11-25-2018, 03:14 PM | #1 |
Need mo $$s
831
Rep 885
NBT EVO Retrofit TPMS Question
Hi,
For those who have done the NBT Retrofit, does your TPMS display (under Vehicle Status) work correctly? I recently looked at mine to see what the pressures looked like, and the value is wrong for both PSI and kPA, but correct for bar. It looks like the values are being reported correctly by the TPMS system, but the NBT isn't converting from bar to kPA or PSI correctly. Here are my tire pressures (measured with my gauge): LF: 31 PSI / 2.17 bar RF: 31 PSI / 2.17 bar LR: 33 PSI / 2.27 bar RR: 33 PSI / 2.27 bar Anyone else seen this issue, and if so how did you resolve it? Thanks in advance, John
2020 TRM-BLACK X4///M Competition
2020 Porsche Macan 1995 Dodge Stealth TwinTurbo Past: 2020 X3M, 2019 TTS, 2008 X5 4.8 M Sport Last edited by 95wildtt; 11-25-2018 at 03:26 PM.. |
12-17-2018, 06:08 PM | #2 |
Need mo $$s
831
Rep 885
Hi,
Had no luck so far... replaced the RDC (TPMS) module with a newer SW version/part number and no joy... Based on input from BimmerRetrofit, I've been checking the code/firmware revision in my modules: KOMBI - Stores the units/date/time etc information RDC - TPMS module Can you help by posting info from your UIF screen from INPA for the above 2 modules: Module ZB No. KOMBI 9236812 RDC 6785279 I have a 2/2008 build date, and others in the same range with TPMS/NBT working? BR says they have never heard of this issues on an E70 before, but maybe I have the oldest build date...??? Thanks in advance, John
2020 Porsche Macan 1995 Dodge Stealth TwinTurbo Past: 2020 X3M, 2019 TTS, 2008 X5 4.8 M Sport Last edited by 95wildtt; 12-17-2018 at 06:17 PM.. |
02-27-2019, 10:50 PM | #3 |
Need mo $$s
831
Rep 885
Update...
The great support team at Bimmer Retrofit provided a Firmware update for their eNBT adaptor and I now have all units (PSI, Bar and kPa) for the TPMS in the NBT Evo. Thanks for your awesome support Bimmer Retrofit, Andrew Rocks! John
2020 Porsche Macan 1995 Dodge Stealth TwinTurbo Past: 2020 X3M, 2019 TTS, 2008 X5 4.8 M Sport |
IN-FLT12.00 |
02-28-2019, 12:17 PM | #4 |
Rep 32
version
hey just curious, is a newer version than 2.70e on their website?
http://bimmerretrofit.com/store/inde...egory&path=162 |
02-28-2019, 12:57 PM | #5 |
Need mo $$s
831
Rep 885
They sent me a 2.70j last night and it's what I'm using now.
Andrew mentioned applying the patch and posting it. You might want to contact him to see about getting the latest. Thanks, John
2020 Porsche Macan 1995 Dodge Stealth TwinTurbo Past: 2020 X3M, 2019 TTS, 2008 X5 4.8 M Sport Last edited by 95wildtt; 02-28-2019 at 04:59 PM.. |
04-10-2019, 07:07 AM | #6 | |
Rep 93
I have recently retrofitted NBT ID4 on my E90 BMW, but I only have Tire pressure display and I can't have tire temperature display. Does your NBT display temperature as well as pressure or pressure only ? Thanks ! |
04-10-2019, 03:31 PM | #7 | |
Need mo $$s
831
Rep 885
I only get pressures, no temps. Sorry, John
