08-18-2020, 02:19 PM | #243 | |
2022 M4 Comp Xdrive
1023
Rep 1,538
What was your oil change interval? Tuned? |
10-28-2020, 09:38 PM | #244 | |
Rep 385
Drives: '23 AMG GLE53, '10 X6M
oil pump failure
I second this. On my 2010 X6M that grenaded at 85k, when i dropped the oil pan, the oil pump almost fell out at him me in the head. It was broken off from the sprocket and obviously separated from the chain. I still have it, I have to snap some photos.
'10 X6M
'08 Cooper S |
10-28-2020, 10:00 PM | #245 |
Rep 385
my 2010 x6m had 85k when grenaded and I had the VAC Motorsports bypass tune. 2 boxes and some cables that went in between the stock harness.
'10 X6M
'08 Cooper S |
10-28-2020, 10:07 PM | #246 |
Rep 2,062
11-05-2020, 11:04 PM | #247 |
Rep 385
5w30 and 10k miles. obv from reading on the forums thats still too long, should have been 5k oil changes. i picked up another s63....its a 11 x5m's s63 with approx 100k on the clock. working on the tear down now and replacing everything i can (main bearings, rod bearings) and inspecting everything.
11-07-2020, 07:21 AM | #248 |
Rep 486
11-15-2020, 09:18 PM | #249 | |
Rep 264
11-17-2020, 12:07 AM | #252 |
Rep 264
11-17-2020, 07:36 PM | #253 |
2022 M4 Comp Xdrive
1023
Rep 1,538
what i do is get a very short metal rod (like a Mini metal pick) and put it in the loop of the plastic pull out handle and then i grab each end of the metal pick with one hand and pull up, that will give you more leverage than pulling the tab with just one finger.
11-21-2020, 01:18 AM | #254 |
Rep 264
Tried that. Still no go!! What the hell is going on!?
11-21-2020, 05:47 AM | #255 |
Rep 780
That's quite a bit of savings right there my man. Have you changed the other fluids like differential/brake/transmission etc yet?.. My guess would be, why, right?
11-21-2020, 08:39 AM | #256 |
2022 M4 Comp Xdrive
1023
Rep 1,538
11-21-2020, 02:02 PM | #257 |
Rep 1,146
Drives: F10 550i
Garage List 2020 BMW M340i [0.00]
2019 RAM 3500 [0.00] 2020 BMW X3 [0.00] 2016 BMW 550i [0.00] 2000 Ford F450 7.3l ... [0.00] |
The plastic can melt a bit on the top of the coil pack. Wiggle it back and forth a bit, and I stuck a flat blade screw driver through the pull tab and pulled with both hands. It wont break, it can just be tough to get out.
11-22-2020, 03:02 AM | #258 |
Rep 264
OK, I'll try yet again. I'm praying that's the cause of the misfire!?
11-22-2020, 03:05 AM | #259 |
Rep 264
Yeah, why?!? oh why! Well, the little old lady who owned it before, ok it was a young lady, as there is still a child seat indent in the back seat, LOL. She drove like 10 mph everywhere she went, so I think it's in like new shape as far as the wear on motor and trans is concerned. But, It's probably time to change trans fluid, I guess. I mean the reason why not to change the oil, is that it would go through a liter a week, so after about 8 weeks, it had an oil change anyways. hehe.
11-25-2020, 05:55 PM | #261 | |
Rep 2,062
It's by no means perfect, it's down on boost (I blame VERY tired turbos), but it runs like a top. Just ritual oil changes and lots of road trips, I haven't dropped the pan or done anything engine wise major. What's funny is I'm NOT nice to this car. I remember my E34 M5 days and read that they like their legs stretched out, so I apply that same technique daily...engine's up to temp and it's game on, EVERY day is a race...stop lights, passing people, dude who maybe looked at funny so I assumed he wanted to race, etc :-) I HATE how it constantly wants to go into 6th, even at the lowest of speeds, so I'm always in Sport and/or ///M mode to keep the revs up vs down low and bogging. Engines in heavy cars don't like low RPM lugging around so I've convinced myself that's why I haven't had the problems I've read about. Mods: - custom intake - JB4 with meth - HCP stage 2+ flash - DV+ diverter valves - muffler valves deleted - catch can Done: - Aux water pump - broke into pieces - CCV/PCV system - usual cracking - Injectors - one failed - Expansion tank - cracked and I now run Evans waterless coolant - Vacuum pump - leaked oil - Front brakes - worn out - Transmission -constantly went into limp mode, slammed itself into 3rd on the freeway and/or wouldn't drive at all even after two flushes/sleeves/gaskets changes a few months apart - Alternator brushes - hoping it'd fix the Christmas tree dash that still happens post trans swap but thankfully still drives this time around - Vacuum lines - still can't get rid of reduced power warnings though To-do: - Transfer case, maybe - still getting the Christmas tree randomly even though it's for new fluids and the servo gear is perfect - S63TU mani and turbos - hoping it'll fix my reduced power and smoke after idling for long periods before I explore valve seals, at which point I'll just go fully rebuilt |
TTV8M126.00 |
11-25-2020, 06:22 PM | #262 | |
2022 M4 Comp Xdrive
1023
Rep 1,538
You may want to look into the xHP trans flash. I made a comment in the xHP thread that the trans flage (stage 3) will likely save your bearings as it stops the TCU from hunting down 6th gear at all speeds. it also allows you to get into 5th much easier if you're in 6th and apply a little throttle as opposed to the stock TCU map that will do everything possible before down shifting. |
TTV8M126.00 |
11-25-2020, 08:15 PM | #263 |
Rep 2,062
I've thought about it because honestly ///M and Sport mode are almost too much to the point where I end up manually shifting just because sometimes it'll go into 1st just coming off the freeway when still doing like 20+/- mph and about to accelerate outta the turn.
