07-26-2018, 09:31 PM | #1 |
Rep 2,821
Drives: X5M F85
Wheel fitment help
Hi all,
Quick one. I already pm'd Gixxer and got his offsets for his wheels he's had in the past. Based on that, i think i'm good but i wanted to run the setups by some other peeps. So I want to go 22x10.5 ET 20 at all corners on Rohana RF2s. Stock 299 s with my spacers 20x10 ET 40 Front with 15mm spacers = ET25 20x11 ET 35 Rear - I have 25mm which over all = ET10 Do you guys think this is possible? Gixxer ran ET 23 on 22x10.5 front making mine 2 tenths of an inch more poke-age. I'm thinking i'm good to run this setup but maybe I'm missing something. Thanks for looking guys. |
07-27-2018, 08:22 AM | #2 | |
Tanzanite Blue II X5M Pilot
1098
Rep 2,077
Drives: M3, M4, X3 M40i, X5M
22x10.5 et23 (same as ADV fronts) 22x12 et15 (5mm more aggressive than ADV rears - my buddy Rodney is currently running these offsets on his X5M and they poke slightly, but it looks really good). Et20s on the front is only 3mm less than what I used, so it will probably poke slightly, but not enough to dispute the difference. Your rears at 22x10.5 et20 however will sink in 19mm.... because you're giving away an inch and a half on the rears over what I was running. Here is the offset calculator that I like to use; https://www.1010tires.com/Tools/Wheel-Offset-Calculator Good luck! Last edited by gixxerboy63; 07-27-2018 at 08:39 AM.. |
07-27-2018, 01:19 PM | #3 |
Rep 3,082
Drives: 2022 BMW X5
these are my numbers before I went with 1 piece, those are for 21" but offsets should be the same
Front - 21x10.5 ET20 Rear - 21x12 ET13
06-25-2019, 09:15 PM | #4 | ||
Rep 2,821
Drives: X5M F85
Which tire size did you run in the front? |
