      04-14-2015, 05:57 AM   #89
Bklynjoker
Bklynjoker's Avatar
85
Drives: G20 %E2%80%9C22%E2%80%9D MSpor
When installing look thru the smaller eye and make sure the H8 is positioned correct upside down "T" locking the bulb. You can see the hole where the LED needs to be to light up outter ring
      04-14-2015, 09:19 AM   #90
jplatt83
Drives: BMW 2011 x5 35d
Are you saying you can tell its not in there properly?
      04-14-2015, 11:07 AM   #91
LuxAngelEyes
LuxAngelEyes's Avatar
Ya thats one of the thing i was mentioning as well to you. I would double check to make sure the light is seated properly and also twisted in place all the way. If its not in the light wont focus in the right spot and it will make the outer ring dimmer in color. You also said that you tried swapping thr LUX from side to side already too right?
      04-14-2015, 02:32 PM   #92
jplatt83
Correct, I did swap from side-to-side. So the problem doesn't lie within the bulbs being faulty. I'm not here to bash LUX in any way.
The issue is with the drivers side headlight (outer ring). Both bulbs lit up 100% white on the passenger side outer ring.
Which makes me believe I did position them correctly.
      04-14-2015, 02:34 PM   #93
LuxAngelEyes
Oh ya i know i would just double check to make sure they are installed right and twisted in place all the way. Try to look at the inside of the inner ring and you should be able to see the light installed there. You will be able to see if its straight or for some reason crooked. Also were the headlights ever replaced on the car as that could make a difference
      04-14-2015, 03:55 PM   #94
jplatt83
I'm going to look into the headlight issue this weekend and double check on that.
Wouldn't of that appeared in the car fax report or BMW service history? I didn't come across that.
      04-16-2015, 04:39 PM   #95
Cattivo
FDNY Engine 55
Cattivo's Avatar
If you want to switch to the LUX H8 160's you can do that and we have a 60 day return policy on the lights. Just sent me a e-mail sales@LuxAngelEyes.com and i can get you the information needed if you want.
I e-mailed you about switching to the 160's instead
      04-16-2015, 08:51 PM   #96
Bklynjoker
Bklynjoker's Avatar
85
@LUXANGELEYES Where's a 1 week discount code? I think we deserve it
      04-17-2015, 09:05 AM   #97
LuxAngelEyes
Thanks i responded yesterday do you
We keep our prices consistent so that no one ever feels they got ripped off
      04-17-2015, 04:34 PM   #98
Cattivo
FDNY Engine 55
Cattivo's Avatar
You know whats funny is, even the 2015 Dodge Charger has better n brighter LED Angel Eyes compared to our Pre Lci E70's
      04-17-2015, 06:00 PM   #99
serge1
Drives: X5 35d
2011 BMW X5 35d  [0.00]
Well, X5 (actually 5 series to be exact) started the whole "angel eyes" thing. A 2015 vehicle ought to have better rings vs. a 2007 they used as inspiration..
      04-17-2015, 11:25 PM   #100
jiggz
Drives: E90 M3|F15 X5 50i
After all this time, all these threads, and all these pics, IMO all of these aftermarket options look bad. Some look better than others, but if I had a 2011 or earlier X5 it would be OEM LED retrofit, or just turn the coronas off in iDrive.
I don't get wanting the brightest look possible? All I see is a blob of light coming from the headlight units in all these pics…or uneven lighting…
      04-17-2015, 11:47 PM   #101
Draper
Draper's Avatar
3461
Drives: M4 Comp / Macan Turbo
Current: G82 M4 Comp xDrive // Frozen Deep Grey
Current: 95B.1 Macan Turbo // Dark Blue Metallic
      04-18-2015, 09:17 AM   #102
LuxAngelEyes
I'm not arguing that the design of the headlights makes it difficult, but here's one picture from over on the Photo forum of the lights installed in an X5. They are pretty even looking and this is also very accurate to what you see in person
      04-18-2015, 08:56 PM   #103
radx5m
member
radx5m's Avatar
Drives: X5M
Lux 160's on the way
Just ordered the 160's for my X5M 2012. I'm a new member but have been keeping up with this thread. I plan on putting some PICS of GP bulbs currently on the beast and then the 160's. 160's supposed to arrive Monday. At the end of the day, it will be fine because most won't be seeing my Heads for long as I pass on the left.
Lux H8 160, Velos Stage II
      04-20-2015, 02:18 PM   #104
radx5m
member
radx5m's Avatar
Drives: X5M
Lux 160 installed compared to GP Thunder
Just put these in today. Slightly cloudy outside so will try to post better PICS. Overall I'm very pleased with the difference between stock and GP's. GP passenger side and yes it did seem to start having some fade to red but the camera seems to make this worse. LUX on driver side. For me LUX works and relatively cheap. Got to resize the rest of pics then post.
      04-21-2015, 07:22 AM   #105
radx5m
member
radx5m's Avatar
Drives: X5M
Added Lux 160 Pics
1st Pics of GP then Lux driver for comparison and finally Pics of Lux 160. Last two are at night. I apologize for PIC sizes.
      04-21-2015, 10:14 AM   #106
Bklynjoker
Bklynjoker's Avatar
85
Very nice, yeah I'll be placing my order for the Lux now.. Good pics
      04-21-2015, 12:28 PM   #107
NotMyCube
Drives: X5
Honestly I think the lux blue looks a lot better than white. Here's a pic I took a while back for comparison.
      04-21-2015, 01:35 PM   #108
Bklynjoker
Bklynjoker's Avatar
85
Oh damn they do look good. Are those the H8 v5 adjustables?
      04-21-2015, 01:46 PM   #109
windtendo
windtendo's Avatar
1716
Drives: 2023 M5C
2023 BMW M5C  [0.00]
1989 BMW M3  [0.00]
LUX H8 160.
      04-21-2015, 02:01 PM   #110
Bklynjoker
Bklynjoker's Avatar
85
So the H8 160 come in colors Or they're adjustable?
