      04-14-2014, 03:22 PM   #1
shanealbrandt
Drives: 2010 X6M
2010 X6M Bluetooth Streaming?
Hi All - me again.
Does anyone have any experience getting Bluetooth to stream music? I have the integrated Bluetooth for my phone calls, but I'd really like to stream music via Bluetooth as well.
I read online about the Combox - but that is $1,000. I'm hoping for a much less expensive option?
Thoughts?
      04-14-2014, 03:47 PM   #2
JX5M
JX5M's Avatar
Drives: 2012 X5M
How do you stream music through the combox if you have that option? I believe I have it and would like to give that a try.
      04-16-2014, 03:18 PM   #3
shanealbrandt
Drives: 2010 X6M
I'm not sure because I don't have it. I was hoping to find a way to stream without needing to spend all of that money. You would think on a $90K+ car - it would come with it!
      04-17-2014, 09:49 AM   #4
Sa3064
Drives: X6m
The 2010 X6M has no streaming capabilities unless you spend that $1000+. Real bummer.
I just use the plug and let the iPhone sit on the arm rest. It's a real disappointment.
      04-17-2014, 12:03 PM   #5
isugoo
isugoo's Avatar
Drives: F80 ZCP
My friend had 2008 M3 which of course, didn't have bluetooth steaming.
But he had aftermarket thing attached on the USB and streamed music.
So I think there are some inexpensive (~$100) option for bluetooth streaming via USB.
Maybe check out Crutchfield website?
PAST: 911 P2S | F10 M5 ZCP | E70 X5M | E90 M3 | E92 335i | E46 M3 | E36 M3
      04-17-2014, 11:43 PM   #6
igorbmwx6
igorbmwx6's Avatar
Drives: 2011 BMW X6M 5.0 xDrive
Send a message via Skype™ to igorbmwx6
Combox media is under $300 option. You can code it yourself and save $700. You will need to remove TCU and MULF modules and replace then with one Combox-media module. Then do a little coding to let your X6M know that there has been change made to your hardware. It is a very simple DIY retrofit
      04-18-2014, 08:10 AM   #7
skforzagroup
skforzagroup's Avatar
Drives: Audi R8
i have it, 2012 tech package i think amazing option
2013 X5M Blue on White Leather
Mods: Miestershaft Remote GTC | ETG Tuned & AR DP |
2011 SLS Gullwing
Mods: H&R Springs | ETG TUNE | Miestershaft exhaust GTC| SKF Carbon Fiber Wheels
      04-20-2014, 10:35 AM   #8
shanealbrandt
Drives: 2010 X6M
Re: 2010 X6M Bluetooth Streaming?
Where can I find the combox for that price, and can you help me get it coded? Are there instructions on how to install it and how to remove the other things you mentioned? I have zero clue what I'm doing here. lol
-S
      04-20-2014, 10:17 PM   #9
igorbmwx6
igorbmwx6's Avatar
-S
Here is one I found for sale on eBay $340.
http://www.ebay.com/itm/BMW-CiC-Comb...72b621&vxp=mtr
The rest is coding. Here are the steps: remove TCU and MULF from your Vehicle Order. Add Combox to the vehicle order. Recode: CIC, Combox and Kombi modules. You will also need a new harness for your Combox, since wires are not all in the same location as those for TCU.
File Type: pdf Combox Installation Instruction for Exx Series BMW.pdf (1.25 MB, 280 views)
      04-23-2014, 11:25 PM   #10
Toneaero
Drives: X5M
Is this $340 combox the same one bimmertech is selling for $663?
      04-24-2014, 01:21 AM   #11
igorbmwx6
igorbmwx6's Avatar
Identical unit
      04-24-2014, 01:31 AM   #12
Toneaero
Drives: X5M
Identical unit
Pardon my newbieness but what else is needed for Pandora to stream to my 2010? I have Bluetooth for phone calls, just no music.
Besides combox for $340 via ebay, do I need any of the following from bimmertech's website? What is a 6NR and do I need it?
      04-24-2014, 11:58 AM   #13
upstate650
upstate650's Avatar
Drives: 2014 650xi Gran Coupe Msport
Identical unit
Yes, on a 2010 I believe you need the combox plus the 6nr, plus harnesses and other accessories that will get you up over a grand real quick. And that is before install.
Your best bet is to call bimmertech and get a quote for everything you need. They will tell you what is required.
2014 BMW 650xi Gran Coupe Msport Black Sapphire Metallic on full black merino leather. 20" M5 343M wheels for summer, 20" 373 wheels for winter with Nokian Hakkapeliitta 8 studded snow tires. M6 CP exhaust with M6 Diffuser and ///M Performance carbon fiber finisher. Mission Performance stage 1.5 and transmission tune.
      04-24-2014, 09:14 PM   #14
DFR
Drives: Evo IX MR/X5d w/Adaptive Drive
Or you can just purchase this:
http://www.amazon.com/ViseeO-WMA1000.../dp/B00B52LLJ6
And stream everything from your phone in your pocket and control the music via the steering controls and view what's playing on your screen. Total cost:$100
      04-24-2014, 09:25 PM   #15
Draper
Draper's Avatar
Drives: '16 M3 ZCP
That actually looks pretty interesting.
Have you tried it yourself? Any issues with sound quality?
F80 M3 ZCP // Sakhir Orange // 6MT
Gone: E70 X5 50i // Space Gray // M Sport
Gone: E90 M3 // Jerez Black // 6MT
      04-26-2014, 09:48 AM   #16
Sa3064
Drives: X6m
Yes, please tell us if it works well. Presumably it should be the same sound quality as any conventional Bluetooth connection. Great find!
      04-26-2014, 08:38 PM   #17
DFR
I have it in both my X5 and 335 and it works great! Cheapest and best alternative. Just make sure you have the BMW OEM USB/audio cable. Should be able to find it on eBay for fairly cheap.
      04-26-2014, 09:00 PM   #18
Draper
Draper's Avatar
Drives: '16 M3 ZCP
Nice. I already have the USB cable as I have been using with an iPod, but would be nice to use Bluetooth to stream Pandora from my iPhone.
Thanks again for the tip!
      04-27-2014, 02:00 AM   #19
wcs5678
x6
Is it compatible with iPhone 5s? Saw reviews the viseeo tune2air is compatible up to iPhone 5 only. Also would the iPhone work normally like answer calls and dialing calls while it is streaming from the same iPhone. I thought bluetooth can only connect to one thing only?
      04-27-2014, 01:50 PM   #20
motex
2016 X5 30d
motex's Avatar
Costa Rica
217
Drives: 2016 MW/F15 30d
Did you buy the WMA2000 which seems to be the one for BMW's ?
What type of phone are you using?
I'm almost ready to buy one....
      04-29-2014, 12:49 AM   #21
DFR
I bought the wma1000 and I'm using the iPhone 5s.
      04-29-2014, 12:51 AM   #22
DFR
Yes it works with the iPhone 5s and yes the iPhone will still work normally like answering calls and dialing while streaming. Basically if you are streaming pandora and you get a call, obviously the call takes priority, will show up on your display and then you can answer or hang up. If you hang up, then streaming resumes.
