      04-24-2014, 08:58 PM   #1
buster84
Drives: 2009 335I X-Drive E90
Tow Hitch
I've seen so many different types of tow hitches online, does it matter what type of hitch they are other than the rating being for 6000+ lbs.
Is there any reason for me to not go with the oem bmw one? or any reason on why its preferred to go with the oem one? What aftermarket ones would you recommend?
Also would the X5 be able to tow my 2009 e93 335i with a uhaul trailer or is that to much weight? I haven't decided if my friend is driving the other car yet or if its easier for me to tow it.
2015 BMW M4 F83
2009 335i X-Drive | GC 2.0 Turbos (sold)
2009 335i e93 (Sold)
2007 Bmw X5 (Sold)
      04-25-2014, 05:34 PM   #2
boom
My X5d tows my spec miata to the track.
Drives: 2010 X5 35d
I got a Curt hitch from an online store for $159. IIRC it was called Hitch Anything. Google it. I bought the OEM barnes for like $188. Installed it myself. The Curt sits lower and you don't have to cut the bumper as much. It's a pretty significant difference. it does not have a mount for the trailer connector. I tuck mine up in the hitch and it stays put very well. I just pull it down when I tow.
      04-25-2014, 05:42 PM   #3
buster84
So the oem one requires the bumper to be cut? Do you happen to have any pictures of your setup?
2015 BMW M4 F83
2007 Bmw X5 (Sold)
      04-25-2014, 06:50 PM   #4
mitch808
Drives: 2012 X5 35i
The max for your X5 is 6000lbs. The 335 is probably no more than 3500, plus the trailer.
The UHaul Auto Transporter is 2200 lbs, so very close to the 6000lb limit.
There are also 2wheel dollies as well, if you feel like removing your driveshaft and lift by the front tires.
I know for the suburban I've owned and just about any other domestic tow vehicle I've worked on, I ALWAYS install a Trans cooler, even if not towing. Heat kills a trans, real fast. A Trans cooler can bring down temps anywhere from 20-50deg, which in a craptastic 4L60e, can mean life or death for that thing.
Not sure if the X5 has anything like that. But if towing a lot or a long distance, I'd highly recommend it.
So that said, get the max tow rating you can find (e.g. 6000lbs), a high tongue weight rating, and the appropriate ball and always buy a lock, and the wiring harness to integrate your brake/driving lights. Oh, if in a hilly area, inspect your brakes and/or replace with a higher performing heavy duty pad.
      04-26-2014, 11:36 AM   #5
gan23
Drives: X5M '18 XM’23 X5 50e 24
Here's a link to a tow hitch setting.
http://www.bmwblog.com/2010/11/08/ph...-2010-bmw-x5m/
I've included a picture of mine with the cut bumper.
gan23
      04-26-2014, 12:19 PM   #6
buster84
Good info thanks! When you say wiring harness does that control the brakes of the Hitch too? according to this my convertible is 4,000lbs so that might be cutting the limit on the tow... I guess i'll have to most likely end up driving the car then since i was planning to tow it from CA to FL and thats a 3,500 mile drive...
gan23
That looks good, I don't have that bumper though... is that aftermarket? The tow hitch looks like it belongs there lol.
2015 BMW M4 F83
2007 Bmw X5 (Sold)
      04-27-2014, 07:30 AM   #7
boom
Drives: 2010 X5 35d
The bumper has to be cut to fit the OEM hitch. Here's a pic:
This is what a Curt hitch looks like:
      04-27-2014, 10:08 AM   #8
rennis
rennis's Avatar
43
Drives: E70 5.0 & B5 S4
Get the Curt. Ridiculous to me that the oem requires cutting the bumper!
Towing a car and trailer should be fine, just watch that tongue weight. No more than 600 pounds.
      04-27-2014, 10:26 AM   #9
BimmerE82
BimmerE82's Avatar
Drives: 2009 BMW 135i Sport package
2009 BMW 135i  [7.00]
Looks like the Curt hitch is the one to get. Thanks for posting photos, Ive been thinking about a Jetski purchase and was wondering how I was going to tow it.
      04-27-2014, 11:41 AM   #10
Tailwinds
Drives: X6m
I just had the Invisihitch installed since I don't use a hitch often and wanted to retain the stock look with no cutouts. Seems to be a top notch hitch and comes with OEM wiring. Car is being delivered so I have no reports on using it yet but Daryl at Invishitch had sent me good pics of the system before I ordered it. dsavell@invisihitch.com is his email.
      04-27-2014, 11:49 AM   #11
hd2000fxdl
Drives: 2011 X5
Interested in seeing pics of the install and any other info when you get it if you could be so kind.
Harry
      04-27-2014, 07:27 PM   #12
boom
Drives: 2010 X5 35d
THat's a really nice setup but you're paying for it. My quote for the kit was in excess of $1K. All said and done I was towing my race car for less than $375.
      04-27-2014, 08:09 PM   #13
buster84
Dam that's expensive! for a tow hitch.
This looks like a nice one
I forgot to ask, does this 6k limit include weight in the x5 it's self or just the weight of whats being pulled? If i stuff the car with box's and 2 people this would go over 6k easily towing a car which now makes me wonder if its just the max towing weight or total weight that the car is capable of pulling? I've never towed or owned a car capable of it till now so this is all new to me.
One last question. Uhaul has a tow hitch that they install on the car for a total of $544 installed. Seems like a pretty good deal, has anyone bought one of these? Is the wiring that they include the same as oem? How much is the oem one to get installed?
It comes with
Round Tube Rec. (Powder Coat) (max 6000lbs) $219.95
Ball mount for 2" receivers. 2-1/4" drop with 7-1/2" length. $19.95
2" ball x 1" shank. Shank Length 2-3/16". $10.95
Class III Pin & Clip $1.69
Pulse Width Modulation System Stop/Tail ST $79.99
Hitch Install $110
Wiring Install $60
Warranty $15
2015 BMW M4 F83
2007 Bmw X5 (Sold)
      04-27-2014, 08:37 PM   #14
sburke91
Drives: 2011 X5 50i
It comes with
Hitch Install $110
Wiring Install $60
Warranty $15
Having watched a U-haul tech attempt to 'troubleshoot' what ended up being a ground issue on their trailer by breaking the water seal on the light plug on my old Tundra, I don't think I'd trust a U-haul tech anywhere near the electrical system on an X5.
Is it really worth the few hundred dollar savings on a 50k-80k vehicle?
      04-27-2014, 08:54 PM   #15
denaliman
denaliman's Avatar
Drives: 2021 BMW X6M Competition
2013 X6M  [0.00]
This is my execuihitch on X6M.
_____________________________________
2021 X6M Competition, 2021 Audi SQ5 Technik, 2013 Audi S4
      04-27-2014, 08:58 PM   #16
denaliman
denaliman's Avatar
2013 X6M  [0.00]
more pics.
      04-28-2014, 07:00 AM   #17
BimmerE82
BimmerE82's Avatar
Nice set up above!!! Did I say Jet ski??? I meant SeaDoo......Thanks for the photos.
      04-28-2014, 08:57 AM   #18
jiggz
Drives: E90 M3|F15 X5 50i
^ agreed - does anybody here have an X5 with the Execuihitch?
I don't like the idea of cutting the bumper (OEM) but the Curt hitch pictured above looks silly IMO sitting below the bumper like that.
      04-28-2014, 09:09 AM   #19
Tailwinds
Drives: X6m
Execuhitch and Invisihitch are the same company now I think and the pics above would be the same. There are other threads on this which show more pics too. Yes it costs more than others.
      04-28-2014, 10:46 AM   #20
PAX5
Drives: 2012 X5 50i
... Uhaul has a tow hitch that they install on the car for a total of $544 installed. Seems like a pretty good deal, has anyone bought one of these? Is the wiring that they include the same as oem? How much is the oem one to get installed?
Installing the trailer hitch hardware is NOT trivial!! It requires removing the rear bumper valance (all plastic). Unless done correctly, carefully and with a lot of patience, it is extremely easy to crack, distort or break the various plastic components. The "tab and click" system BMW uses in their design is pretty fragile ...
Once the bumper skirt and the components are off, installing the hardware is straightforward.
The fun part comes when you try to hook up the wiring harness ... the car computer has to be coded with proprietary software in order for the trailer lights and rear view camera to work properly ... GL.
PAX5
BMWCCA 20645
      04-28-2014, 11:17 AM   #21
buster84
Coding is the simple part for me as long as it's the same as it was on my 335 lol. I found a few oem hitch's online I maybe just order. At this point I've decided to drive the car but plan to get a hitch anyways since I want to buy a boat down the road. So thanks again everyone for the help and pics. Feel free to expand on this thread for anyone else looking for pics or help
2015 BMW M4 F83
2007 Bmw X5 (Sold)
      04-28-2014, 11:35 AM   #22
rennis
rennis's Avatar
43
I went with the Curt because tow hitches look dumb on cars but look great on trucks and SUVs.
(I also do not like the length of the stinger on the Execuhitch - I like a short hitch and ball to keep the tongue weight right underneath the points supporting the weight, especially on a uniframe SUV. The Curt allows you to do that.)
I also highly, highly recommend getting a silent pin for pinning the hitch to the receiver for anyone who tows - locking that up reduces all the audible clunking you otherwise getting when accelerating and braking, which gets really annoying and unsettling in an SUV, if you're used to towing with a truck.
Overall been very happy with the Curt, feel it's the best overall design for function and price/quality.
