      03-20-2014, 12:06 AM   #1
igorbmwx6
igorbmwx6's Avatar
Drives: 2011 BMW X6M 5.0 xDrive
Send a message via Skype™ to igorbmwx6
Replacing front rotors and pads on X6M
Planning to replace both front rotors and brake pads this weekend (DIY) on my X6M. Can someone please point to a diagram on how to disassemble X6M calipers and rotors. I have replaced X5 and X6 brakes many times, very simple and straight forward procedure. However, my front X6M calipers and pads look completely different from X5 and X6 once. Any help or link to a DIY would be greatly appreciated
      03-20-2014, 09:08 AM   #2
JX5M
JX5M's Avatar
Drives: 2012 X5M
What are you putting on OEM parts or aftermarket?
      03-20-2014, 02:13 PM   #3
igorbmwx6
igorbmwx6's Avatar
Genuine BMW original oem rotors and pads: 34116799964, 34116789069 (left rotor), 34116789070 (right rotor). I already learned a lesson once before, will never use any aftermarket components on my BMW
      03-21-2014, 09:32 PM   #4
igorbmwx6
igorbmwx6's Avatar
Anyone knows how to remove the two guiding pins from brake caliper in order to swap out old pads with new ???
      03-21-2014, 09:49 PM   #5
denaliman
denaliman's Avatar
Drives: 2013 BMW X6M
2013 X6M  [0.00]
I haven't done the X6M, but on my e70 remove the dust cap on the bolt and use a 7mm hex socket to loosen counterclockwise. Might have to give it a shot of penetrating oil to free up the bolt. Don't forget to compress the pistons before removing the guide pin.
_______________________
2013 BMW X6M-current
2013 Audi A4 S-Line-current
2007 BMW X5 4.81-sold
      03-21-2014, 09:52 PM   #6
igorbmwx6
igorbmwx6's Avatar
Thank you, denaliman. I have also done it many times on X5 and also on X6. X6M front brake calipers are Brembo and they are completely different from X5 and X6 front brake calipers. There are two guiding pins that I just have no idea how to remove. They must be removed in order to swap out old pads with new, but how ???
      03-21-2014, 10:05 PM   #7
denaliman
denaliman's Avatar
2013 X6M  [0.00]
I think you have to tap the pins out with a nail punch or the like. I know on my wife's Audi the brembo's were like that.
Maybe this for reference:
http://www.audiworld.com/tech/wheel23.shtml
      03-21-2014, 10:08 PM   #8
denaliman
denaliman's Avatar
2013 X6M  [0.00]
Here's a link
      03-21-2014, 10:12 PM   #9
igorbmwx6
igorbmwx6's Avatar
Thank you for the reply; however, that's not going to help much. In this DIY instructions and pictures, showing cotter pins holding the guiding pins in place. On Brembo M4.42 BMW brake calipers there are no cotter pins holding anything. Usually I an good at reverse engineering things, but this one is just a mystery. BMW have really worked on this one, so that you cannot DIY
      03-21-2014, 10:17 PM   #10
igorbmwx6
igorbmwx6's Avatar
Here's a link
Something is holding those guiding pins in place. I am just afraid that if I start hammering on them, something will break. What a mess ...
      03-21-2014, 10:32 PM   #11
denaliman
denaliman's Avatar
2013 X6M  [0.00]
I think there is a pressure spring/clip holding them in place by tension.
http://www.realoem.com/bmw/showparts...35&hg=34&fg=05
      03-21-2014, 10:53 PM   #12
Rob NY
Drives: X5M 550xi
I removed those pins on my car (X5M) and they come off just like in that video. It's not that difficult.
      03-22-2014, 12:20 AM   #13
igorbmwx6
igorbmwx6's Avatar
I will try to just knock them out with hammer. Interesting thing is that end of the guide pin which needs to be hammered on is a sharp point, rather than a flat surface. This is what threw me off
      03-22-2014, 12:22 AM   #14
igorbmwx6
igorbmwx6's Avatar
I tried to remove the clip to free up both of the guide pins and they are still not moving out freely. I will try to hammer them out tomorrow. Thank you very much for all your feedback, links and video. Greatly appreciated. I tried to Google X5M and X6M front brake calipers and all I could find was for sale
      03-23-2014, 01:06 AM   #15
igorbmwx6
igorbmwx6's Avatar
Got my front brake pads and rotors replaced on my X6M (Brembo). Thank you all for your replies. As was suggested, I tapped on the guiding pin from one end with hammer and it came right our of the caliper. The rest was self explanatory ...
      03-23-2014, 10:24 AM   #16
denaliman
denaliman's Avatar
2013 X6M  [0.00]
Good to hear. Perhaps you could put together a short DIY for the rest to follow.
      03-23-2014, 02:19 PM   #17
motex
2016 X5 30d
motex's Avatar
Costa Rica
222
Drives: 2016 MW/F15 30d
+ 1
