11-12-2019, 02:54 PM | #1 |
Rep 1
2011 BMW X5 35i
Good afternoon, so I am hoping someone can clarify. I purchased 4 winter tires from a guy off kijiji...he says he took them off his 2008 BMW X5 look like original OE rims and Michelin tires
However just got a call from mechanic said 2 used rims with winter tires were installed on back but other 2 would not fit on front without drilling?? So he was going to take the winter tires off the rims I bought and put them on the rims I was using for the front only So Back (2008 BMW Rims and Michelin tires) Front (2011 BMW Rims and Michelin tires) I have no idea what this means anyone? I said well if the four 2008 rims fit on the back I can use two for winters and two for summers but means somehow rims must be different size? Please helps. Thanks |
11-14-2019, 11:33 AM | #2 |
Rep 360
The rear wheels on a X5M or X6 have a different center bore diameter. Therefore they won't fit on a regular X5 without modification.
Other then that there are lots of OEM wheels that have different sizes and offset but should be compatible. |
11-15-2019, 03:43 AM | #3 |
Rep 195
This is correct. The simple fix is to run your wheels with hub adaptors or spacer adaptors. That's how I run my setup
