03-18-2019, 02:15 PM | #1 |
Rep 291
X5M Cooling System Maintenance
Seems that my expansion tank is leaking. Since it has 100k, I'm looking to do the waterpump, thermostat and turbo cooling hoses.
Has anybody refreshed their X5M's cooling system...anything else to consider? (suppose radiator hoses) |
03-18-2019, 03:44 PM | #2 | |
Rep 1,252
Sorry they're upside down and sideways, not sure what happened there... |
03-18-2019, 08:25 PM | #6 | |
Rep 291
03-18-2019, 08:39 PM | #7 |
Rep 1,252
Right, this is the one I got...
https://www.turnermotorsport.com/p-2...uine-bmw-part/ You can get knockoffs for cheaper, but this one is heavier duty, comes with the new sensor and is genuine BMW. |
IN-FLT12.00 |
04-01-2019, 09:27 AM | #9 | |
Rep 291
It's recommended to replace the waterpump and thermostat around 100k. The turbos coolant hoses where out a lot faster than other hoses because of the heat from the turbos. You might be fine not replacing the lower radiator hose which is almost $100. Though I would replace the upper hose since this is likely the hose that receives hot coolant from the engine. Last edited by philly42; 04-01-2019 at 09:36 AM.. |
04-01-2019, 09:48 AM | #10 |
Rep 291
Parts came in from fcp euro though the waterpump looks damaged (see the bent port). Also the wrong thermostat was sent as it has 4 mounting holes instead of 3. I contacted them and they will be sending a new waterpump and the correct thermostat.
e92BMW///M3123.00 |
04-01-2019, 12:18 PM | #11 |
Rep 357
Drives: E70 X5M
Idk who is picking/packing and verifying orders before they go out at FCP Euro but they need a talking to. I just got an order in a week ago that was missing an item. Customer service was good and they issued a refund but still - seems like it's a regular occurrence.
- 2013 X5 M - Silverstone Metallic w/ Black Perforated Complete Merino - All OEM Options - 12.5mm/20mm Spacers - Velos Stage 2 - xHP Stage 3 - AA Catless - Megan Racing Supremo - PTP Blanket - K&N Drop In -
04-01-2019, 12:36 PM | #12 | |
Rep 1,252
04-01-2019, 07:14 PM | #13 | |
Rep 286
04-02-2019, 01:02 PM | #14 |
Rep 291
The X5M has a recall on the auxiliary pump. The dealer replaced mine last year at no cost.
9vapors648.00 HollywoodsX5M12.00 |
04-02-2019, 03:42 PM | #15 |
Rep 109
04-03-2019, 11:04 AM | #16 | |
Rep 291
SI B11 05 18 https://static.nhtsa.gov/odi/rcl/201...sy2VUwRT-MXSX0 |
9vapors648.00 |
11-13-2019, 11:25 AM | #17 |
Rep 291
Update:
I replaced the expansion tank earlier and did the other components later when I had more time. The lower radiator hose was leaking where the temperature sensor goes. I used the same sensor but replaced the o-ring with an AC o-ring from local autopart store. I pulled the waterpump out with the lower radiator hose attached. It would seem really difficult to replace this hose without removing the waterpump as the space extremely tight. Removing the aux waterpump should help. The plastic impeller on my waterpump seemed fine. Though they’re known to fall apart with age. The new WP from fcp euro had a metal impeller. |
11-13-2019, 11:41 AM | #18 |
Rep 397
Seems these expansion tanks only have a life of 100k mine failed at 117k..
I’d recommend replacing the main line feeding from the tank from the bottom and back to the heater core with the aluminum pipe - mine developed a leak at the connection base and requires removing the intercooler.... which requires completely draining both systems quite a bit of work for just one very expensive hose - $160/from stealer Not sure if others have tried reusing the ends with some new hose? Seems these connections it should work as long as the connection is still good - Would save quite a bit of money considering how many hoses there are and they are all 60-150/each.... probably a 10th of the cost might try it. |
11-13-2019, 03:32 PM | #19 |
Rep 291
Yeah some of these hoses are pricey. I believe the lower radiator hose was $95. I suppose if just the connector needs to be replaced, a replacement connector could be used. Something like this but I haven't found any that were large.
https://www.ecstuning.com/b-genuine-...RoCAPEQAvD_BwE |
11-13-2019, 07:18 PM | #20 |
Rep 2,062
I posted pics on another thread showing what I did to replace the expansion tank, I also converted to Evans waterless coolant and it's been fine for like 3yrs now.
11-13-2019, 07:41 PM | #21 |
Rep 40
11-13-2019, 08:21 PM | #22 |
Rep 2,062
Thanks, I hope yours is doing good as well :-) Mine being good though, ehhh, that's debatable lol.
It sat for a better part of a year while trying to diagnose crippling trans issues, I squirreled since having bought.3 cars and sold 2 in the time the X5M has been down. I finally broke down and bought a trans about 6 months ago and only just got it installed a few weeks ago in anticipation of the snow hitting Seattle again. It's finally driving but I'm now sorting a very random parking brake, traction control, self levelling, etc error that pops up while parked, while driving, etc. She's currently sitting at 126k. The mod bug has bitten again now that I'm driving it so I'm looking to finish what I started by doing the S63TU manifold upgrade along with stock S63TU turbos or something upgraded...I'm still searching.
'10 BMW X5///M - Alpine White on Sakhir Orange - JB4 w/ HCP Stage 2 BEF, NGK 97506 @ .20, SS tubing & BMC filters, gutted cats, AC Forged 312 22's, H&R 2"
'98 BMW 740iL - ///E39 M5 6spd swap, fully built engine (sleeved, P&P, cams), 3.46 LSD, H&R Stage 2/Bilstein HD, Magnaflow 14816's '97 BMW 328ci - ///E36 M3 clutch & L/W flywheel, Z4///M 18's |
