bimmerpost/
BMW M2 and 2-Series Coupe
home
BMW 2 Series Forums (G42) G42 2-Series General Topics
      04-10-2024, 06:29 PM   #1
IndyRed128i
IndyRed128i's Avatar
233
Drives: 2022 BMW 230I(Red)
Extreme Sunroof rattle when closed? Anyone?
Starting around a month ago, the sunroof makes a very noticeable creaking noise even when going over the smallest of bumps. It does not do this when it is opened or titled.
Have an appointment scheduled for later this week.
Anyone else come across this issue?
      04-10-2024, 07:36 PM   #2
zzt42
Drives: 2022 BMW M240i
Just noticed the same on my car- can’t remember if it did it last spring or not. I’m going to try putting some Gummi Phledge (rubber conditioner) on the seals. It worked on my last car when it had the same issue
      04-10-2024, 07:59 PM   #3
TJZ67201
TJZ67201's Avatar
Drives: '23 M240i
I ceramic coated the rubber seals last year. Never had any sunroof noises in my 7k miles
      04-10-2024, 08:19 PM   #4
PP3121
Drives: 2023 M240i
Experienced only on one occasion - freezing rain covered the car one night. When I started driving the next morning, the whole car seemed to be creaking and cracking from all around.
Have not noticed anything else since that day.
Never had a car do that before although under similar circumstances, so I was a bit shocked and surprised.
      04-11-2024, 08:50 AM   #5
Littlecoupe
Drives: 2023 M240i
What coating, may I ask? I have never heard of ceramic used on rubbers.
Also, I use Gummi Pflege probably 2 to 4 times per year. Mine became noisy and this fixed it right up. Clean the rubber off with a mild detergent and water, let it try, then apply Gummi Pflege. It's hard to get it on one part of the seal. I access the front by sliding the glass back into the roof, then get the rest using the tilt function of the sunroof.
      04-11-2024, 09:00 AM   #6
TJZ67201
TJZ67201's Avatar
Drives: '23 M240i
CarPro DLUX. Specifically made for metals, plastics, and rubber.
I also coated the door seals. It keeps them shiny and supple feeling. I used to use CarPro Perl which is great for rubber. Both protect against UV and friction
PP3121360.50
      04-11-2024, 08:35 PM   #7
IndyRed128i
233
I’m curious, why not just let the dealer take care of it?
      04-13-2024, 07:25 AM   #8
car5m
Drives: 2023 m240i
I have the same issue: sunroof is very rattly when closed. My service appointment is in two weeks.
How did the dealer resolve your rattle?
      04-15-2024, 06:25 PM   #9
IndyRed128i
233
I took it in last Friday and the dealer told me they would need to schedule me for a day when loaner cars are available, as they will need to remove the headliner, and "redo the sunroof"
Was a bit surprised something like this requires all of that to be done.
g87
