02-11-2020, 07:29 AM | #1 |
Rep 397
Power steering pump dead again
Having issues with my power steering again after replacing the pump 3 years ago in 2016 when the pump started shooting fluid out.
This time the pump makes a very loud knock inside the pump at certain times, steering is impossible while parking ... The problem here is these fucking pumps cost 1500 and this is the second failure I’ve had, first was about 90k miles now this one again What kind of BS is this BMW I’m seriously considering selling because of this, really tired fixing extremely expensive parts to break again and again especially when it takes 2 days to fucking replace. Seriously how the f can these pump cost 1500 new and not be bulletproof - literally being charged through the nose because they only made these pumps special for this model so we can get fucked, dealer price is probably about 3-5k installed and the part has a 12/month warranty like that matters |
02-11-2020, 12:55 PM | #3 | |
Rep 397
I’m questioning if I should replace everything with the steering at this point as maybe something else is causing the premature pump failure within the steering although I know it is going to be stupid expensive but maybe worth it at this point. I might just let it sit for a bit since I’m pretty pissed off at the car now as I contemplate on selling it, fixing it or just setting it on fire. |
02-11-2020, 05:28 PM | #5 |
Rep 357
Im quite sure the OP have the active suspension(//M) which is why it cost over $1k. Mine is groaning and I was looking into a new pump. Guess I’ll hold it off for now, every part of these M have gold sprinkles in them.
02-11-2020, 11:06 PM | #6 |
Rep 750
Drives: 2019 BMW X6M
Comes with the territory, all I can say. As much as I love my X5M and I've never had a problem with it (1 year/10K miles later, knock on wood), I have no illusions of it being as bulletproof as a Lexus.
2019 BMW X6M
2013 Lexus RX450H 2010 Nissan GTR AMS Omega 14 |
02-12-2020, 10:43 AM | #7 |
Rep 397
32416799278 - part number
It does not like having the pump bypassed....warning lights are triggered... This entire steering system is really expensive to replace, I want to just replace it with something else entirely that I know will last longer this is not ok every few years. I ended up taking it apart a bit and just lubricating the column and it’s back to somewhat working again. |
02-12-2020, 03:28 PM | #8 |
Rep 357
Did you take the pump out? I can barely stick my hand back around column area to inspect anything. Last time i change the suction hose that goes from the reservoir to the pump, that seems/sounded like a 5 min job to a couple hour struggling to fit my hands back there.
I’ve been hating this truck not only because the quality is junk but the hassle you have to go through just to change a stupidly simple part, a part that shouldn’t have failed this early or at all. |
02-12-2020, 04:15 PM | #9 | |
Rep 397
I noticed an extreme amount of gunk and grime on the column joints I could see without removing anything and was able to spray a lubricant and cleaner on it directly with a little aim for now. When u change the pump you need to take the front radiator out, bumper off etc etc ... it’s actually quite a bit of work since these is so little room everything must come out. Very frustrating but that is why it costs so much to have work done and why I don’t trust anyone to do it |
02-13-2020, 03:24 PM | #10 |
Rep 51
I am not sure if you are having the same issue I had in my X6 5.0 with Adaptive Drive, but I replaced my pump and Valve block(picture2) 3 times before realizing that expansion hose 1st section(picture1, item#23) was the problem. I did not want to spend $400 for that part alone. It has a filter inside and once it is clogged, you cannot get it clean-up.
02-13-2020, 04:11 PM | #11 |
Rep 357
JMX6V8 , that’s good to know that there is another filter. I have a feeling my is somewhat clogged but don’t know what else it could be besides the reservoir. The amount of hoses these adaptive drive have is crazy.
02-13-2020, 10:23 PM | #13 | |
Rep 51
02-13-2020, 11:44 PM | #14 |
Rep 357
Did you end up replacing the expansion hoses section 1? I don’t have a leak. But i do have bubbles in the reservoir. I bled it like a 100 times turning the wheel full lock to lock.
I vacuum test it and it holds vacuum. I pressure test it and it holds pressure without any leaks. But somehow air is entering the system. I bought new reservoir, 2 new hoses - to and from reservoir Again, no leaks. The air is causing the moaning and whining. I have nothing else to suspect on. |
02-14-2020, 12:40 PM | #15 | |
Rep 51
https://www.newtis.info/tisv2/a/en/e...supply/79eoCpZ It will let you know if the system has air in it and what part of the system need to be bled. Last edited by JMX6V8; 02-14-2020 at 12:51 PM.. |
02-14-2020, 02:28 PM | #16 |
Rep 709
I heard the next gen will do all that and then fix itself too.
OP - you DO have a CCA club discount, when ordering this part right?? Saved me hundreds of dollars over the years. It's normally ~15% give or take, but some parts are discounted even more than that.
heatmizr [Todd]
g26 i4 e40 - Clean Machine e70 X5 50i M-Sport "The Boss" Loaded e90 328i - sold e36 M3 - Gone to become a track star |
