05-07-2024, 09:40 AM | #1 |
Rep 1
Drives: BMX X5 xDrive 35i
28A0 - Re group to fix tihis issue together! BMW X5 xdrive35i
Hello Guys,
I got this BMW X5 2012 xdriv35i E70 last year and I am trying to keep it for long term. I have been dealing with a code : 28A0 ( Air Mss System, plausibility: Calculated air masses in the air intake system not plausible) for long time. This is was has been done to the car related or not to the issue: Order: RELATED: DMLT VALVE replaced Purge valve replaced charge pipe replaced with FTP Valve cover and other parts replaced. OEM TMAP/MAP Sensor replaced (intake and charge pipe) MAF sensor cleaned and new gasket installed Superjet pump vacuum hose replaced Air filter box gasket replaced. ------------------------------------------------------------------------------------------------------------------ NOT RELATED: Current Miles: 110.000 Oil filter and gaskets MANN, Oil 5w30 Liquid Moly , air filter MANN , drain plug and gasket - changed every 5k miles. PREMIUM 93-94 octane fuel (Delta, Shell, Sunoco) Brakes pads , rotors and sensor Parking brake actuator Spark Plugs and Coils Oil filter housing gasket and mickey mouse replaced, coolant flush Transfer case fluid changed Differentials fluid changed. Transmission fluid and filter changed. Heater control valve radiator cap steering wheel cap L/R Mirror glasses Right interior temperature sensor HVAC AUC Sensor Exterior and Interior HVAC Filters Parts supplier: FCP EURO (OE/OEM) ------------------------------------------------------------------------- I have been doing some smoke tests and this is what I found and Fixed. Charge pipe leaking: FIXED Maf sensor leaking: FIXED Map Sensor leaking: FIXED Superjet pump vacuum line leaking: FIXED Air box filter gasket leaking: FIXED Valve cover gasket leaking: FIXED Map Sensor leaking: FIXED besides that I can't find more vacuum leaks with my smoke teste, I don't see any smoke coming out anywhere. What else can I do ? Something also weird is that the EVAP Monitor never gets done. Car runs perfect , no issues , no bad idle, not knocking (just some times you can feel a small misfire but the RPM does not go crazy. The light and code triggers when the car is being drive at constantly low RPM (1000rpm-1500rpm) and around speed of 25-35mph. If avoid those situation I won't get the light but I will get the code sometimes as pending. I am tired of this code ---------------------------------------------------------------------------------- Some Live data: Short trim fuel are usually at 0% Long term fuel are usually at -2,3% Short trim sensor 2 is usually at 99.2% O2 b1s1 is usually at : 1.4 - 1.5 O2 b1s2 is usually at : 0.7 Intake manifold pressure after throttle valve: 13.93 psi Intake pipe vacuum before throttle valve (charging pressure - setpoint value) : 14.65 psi Intake pipe vacuum before throttle valve: 14.63 psi Charge air temperature: 115.7 F ------------------------------------------------------------------------------------------- Please let me know what else can I do to diagnostic and fix this code, It is the only code that the car has. Thank you so much! |
05-07-2024, 03:24 PM | #2 |
Rep 147
To me this sounds like you may also have a leak somewhere in the EVAP system coming from the fuel tank. The EVAP system can cause a vacuum leak as it is also plumbed into the intake.
Can you smoke test that? Other possibility is this from a couple of threads on BimmerFest forum: https://www.bimmerfest.com/threads/2...essure.977220/ The last post says this "Remove tank valve connector which is right beneath the airbox, let the car idle for 15min and plug tank valve connector back in. Clear the codes and it should remove the code permanently, works 95% of the time." This post shows what connector that is: https://www.bimmerfest.com/threads/n...stion.1026257/ This thread suggests that this is a procedure to reset the adaptation for this system. Seems worth a try and may fix your code. |
