      09-11-2019, 01:29 PM   #1
Demosc430
Drives: 2008 x35d
Rawtek for dpf delete?
Hi, guy. Well the time has come to build my wife's 09 x5 diesel the way it was always meant. After having a clogged dpf, my finally getting a low vehicle performance indicator... I recently purchased the rawtek dpf delete and catalytic converter with the malone stage 2... I wrote a few other people/companies about the dpf delete, but in all honesty, only rawtek reached back to me... is the rawtek/malone setup a quality setup/good brand or did I shoot myself in the foot?
      09-11-2019, 01:43 PM   #2
sunny_j
sunny_j's Avatar
211
Drives: 2012 X5d
If you already spent the money then who cares if you shot yourself in the foot lol?
Rawtek should be fine and since you got a DOC it should help with the diesel exhaust smell
2012 X5d | Deleted & BRR Tuned | DWR TCU Tune | 10.25" Android 8.1 Screen
Build Thread
https://www.xbimmers.com/forums/show....php?t=1529213
      09-11-2019, 01:45 PM   #3
Demosc430
Drives: 2008 x35d
Because it's not delivered yet and I'm pretty sure I can cancel the order
      09-11-2019, 02:12 PM   #4
sunny_j
sunny_j's Avatar
211
Drives: 2012 X5d
I went with a buzzken DP with DOC because it was the cheapest option. Recently switched to the BBR tune from JR 2.8 which I ran for a little over a year
Build Thread
      09-11-2019, 06:02 PM   #5
RL18
Drives: 2011 335d sport
They're all basically the same stuff. Theres been many guys with that downpipe on their 335ds and they haven't complained.
If you can cancel the order then do it if you want and get the atm downpipe and scr delete.
If you can't no big deal. Just make sure you have the block off plate for the second egr cooler!!! I know the atm "kit" comes with it too.
As for malone tuning I've heard good things also. I personally went with BRR like sunny j and don't regret a thing about it.
2011 335d tuned by B.R.R.
2011 X5 35d tuned by B.R.R.
      09-11-2019, 08:22 PM   #6
Demosc430
Drives: 2008 x35d
I would of preferred the atm speedshop one but they are out of stock until the end of the month and I'm kinda needing to get this repair sooner than later (I dont like when my wife drives my car because she always complains after)... yeah, it is what it is at this point. At least the hardware would be in... hey RL, how many block off plates should be installed... I spoke with Rob out there at rawtek and he said it comes with a block off plate for the egr cooler... but I wasn't aware of a second egr cooler?
      09-11-2019, 10:14 PM   #7
sunny_j
sunny_j's Avatar
211
Drives: 2012 X5d
He's talking about the second EGR on the DPF. The upper EGR block plate will come with the race pipe which deletes the EGR
Build Thread
      09-12-2019, 06:57 AM   #8
RL18
Yes what he said ^
OP are you doing the deletes yourself or having a mechanic do it?
      09-12-2019, 08:38 AM   #9
Demosc430
Drives: 2008 x35d
Well my mechanic says hes never done one of these before and I've never done one of these before as well... so I guess we will figure it out together.
Anything else to look out for?
      09-12-2019, 12:29 PM   #10
RL18
This will help a lot then: DIY - E70 X5d DPF Delete (Good Reference for 335d) https://www.e90post.com/forums/showthread.php?t=1307679
It's not that bad. Did my 335d in a day. My x5 when I do it will probably take half the amount of time now that I'm familiar with what I gotta do
      09-12-2019, 12:44 PM   #11
sunny_j
sunny_j's Avatar
211
Drives: 2012 X5d
be prepared to drop the subframe unless you take a hacksaw to the factory dpf
Build Thread
      09-13-2019, 07:23 AM   #12
RL18
Did you have to drop the entire subframe? That diy shows just loosening the subframe bolts then removing the engine mount and you should be able to wiggle the dpf out.
I haven't been able to look at my x5 on a lift but I know my 335ds dpf almost dropped on my head after I removed the engine mount. I also had an engine support tilting the engine up on the passenger side with the drivers side mount loosened so that might of given me lots of space too. Also I had the rest of the exhaust hanging so the flange wasn't in my way.
      09-13-2019, 12:59 PM   #13
sunny_j
sunny_j's Avatar
211
Drives: 2012 X5d
not entirely but even dropping it a little is such a PITA
Build Thread
      09-14-2019, 07:30 AM   #14
RL18
Yeah that sucks. I'm not looking forward to it, but I want more power lol
      09-14-2019, 02:59 PM   #15
sunny_j
sunny_j's Avatar
211
Drives: 2012 X5d
That's why you take a hacksaw to it
Build Thread
      09-14-2019, 04:46 PM   #16
RL18
Oh boy. I hope not! I sold my last dpf and got a couple hundred for it on my 335d
