01-01-2020, 09:12 AM | #1 |
Rep 2
2013 X5M Issues
Hello everyone, I'm new to the forum and hate to introduce myself by asking questions, but I'm in a pickle with my 2013 X5M.
It has 85K miles and it frequently goes into low-power mode after moderate acceleration (e.g., Engine Malfunction, Entering Reduced Power Mode). It also has an oil leak that for the life of me I can't ID the source. From what I've read here, the engine issue is likely the coils/plugs and perhaps the fuel injectors. Is there anything else? I ordered this scanner to help diagnose: https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1 The local BMW dealership quoted $7800 to fix everything; they were vague on the engine issue and said the oil leak is from the oil pan. Tough to justify spending $8K on a car now worth less than $25K. So I'm looking to fix it myself; pointers are much appreciated! |
01-01-2020, 09:28 AM | #3 |
Rep 2
01-01-2020, 11:47 AM | #4 |
Rep 357
01-01-2020, 01:30 PM | #5 | |
Rep 1,564
Plugs: Go with NGK or Bosch, go 1 step colder if you plan on tuning it, 2, steps if you really want to push it. Expect to pay no more then 8 to 11 a plug. Coils: Change ALL of them, do not just change a few, they all start to go bad at the same time. Choose Eldor, they are the best, second is Bremi third Delphi, four the is Bosch (Germany), AVOID Bosch Slovenia unless you like pain. Expect to pay 35-50 each depending on brand. 9 times out of 10 this will take care of issues. If not next is to look into vacuum leaks (CCV tubes) and Injectors last (they are 225 each!) |
argento538.00 |
01-07-2020, 09:42 PM | #7 | |
Rep 230
