      04-15-2014, 11:06 PM   #1
mik
mik's Avatar
Drives: x5 48i Msport
wierd seat problem?
whats up fellas. im not too active on the forums, mainly lurk, but ive run into a problem and hope someone can help me out. 09 e70 with comfort seats. the part labeled 3 in this diagram has all of a sudden stopped moving on both front seats. when i press the control for that section to move in or out i can hear the motor running, but that section of the seat is not moving. seems super wierd that both the driver and passenger side are doing it and even more wierd that it sounds like its working... any help is appreciated
      04-16-2014, 06:43 AM   #2
zoex5m
Drives: x5m
Bump I would like to know as well.
      04-21-2014, 10:08 AM   #3
n_sievers
Drives: 2012 X6M Monte Carlo Blue
2012 X6M  [0.00]
This must be an issue with the comfort seats as both driver and passenger thigh support motors were replaced in my X6 prior to my ownership and then I had the driver's side replaced again since it had suddenly gotten very loud and was not operating smoothly.
      04-30-2015, 10:19 PM   #4
mik
mik's Avatar
Bump
      04-30-2015, 10:56 PM   #5
windtendo
windtendo's Avatar
1716
Drives: 2023 M5C
2023 BMW M5C  [0.00]
1989 BMW M3  [0.00]
I had mine at the dealership for this exact problem on the passenger side. They tried several different approaches and then finally decided to just replace the thigh extension. Now it's working like it should.
      05-01-2015, 10:46 AM   #6
n_sievers
2012 X6M  [0.00]
My 09 X6 went though several motors/mechanisms (2 driver side and 1 passenger side) luckily all were replaced under warranty.
      05-02-2015, 06:19 PM   #7
joe_planet
Drives: 2011 X5d
Those motor gears strip out and must be replaced. Happened on my passenger side. Seems like a common problem. I bet they use plastic gears. Idiots
      05-04-2015, 09:11 PM   #8
mik
mik's Avatar
Thanks for all the responses fellas. Its one of the things I never used but still bothers me that it doesn't work....
      05-04-2015, 10:08 PM   #9
blown_m3
The Beast
blown_m3's Avatar
Drives: X5M
The motor is out. Need to replace to entire assembly which comes with the motor and cables for the thigh extender.
      05-05-2015, 05:46 AM   #10
mik
mik's Avatar
If the motor is out why can I hear it running? Seems like its off track or something
      05-05-2015, 02:29 PM   #11
blown_m3
The Beast
blown_m3's Avatar
Drives: X5M
You will hear it running. It is a single assembly which needs to be replaced. $320 for the parts and $82 for labor.
      05-07-2015, 10:04 AM   #12
mik
mik's Avatar
Wow thanks for the info. I've read about this on a 5 series thread. Seems like 50/50 chance covered by CPO...
      05-08-2015, 07:53 PM   #13
blown_m3
The Beast
blown_m3's Avatar
Drives: X5M
You are welcome!
