08-03-2019, 05:49 PM | #1 |
Rep 2,737
Hello folks, selling my F86 style M wheel It's a fully loaded wheel with heat and vibro motor in it. Car systems can make a custom map for you for M functions. They made mine run heat and recirculate from the buttons, the module also supports paddles. Cruise control is also supported to the steering wheel and you can remove the stalk if you so wish. The airbag harness has already been adapted to fit to the e70 e71 column clock spring and is basically plug and play. You will need to call carsystems to get a new module harness as each truck is specific and may need different harness depending on options and ECU. Asking $1500 for the whole thing. Over 3k new. Not including module. If local I will install for you. |
