12-07-2018, 02:55 AM | #1 |
Rep 76
Rear tires 315/35/20
As today Dec 07, 2018 just purchased both rear tires and installed continental DWS06, they claimed will last at least 50k miles. We'll see..how long these tires gonna last.
I had continental DW extreme contact summer tires and dunlop both worn out not over 10k.I dont drive much prolly just once aweek.First I thought maybe need adjustment or some bad rear bushing.I checked everything they all good.Its always inside edge and the middle section of each rear tires worn down to the belt. Any thoughts? |
12-07-2018, 06:41 AM | #2 |
Rep 491
4.8i is a very heavy SUV. It eats brakes and tires. I put cheaper Achilles Desert Hawk 315 tires in the rear. Cost me only $120 each. I can change them every year and still pay less then Contis DWS06
https://www.amazon.com/Achilles-MAG3...esert+hawk+315 |
12-07-2018, 11:33 AM | #3 |
Rep 310
I am currently at around 22-24K on the DWS on the rear of my X5M and they are still doing great. I would suggest a double check on the alignment, and actually talk to the tech doing the work, see if they have any suggestions to help that inner wear.
12-07-2018, 02:17 PM | #4 | |
Need mo $$s
827
Rep 880
The tread ware rating is good for that, but not on our X5s. I just installed the DWS 06s (again) on my winter 20" setup for my 08 4.8 also, got 27k out of the last set. Had the previous generation also and these are even better, they really are a GREAT tire! Not much can be done on the inside edges due to the negative camber (it's a good thing, you want to have it). We also can't switch the DWS 06s side for side, since they are directional, but if they are wearing in the middle (cupping) the tire pressure may actually be too high for the specific tires/wheels. You might want to look at lowering your tire pressure a bit too... You don't have to run what BMW states on the door sticker I personally like to run 28PSI front and 30PSI rear. Tire pressure can make a HUGE difference in the wear of the tires, comfort in the ride and the handling... Try the lower pressures (be sure to reset your TPMS) and see what you think.
2020 TRM-BLACK X4///M Competition
2020 Porsche Macan 1995 Dodge Stealth TwinTurbo Past: 2020 X3M, 2019 TTS, 2008 X5 4.8 M Sport Last edited by 95wildtt; 12-07-2018 at 03:28 PM.. |
12-07-2018, 04:37 PM | #5 |
Rep 3,034
Drives: 2022 BMW X5
good tires, I don't see any issues them lasting at least 50k but it will depend on your driving...
12-07-2018, 10:30 PM | #6 | |
Rep 76
12-07-2018, 10:34 PM | #7 | |
Rep 76
Will try run those PSI, previously i had them 35 PSI all fours. |
12-08-2018, 04:29 PM | #9 | |
Rep 310
Toe can be a big deal as well for inner wear, so make sure it's in spec. |
12-16-2018, 09:43 PM | #15 |
Rep 76
man you guys, 22 yrs old lexus suv.
Yup '97 lexus lx450, top n bottom bored maxed out to 4.6 litre, the suv only had 3k miles in it right after rebuilded the whole motor. pic as you requested... sorry back to X5 topic, please... |
