03-20-2019, 08:34 AM | #1 |
Rep 18
New to me used 2012 X5 50i
Hi folks! This is my first Bimmer. Am I doomed? Or are there any good words about N63?
So far it has 115K km (72K miles) on it. Sounds healthy and drives good. |
03-20-2019, 08:57 AM | #2 |
Rep 491
Take it on a long test drive on highway at 80mph and see if any check engine light comes up
Get new plugs and coils replaced before you buy. Check engine partions for crumbling. |
03-20-2019, 09:02 AM | #3 |
Rep 18
03-20-2019, 09:15 AM | #4 |
Rep 491
Enjoy the 50i Its the best SUV money can buy. I have the same 2011 50i and after a few updates., it drives like a champ. Nothing comes close to it except maybe a Porsche Cayenne. |
03-20-2019, 09:59 AM | #5 | |
Rep 1,564
Long version: I Have 2012 50i with 141K on it. I put 40,000 miles on in it in one year so I drive it hard. The biggest problem with the 50i (and M) is that the engine is a reverse flow "Hot Vee". This means the exhaust manifolds and catalytic converters, items normally located away from the engine, are actually placed in the center of the valley of the engine, underneath that pretty engine cover. Yes thats right, items that reach well over 1000 degrees are tucked in there along with all kinds of wonderful plastic hoses and bits and then covered up by that engine cover which also has sound deadening material that also acts as amazing heat blanket(BMW actually calls it an Acoustic cover). To make it worse, the 50i is unique with its crazy air filter system that further traps heat soak from the exhaust system and cooks the living hell out of the heads, thus why our coils and CCV tubes fail much sooner then the M version of the engine as it has a different air filter design. Throw that damn engine cover out and toss your rear partition (alot of users will disgree with me on that one, but until they get a 140K on their N63 powered X5 in the AZ heat, they know not what they speak of) So unless they have recently been replaced, look out for the following within the next 10-30K miles: Misfire codes & engine malfunctions from worn plugs and coils. Misfire and rough "surging idle or underboost codes from cracked CCV tubes Coolant leaks from the hoses going to the turbos, head to head hose under alternator. If the previous owner was a dick and used cheap oil then expect blocked turbo oil return lines (your engine will smoke like a James Bond smoke screen if this happens) around 90 to 100K, most N63's start smoking pretty bad due to bad valve seals. Install catch-cans with adjustable CC Vacuum and get at least another 40K out of it without having to spend 3 grand to have them replaced (or 1000 dollars in tools and 40 hours to do it yourself) , I am working on a write up how to do these, been taking me forever but will have it up long before its a issue for you. Change your tranny oil at 80K, BMW says its lifetime because their marketing team has a drug problem(obviously), ZF the actual maker of your ZF8HP70 transmission recommends changing it at 80 because they believe in reality. One would think the actual maker of the transmission would know best. Do you see the pattern here? All items are heat related and thats why I always shout my mantra of throwing away the engine cover and rear partition, get some friggen air flow in that tomb of an engine compartment. Twin turbo v8 reverse flow with an damn engine cover and an engine compartment so tight you can pour water on your engine and a drop wont hit the ground.....they need to bring back drawn and quartered specific for whoever thought that was a good idea..... So as mentioned before, Enjoy the 50i, it drives like no other, but be prepared. You have a complicated machine....any car that has 3 water pumps and enough wires and tubes to reach the moon if put in end to end is going to be. Get a Foxwell 510, 520, or Bimmergeeks Protools and start surfing for the best coil and plug prices & CCV component prices (avoid Bosch Coils made in Slovenia like the Plague, Eldors are a safe bet, get generic Bosch plugs or be fancy and get the Iridium NGK's, I have them, they rock) Even if you dont do the work yourself, having the scan tools and being informed will prevent you from being bootyraped by the repair shop/dealer. Last edited by Sophisticated Redneck; 03-20-2019 at 10:17 AM.. |
03-20-2019, 10:15 AM | #6 | |
Rep 491
If you want a soccer-mom SAV then do NOT buy the 50i or X5M |
9vapors648.00 |
03-20-2019, 10:55 AM | #7 |
Rep 18
Thanks guys for the input. It gives me some hope after I read all the horror stories. My normal drive is a 15-20 min on a country road with a few stop signs. No have traffic.
I'm very good mechanically, so far had no issues maintaining and fixing my Volvo XC90 and Tundra. From wright-ups and videos about repairs on the web, I see nothing that I can't handle myself. However I bought extended warranty with it, just too many other projects on the go. |
03-20-2019, 11:09 AM | #8 | |
Rep 780
03-20-2019, 12:34 PM | #10 | |
Rep 1,564
03-20-2019, 01:09 PM | #12 |
Rep 18
03-20-2019, 06:39 PM | #13 |
Rep 780
03-21-2019, 04:20 PM | #15 |
Rep 449
I am sitting at 126k and this is the best worst thing I have ever owned. My 27 mile daily commute is all back roads, so this thing murders all of them like a heavyweight rally car.
I like the inverted V concept, its a very good idea, if you do proper heat shielding the packaging in theory is better then a regular V. I know it really helps with the packaging on the Ford 6.7L Powerstoke. with the f15 X5 going soft, I will probably replace this one with a Cayenne (as long as sport still lives with Porsche Mid sized SUV'S) or something just as sporty
2011 BMX X5 Xdrive50i - 127K - No muffler, BMS Stage 1
2005 Jeep Grand Cherokee 5.7L V8-Her stock DD 1995 Ford Thunderbird 4.6 V8 LX - A bunch of mods BMW guys don't care about 1995 BMW 540i6 - H&R Lowering Springs, Bilstein's, Racing Dynamics Bars, Catback, Short shifter |
03-22-2019, 11:38 AM | #18 |
Rep 491
I made a conscious decision to buy N63 2011 even though it so much known for issues. I test drove the F15 X5 and the feeling is of total let down. Sort of like wimpish version of the older X5s
So I bought N63 and spent nearly $6-$7 k to update it and now I don't regret it. Best performance BMW one could ever drive. |
03-22-2019, 12:11 PM | #19 | ||
Rep 138
2012 X5M /// Velos Stage 2 /// xHP Stage 3 TCU tune /// Sprint Booster
2013 X3 35i M-Sport |
03-22-2019, 01:02 PM | #20 |
Rep 1,564
03-28-2019, 06:47 PM | #21 |
Rep 18
So I think the fun has begun for me too - just noticed a significant coolant puddle under the car on the passenger side. Also some sort of whistling sound at certain rpms. I wonder if those two are connected.
03-28-2019, 11:04 PM | #22 |
Rep 357
Hey Rednex, did the ngk plugs use the same socket as the bosch? I looked up the part # for the Ngk and the picture shows that it uses hex which I don’t think a regular hex socket will fit through the spark plug tunnel.
