09-10-2018, 01:33 PM | #1 |
Rep 155
E70 rear air bags
Looks like it's time to replace my rear air bags, it's been sagging after a few hours of usage. About to purchase the after market Arnott's, any issues with these? Does the system need to be re calibrated or is it just a direct swap?
09-10-2018, 01:35 PM | #2 |
Rep 728
I just replaced mine with arnott ...they look different but are direct swap...just need to reuse the oem spring cover
2020 G01 X3 30e CURRENT M Sport Package 2019 Ford Raptor SuperCrew CURRENT 802A, KN Drop-in, RB Flaps, Husky Well Liners 2012 E70 X5M SOLD Stg 1+ Turbos, DPs, Velos Stg 2+, JB4, Race Cats, Bavauto Coils 2003 E46 M3 SOLD aFe CAI, AP Axleback, SSK, H&R Springs, TMS CMBR Arms, PF RTABs |
09-10-2018, 02:17 PM | #3 |
Rep 3,034
Drives: 2022 BMW X5
same here, ordered a pair of Arnott's this morning, install seems pretty straight forward but we will see, sometimes the straight forward can become something else
09-10-2018, 02:36 PM | #4 |
Rep 337
Drives: 2010 X6 M
how do you know if its sagging? i recently lowered my car with H&R springs with lowering links but i dont know if i should replace my rear air bags
09-10-2018, 02:46 PM | #6 |
Rep 337
Drives: 2010 X6 M
09-10-2018, 02:50 PM | #8 |
Rep 337
Drives: 2010 X6 M
09-10-2018, 02:52 PM | #9 |
Rep 3,034
Drives: 2022 BMW X5
what he said
09-10-2018, 03:09 PM | #10 |
Rep 337
Drives: 2010 X6 M
one more question, is it bad to be driving around with saggy air bags? I will replace it but is it something i should do ASAP?
09-10-2018, 10:14 PM | #11 |
Rep 728
09-11-2018, 08:40 AM | #12 |
Rep 337
Drives: 2010 X6 M
i honestly cant tell because i lowered my car recently.....not sure if its sagging or its because the car is lowered to that height..i will take a pic of my car later today when its been parked there all day.
09-11-2018, 08:58 AM | #13 |
Rep 76
if your rear airbag leaks thats not good., your compressor will work twice as much soon or later the compressor will go out... the compressor not cheap.. i rather replace the bags much cheaper.. mine i got the arnotts also.
09-11-2018, 09:49 AM | #14 |
Rep 337
Drives: 2010 X6 M
would lowering your car cause the air bags to leak prematurely?
09-11-2018, 02:27 PM | #15 |
Rep 76
Nope i dont think so.. the bags will hold any amount of pressure, including the towing.. they tested and know when designed the airbags instead of the springs.. it just the airbags when you have small leaks in it.. there you go.. it just like car tires.. you have small leaks either you patch it or replace it
09-11-2018, 02:51 PM | #16 | |
Rep 337
Drives: 2010 X6 M
10-13-2018, 10:14 AM | #17 |
Rep 3
Installed Arnotts two weeks ago. One side ok the other still dropped. Replaced the air valve, no change. The old bags (cheap new bags of ebay) had been dropping since they were fitted but only slowely so I lived with them for a while (a few months). Next thought was maybe the air compressor, which had been working too hard for several months and maybe rwasn't producing enough air pressure ... new pump. Back end lifted like raising the titanic however driverside got carried away. The car is now sitting with a perfec passenger side and a driverside 10cm higher than it should. My local indi tried to sort yesterday by recalibration. He was able to reset but when the car was restarted it went back to the wrong ride hight. urgh! Maybe spring conversion was the way to go but I'm now in for +£500 in parts .... Bought a K+Dcan and currently downloading ISTA. The indi talked about resetting the ecu ........?
10-13-2018, 02:28 PM | #18 |
Rep 12
Replaced mine 3 years ago, wasn't difficult at all. Never had any problems with height afterwards, I didn't perform any recalibration (Bmw mechanic said if you don't have a proper equipment don't mess with it). My friend replaced, recalibrated his at Indy shop and had a problem on one side lower than the other.
But remember don't drop your car until new bags are inflated! For maintenance, just hit it with a water and wipe it with a damp cloth when you wash your car. Last edited by Modern Autos; 10-13-2018 at 02:39 PM.. Reason: Addition. |
10-14-2018, 01:19 AM | #19 |
Rep 3,151
Ordering the Arnotts on Monday. My X5M is sitting low after installing the lowering kit.
Current Mods:
2004 E46 M3cs JB/CSL 2010 E70 X5M AW/BLACK 2011 VW Golf R DSG White/Black IG: @060Motorsports |
10-14-2018, 08:26 PM | #20 | |
Rep 3,034
Drives: 2022 BMW X5
second time doing the bag I jucked up only one side and when I brought that side down now my driver side was seating in the fender again, I ended up jacking up the drivers side one more time and after bringing it down again I was leveled! I heard about calibration before but never attended it, I have coilovers setup and remember plaing with adjustable links before but that wasn't related to the bags.
0-60Motorsports792.00 |
11-16-2019, 01:29 PM | #21 |
Rep 957
my car spent a week at the stealership for a misfire diagnosis, and when i got it back it started to sag in the back after sitting for a couple days. it's dropping on both sides. of course it never happened before the car was at the dealership!
if one bag is leaking, would both sides sag, or only the one that is leaking? i'm trying to determine if both bags are leaking or if there is a leak somewhere else in the system?
2011 e92 ///m3 zcp - jzb/fr
ED 6/29/10 |
