02-13-2020, 07:56 PM | #1 |
Rep 26
Blower Fan Speed Not Responsive
Searched quite a bit and haven't found much. I can increase the HVAC fan speed all the way up and seems it really doesn't change speed. However, if I put it on Defrost it will run full bore. Take it off defrost and back to no change with the button up or down - fan speed stays pretty much low and constant.
Thought it might be blower regulator, but thought I'd check with anyone else run into this. Getting cold here in Chicago and need some fan speed. Thanks in advance. robc |
02-13-2020, 09:48 PM | #2 |
Rep 360
Couple things...
1. If there's no heat in the engine it won't speed up the fan. Unless you are on defrost 2. Are you having trouble with battery or getting warning messages. The car might be protecting itself by shutting down the fan speed. |
02-14-2020, 07:07 AM | #3 |
Rep 26
Hmm. Not number 1. But number 2 is possible. Right now I know I don't have the correct battery in the car (bought it that way) and occasionally I'm getting low battery warning messages. Dealer told me yesterday that battery was going and needed $600. Interesting protection circuit...managing fan speed. I wouldn't rule it out with this vehicle.
Thanks for the thoughts. |
02-14-2020, 07:10 AM | #4 |
Rep 714
This happened to mine. I replaced the motor(not the regulator) and it fixed this. My fan was also squeaking for a wile before it quit, and it ended up doing what you described for a few days and then quit altogether.
02-14-2020, 05:42 PM | #5 | |
Rep 1,054
2011 335d tuned by B.R.R.
2011 X5 35d tuned by B.R.R. |
