269
04-16-2019, 10:45 PM | #4 |
Rep 269
Anyone experienced this before by any chance? I see from other threads its somewhat a common issue, and happens at lower mileage, Im well past 110k now
04-17-2019, 12:36 AM | #5 |
Rep 755
Drives: 2019 BMW X6M
This is based out my experience with a 2013 650i wherein I experienced 3 engine malfunctions in the year and a half I owned it. Car was a BMW CPO with 43K miles. Each time, the car would vibrate and misfire but the malfunction code would go away and car seemed to run ok. Each time I brought it to the dealership for warranty repairs, they ended up replacing a combination of ignition coils, spark plugs, HPFP, and various vacuum lines.
2019 BMW X6M
2013 Lexus RX450H 2010 Nissan GTR AMS Omega 14 |
04-17-2019, 12:46 AM | #6 | |
Rep 269
04-17-2019, 12:55 AM | #7 |
Rep 755
No problem. Good Luck.
2019 BMW X6M
04-17-2019, 12:26 PM | #8 |
Rep 264
For me it was the vacuum lines on top of the motor. Just disintegrated over time, they crack, and you can't see the crack. I replaced one, but still getting the engine malfunction, then run rough, then next startup it's fine. Just replace those plastic lines on top of the engine. It says misfire cylinder 6 for me, but there's nothing wrong with cylinder 6 as I replaced coils, but even the dealer couldn't figure that one out, lol.
04-17-2019, 01:31 PM | #9 | |
Rep 269
Is it this? http://www.fluidmotorunion.com/2011-x5-boost-pressure/ |
04-17-2019, 01:54 PM | #11 |
Rep 357
Drives: E70 X5M
Tough to say really. If you said it feels like it's running normally and building boost as it should then you'll likely be OK but have that AAA card or other tow coverage handy just in case.
- 2013 X5 M - Silverstone Metallic w/ Black Perforated Complete Merino - All OEM Options - 12.5mm/20mm Spacers - Velos Stage 2 - xHP Stage 3 - AA Catless - Megan Racing Supremo - PTP Blanket - K&N Drop In -
04-17-2019, 08:17 PM | #12 |
Rep 269
Drove it 100 miles today, and it was all fine, so going to hope my luck stays with me and it's all good.
04-18-2019, 01:39 AM | #13 |
Rep 2,062
I've been chasing reduced power warnings on and off for like 3yrs, replaced all the CCV lines and like 3/4 of the vacuum lines and it still comes on. It's annoying as shit while trying to race someone or it just happening randomly (I've even learned to shift into Neutral, cycle the engine off and back on, then back into Drive while still moving) but it hasn't stopped me from making three Bimmerfest trips from Seattle to Hollywood to Vegas and back so I'd say you're fine...but keep chasing it because it's only going to get worse.
'10 BMW X5///M - Alpine White on Sakhir Orange - JB4 w/ HCP Stage 2 BEF, NGK 97506 @ .20, SS tubing & BMC filters, gutted cats, AC Forged 312 22's, H&R 2"
'98 BMW 740iL - ///E39 M5 6spd swap, fully built engine (sleeved, P&P, cams), 3.46 LSD, H&R Stage 2/Bilstein HD, Magnaflow 14816's '97 BMW 328ci - ///E36 M3 clutch & L/W flywheel, Z4///M 18's Last edited by m5james; 04-18-2019 at 01:48 AM.. |
04-18-2019, 08:22 PM | #14 | |
Rep 269
Ill keep on chasing it! |
04-18-2019, 08:25 PM | #15 |
Rep 269
Little update, after about 150 miles of not getting it, it pop up on the freeway on ramp.
This time I felt no boost coming in from the small scroll in the turbo. So from cruising RPM up to about 3-4k it felt dead, after that boost picked up. Took it to my indy, but by the time I got there the light disappeared and no codes were stored. Told me it could be attributed to the car getting hot lately??? Ill keep an eye out on it tomorrow during my road trip. Hopefully this thread will help anyone else having the same problem. |
04-24-2019, 12:16 AM | #16 |
Rep 269
You guys won't believe it. Its been 200 miles from the time the code last showed up. As my mechanic suggested it could have been bad gas and it makes sense. I usually fill up at shell or costco, but before that filled up at sinclair, and after that the code started showing up. If anything changes I will update the thread, otherwise don't fill up at untrusted locations.
04-24-2019, 01:30 AM | #17 | |
Rep 755
2019 BMW X6M
04-24-2019, 10:38 PM | #18 | |
Rep 269
05-23-2019, 10:26 PM | #19 |
Rep 1
2008 bmw x5
I was driving on the freeway a few days ago and all of a sudden there was a message that came on saying "Transmission Malfunction" Drive with caution or to the side of roads or something to that nature. But the car it was like slipped into neutral in the middle of the freeway. So I braked and stopped the car, threw on my hazards, shut the car down and then restarted the car and it was like nothing happened. I went on my marry way. I got to my destination turned off the car for an hour or so, got back into leave, started the car put into drive and it wouldn't move forward. It was like the front door was a door ajar and it wouldn't let you move. But it left go in reverse. No message this time. So again, I shut car off, turned it back on and drove on. No issues. Three passes, I turn on the car and try to reverse this time, its like it got stuck, then turned off the car and turned it back on and no issues... What could this be?
I should also say that the day before all this started I was driving on the freeway and AWD/4x4 malfunction came on as well. Shut the car off, turned it back on and I haven't seen it again since then. The car was served at Seattle BMW about three weeks ago. They said the car great. Had an oil change. No issues... Baffled. Last edited by MsHill; 05-23-2019 at 10:28 PM.. Reason: added info |
05-23-2019, 10:34 PM | #20 | |
Rep 269
Also Id suggest you make your own thread. This is for engine malfunction which is different from Transmission. That way you will get more helpful answers |
