07-21-2022, 02:54 PM | #1 |
6MT FTMFW
61
Rep 229
Drives: 11 E90 335xi E91 6MT 12 X5 35i
Garage List 2005 330ci Vert ZHP [0.00]
2011 335xi Sedan M- ... [0.00] 2011 328xi Wagon M- ... [0.00] 2012 X5 35i M-Sport [0.00] |
N55 FBO Exhaust Options to quiet it down?
I have a 2012 35i. I've installed a VRSF downpipe and MHD. The exhaust sounds pretty good, but when you apply too much throttle, the change in sound when the valve opens is obnoxious. I tried propping the valve to always be open so it'd be consistent, but then it's just too loud all the time.
What is a good solution to quiet it down just a little? Ideally I'd quiet it down some and then prop the muffler valve open so the sound is consistent.
2011 LMB E90 335xi 6MT: Wagner EvoII FMIC, Catless DP, PE Mod, Cobb CP, BMC Filter, ST Coilovers, Strongflex TSB's, Whiteline RSFB Inserts, CDV Delete, Hawk Talon Rotors & PC Pads
2011 SGM E91 328xi 6MT: 3-Stage Intake Manifold, ST coilovers, 335i brake kit, drilled/slotted rotors, CDV Delete, Charcoal Filter Delete Last edited by drummr8; 07-29-2022 at 08:05 AM.. |
07-22-2022, 03:25 PM | #3 | |
6MT FTMFW
61
Rep 229
The smell is not great. It's much more tolerable on my 335xi which still has secondary cats in place. I'm wondering if I should install a high flow cat in the X5 and that would help both the smell and the sound? The smell isn't awful, but it isn't pleasant either. My wife hasn't complained other than one comment when I first modded it, so it must not be too bad
2011 SGM E91 328xi 6MT: 3-Stage Intake Manifold, ST coilovers, 335i brake kit, drilled/slotted rotors, CDV Delete, Charcoal Filter Delete |
07-23-2022, 12:00 PM | #4 | |
Rep 129
Or, maybe there is a way to limit the exhaust flap opening all the way? Maybe open it 25% or something. |
07-25-2022, 11:27 AM | #5 |
Rep 60
Try adding a resonator in the midpipe. Something like this...
https://www.amazon.com/Vibrant-1792-...ps%2C79&sr=8-4 Just make sure you have the space and the correct diameter. |
07-28-2022, 12:16 PM | #6 | |
6MT FTMFW
61
Rep 229
07-28-2022, 09:13 PM | #7 | |
Rep 60
https://www.amazon.com/dp/B000COTCI0...axlechassis-20 |
07-29-2022, 08:05 AM | #8 | |
6MT FTMFW
61
Rep 229
