      08-07-2020, 11:49 AM   #1
drummr8
6MT FTMFW
Drives: 11 E90 335xi E91 6MT 12 X5 35i
Hardwire Power for Radar Detector - Front Fusebox?
Has anyone hardwired their radar detector into the front fusebox on the E70? I have it this way on my E90 and I really like it. I utilized an empty fuse slot for a switched power (KL15) and ran the fused power line to the radar detector. Was wondering if anyone knows an empty KL15 spot on the E70 front fuse box.
Thanks
2011 LMB E90 335xi 6MT: Wagner EvoII FMIC, Catless DP, PE Mod, Cobb CP, BMC Filter, ST Coilovers, Strongflex TSB's, Whiteline RSFB Inserts, CDV Delete, Hawk Talon Rotors & PC Pads
2011 SGM E91 328xi 6MT: 3-Stage Intake Manifold, ST coilovers, 335i brake kit, drilled/slotted rotors, CDV Delete, Charcoal Filter Delete
      08-07-2020, 12:47 PM   #2
Lviv777
Drives: f30 330e, C8 Vette
I had a shop do it for me with a dash cam, cost $115, so it should be possible, i don't know where the fuse is however.
      08-07-2020, 12:55 PM   #3
laselvasurf
Drives: 13 X5M/Ford Raptor/19 BMW i3
I used something like this and tapped into the power at the mirror. I can't remember exactly what wires were 12v and ground, but it wasn't too hard to figure out with a multimeter.
https://www.amazon.com/Radar-Mount-D...s%2C247&sr=8-5
2013 X5M
2011 X5 35D Sport Package
2002 M3
2019 i3
Nyc Dito112.50
      08-07-2020, 03:42 PM   #4
Sophisticated Redneck
Drives: 2012 BMW X5 50i
Thanks
I did the same as Lasel and just tapped into the mirror power supply, works excellent. I'll take some pics in the next day or two of the wires I used as I am about to take it apart again to hide the Valentine 1 Bluetooth module in the mirror mount.
      08-07-2020, 04:04 PM   #5
Dawgz
2022 M4 Comp Xdrive
1015
Drives: 2022 M4 Comp Xdrive
Ditto
      08-07-2020, 05:54 PM   #6
Nyc Dito
Nyc Dito's Avatar
113
Drives: BMW X5 35d
Same here, working perfect for more than a year.
E70 LCI 35D
Sutphin trans tune///xDelete///What EGR?
      08-10-2020, 02:36 PM   #7
drummr8
6MT FTMFW
damn, so nobody uses the front fusebox? I like this option because it provides a dedicated spot for it and it's installed with an inline fuse. Also when I tried using one of those backprobe-type setups on my E90 the pins kept falling out because they didn't fit right.
This is what I did in my E90
https://www.ebay.com/itm/UNIDEN-R7-R...D/113864873103
      08-10-2020, 09:10 PM   #8
argento
argento's Avatar
538
Drives: 2013 X5M
FWIW I used the front fusebox for my dashcam install...
https://www.bimmerpost.com/forums/sh...php?p=24282047
