      04-18-2019, 12:04 AM   #1
Makaveli69
Drives: BMW X5
X5 twin turbo bolt on 3.0d
Are all the M57 engines pretty much the same long engine?
Can i buy a 3.0d say 2008 model long engine and bolt the stuff off an 2008 SD onto it.
      04-20-2019, 10:10 AM   #2
KmanOz
KmanOz's Avatar
Australia
14
Drives: 2008 E70 3.0d
Same block but different compression. Lower compression as more turbos are added.
      04-25-2019, 09:14 PM   #3
Makaveli69
Drives: BMW X5
Thanks mate
      05-06-2019, 11:35 AM   #4
rodnex
Drives: E70 3.0si, E70 3.0d, E70 X5DUS
Hey, you can do the upgrade from single-turbo to bi-turbo from SD.
Many people have done that. Difference in compression ratio is minimal.
single turbo is 17:1 and biturbo is 16,5:1
You'd need to get a biturbo ECU and the vacuum actuators for turbo regulation.
valvecover/ aircleaner/ intakes is different, too.
I was about to do that swap, but then I was too impatient sourcing the spares.
So I just went for a stage 2 hybrid turbo. So I'm running now nearly 400hp on single turbo.
Can't complain
      05-07-2019, 01:08 AM   #5
Makaveli69
Drives: BMW X5
Thanks i was wondering because someone with an X5 sd/35d done a timing chain and got quoted 15k for a 2nd hand twin turbo engine and the single turbo engines are 3-6k, only need the long bare engine.
