07-29-2017, 02:18 PM | #23 | |
Rep 263
Drives: 2013 E93 M3 Jerez Black, 13 x5
Garage List 2017 GMC 2500HD denali [0.00]
2018 Tesla Model 3P [0.00] 2020 BWM x7 m50i [0.00] 2013 BMW X5 [0.00] 2013 BMW M3 E93 [0.00] |
WAITING If it works I wil do it |
07-30-2017, 03:05 PM | #25 |
Need mo $$s
873
Rep 913
Completed this mod yesterday and I have to say it's much better but not as bright as it could be... especially given my all black interior.
You can definitely tell the LEDs are there now, but they aren't going to affect your night vision in any way The strips are now about 2-3 times brighter than they were. After trying both types in front and rear panels... With the LEDs mentioned earlier in this thread (I went with the 18000mcd/15 degree beam angle as they we noticeably brighter once installed). In the photo comparing the LEDs, the 9000mcd/30 looks brighter, but is not once connected to the clear plastic diffuser in the door. I think the narrower beam angle works better in the diffuser. The LEDs are a perfect color match (about 605nm) for the orange LEDs in the instrumentation and through out the interior. These photos are looking up at the front (OEM/new) and rear (OEM/new) in similar lighting conditions (about 75% dark). There isn't enough light showing on the doors for my iPhone to capture it on the doors themselves, but your eyes can now see it, especially at the front of the openings, where you would be most likely to see it when seated. If you were to change the LEDs to another color like white or red, there are much brighter LEDs out there BTW in other colors (you need a forward voltage of about 2V and current of around 20mA) then you may see a much more drastic change. Thanks, John
2020 TRM-BLACK X4///M Competition
2020 Porsche Macan 1995 Dodge Stealth TwinTurbo Past: 2020 X3M, 2019 TTS, 2008 X5 4.8 M Sport |
07-30-2017, 06:09 PM | #26 |
Rep 398
Very nice, thanks for the updates and info! Stupid question, do you need to take the door card off to remove these light assemblies?
'17 Porsche C4S Sapphire Blue Metallic / Bordeaux Red - Softronic tune - Soul Sport Cats - Soul Exhaust
'13 E70 X5M Black Sapphire Metallic / Bamboo Beige - Full Dinan Suspension - Dinan Exhaust - BPM Sport Tune - xHP Flashtool Transmission Tune |
07-30-2017, 07:15 PM | #27 |
Need mo $$s
873
Rep 913
Yes, you do have to take the door panels off.
But, it's only removing a few screws then using a trim tool to pop the first couple of clips lose. Then just unhook the wiring... There are a few videos/DIYs floating around on how to do this, but trust me when I say it's VERY easy and only takes a few minutes for each one. Here's one that I have used (only need to watch the first 2 minutes): https://www.youtube.com/watch?v=cmsmyIBnznk For the driver's door the process is the same, except you just pop up the switch panel and remove the 2 torx screws under it. BMW did a very good job on this aspect of our X5s, so don't sweat it, as it's really no problem at all. I did all 4 of mine in about 90 minutes, including the modification to the LEDs. Thanks, John
Lunker32594.00 |
07-31-2017, 08:24 AM | #28 |
Rep 263
Thanks for the write up. Will try this!
07-31-2017, 08:46 AM | #29 |
Rep 263
Are u happy with 18000mcd? Or would u go higher?
07-31-2017, 04:42 PM | #30 |
Need mo $$s
873
Rep 913
I'd go higher with a narrow beam angle if I could find them.
Can just change the resistor if more current/voltage is needed.
2020 Porsche Macan 1995 Dodge Stealth TwinTurbo Past: 2020 X3M, 2019 TTS, 2008 X5 4.8 M Sport Last edited by 95wildtt; 07-31-2017 at 04:48 PM.. |
07-31-2017, 07:14 PM | #31 |
Rep 263
08-01-2017, 06:41 AM | #32 | |
Need mo $$s
873
Rep 913
They would be VERY bright, but they are 2x the diameter, so they won't fit in the holes of the "holders". I don't believe there would be any way to make the holes in the "holders" big enough to make these fit (see photo earlier in the thread), there just isn't enough space... Sorry.
08-01-2017, 08:41 AM | #33 | |
Rep 263
i wonder what a blue or green ambient light would look like in the background of the amber instrument lights. |
08-01-2017, 10:00 AM | #34 | |
Need mo $$s
873
Rep 913
Be careful with the color, Amber is not Orange. Amber is what is used for turn signals and is more yellow than Orange... You really want something very close to the 605nm color or it won't be orange. Here is a color chart:
08-14-2017, 06:45 PM | #35 |
Rep 263
https://www.superbrightleds.com/more...gle/4048/8762/
I'm thinking about adding these. What do you think? should I change the resistor as well? |
08-14-2017, 10:41 PM | #36 | |
Need mo $$s
873
Rep 913
You wouldn't have to, but the change would make them a bit brighter. Might try both and see what you think. Resistors are cheap! John
2020 Porsche Macan 1995 Dodge Stealth TwinTurbo Past: 2020 X3M, 2019 TTS, 2008 X5 4.8 M Sport Last edited by 95wildtt; 08-15-2017 at 07:45 AM.. |
08-28-2017, 07:12 PM | #37 |
Rep 263
Ok. I finally got the fronts installed. It was pretty quick, once you figure out how to pop the panels off. I only took off the screws at the bottom of the doors and just pulled the wire harness out. It didn't require taking the whole panel off.
It is so much brighter than the stock. I used these: https://www.superbrightleds.com/more...gle/4048/8762/ kept the resistor and just cut off the OEM light. Soldered the new ones. It was actually a very quick modification. The pictures don't do justice as it was a phone camera. It is bright enough to see your foot while sitting but not intrusive at all. I like it alot. |
08-29-2017, 09:58 AM | #38 |
Corporate Thug
Rep 76
Awesome! I'm considering doing this mod as well. Only thing is that the amber LED option is only half has bright as the green.
08-29-2017, 10:49 AM | #39 |
Rep 263
08-29-2017, 11:27 AM | #40 |
Corporate Thug
Rep 76
Searched, but only color option with a equiveant output/intensity to Green is Aqua. So the Amber color at 18000mcd is the best option to remain with a OEM look (my goal) and Orange at only 4000mcd output is just plain no bueno.
QQ: Did you order the 63316971823 with the black case/housing or only the bulbs from superbrightled.com and reused the existing black case/housing to complete the project? B/c at only $0.24 per LED bulb this sounds super cheap and super easy w/o ordering the 63316971823 . Thanks for answering. |
08-29-2017, 12:40 PM | #41 | |
Rep 263
2slick4u5.00 |
01-31-2018, 11:30 PM | #42 |
Need mo $$s
873
Rep 913
Update:
Changed out a buddies Orange LEDs for Cool White (6000k) and they really show up at night. So this may be an option if you want to brighten the storage compartments and actually make them useful. You could use an LED something like this (18000 mcd): https://www.superbrightleds.com/more...-mcd/256/1183/ Be sure to change the resistor from what is in the module to at least a 330Ohm and a larger 1/4 W or you will "fry" either the LED of the resistor, or both. Just an FYI, John
02-03-2018, 08:30 PM | #43 |
Rep 10
Good to know you can swap out that little bulb! I gave up on that and decided to try some El Wire in the door trim. I think I'm pretty happy with the way it turned out. I know I'd seen some people do it to the 3 series so I figured I'd give it a try. I tapped right into the wires that feed the door pocket lights. It doesn't give off quite 12V of power so it's not as bright as it could be, but it looks quite nice IMO.
The only downside is that the little wire strips that light up are actually orange even when off. Some people may like that look (I guess it looks kind of sporty), but the jury's still out for me. I think it'll have to grow on me. However I'm absolutely in love with the look at night. One option to avoid the orange strips being orange during the day (or when off) would be to go with white instead. The white is clear when off so you wouldn't really see or notice it, but the orange matches the interior lights almost exactly so I don't know. I may get some white and just see what they look like. The good thing is once you have them wired all you have to do if you ever wanted to change colors is just take the window switch out (that's where I have them coming into the door from) and then there's a little plug on the wire you just unplug and can easily switch them out without ever having to do any re-wiring. |
02-04-2018, 01:11 PM | #44 |
Rep 2,062
Can you share a link to the EL wire you used and pics of how it looks in the daytime? Did you just tuck this between the door card and power window switch, meaning it's just being held there by tension?
