      01-24-2013, 01:28 AM   #1
Rob32R
Drives: 530i/VW R32/E70 X5
Upgrading E70 X5 Angel Eyes Halo Rings to LEDs - What do you recommend?
Hey guys,
Thought this topic may be of interest to everyone looking to upgrade their halogen angel eyes to the LEDs as seen on the LCI X5. Seems to be quite a common add on and quite easy to do these days for pre-LCI E70 X5 owners like myself so I need your help in telling me which is the best to buy for my car.
What is the best (by best I mean brightest and most even) LED option for the E70?
Thanks in advance fellow bimmers.
Rob32R is offline   Australia
      01-24-2013, 04:36 AM   #2
X5MSD
X5MSD's Avatar
Drives: Xdrive35d
Lux
The best
X5MSD is offline   Reply With Quote
      01-24-2013, 07:48 AM   #3
Rob32R
Apparently Early E70 X5s don't use an H8 globe (on Aus spec cars - many US sites say the E70 uses an H8 bulb) - they use the same bulb as the E53. Is this true fellow X5 owners?
      01-24-2013, 12:15 PM   #4
igorbmwx5
igorbmwx5's Avatar
Drives: 2009 BMW X5 3.0si
Send a message via Skype™ to igorbmwx5
I bought LUX. Very happy with the look and quality of the product
igorbmwx5 is offline   United_States
      01-25-2013, 12:46 AM   #5
APLINE_997
Drives: 997 Turbo
I bought these after I wasn't impressed with the LUX for the E70 AE's. On my E60 M5 both rings are bright but obviously the inner rings are always brighter as that is where the bulbs are placed so it would stand to be brighter. On the E60 M5 the lights carry through the rings better probably since it is smaller ring diameters for light travel.
On the E70's the outer rings no matter which I had aren't as bright.
These ebay ones are white and bright on the inners and not too bad on the outers. Better than the LUX V3 that I had. Not sure about the V4's but its not important enough for me to upgrade again as I am happy with them.
http://www.ebay.com/itm/130764789973...84.m1497.l2649
This the seller I bought them from. Came in quickly and installed in minutes without a hitch.
APLINE_997 is offline   Reply With Quote
      01-25-2013, 01:05 AM   #6
mrpcar
Drives: 2012 X5M
I have the Lux kit installed, however I've noticed that the newer X5 with the factory LEDs looks much brighter. How is that achieved? Is it a different LED system? two LEDs on each ring?
mrpcar is offline   United_States
      01-25-2013, 02:54 AM   #7
APLINE_997
Drives: 997 Turbo
The LCI's updated Corona Rings are LED's and are not bulbs like the H8 bulbs for the AE's that were not LED's but H8 Bulbs. The LED H8 upgrade will never achieve the updated LED LCI Angel Eyes that are on the newer BMW's.
To achieve the same look you would need Orion V4's which are LED rings and are as bright if not brighter than the new LED Angel Eyes from BMW. You would have to cut into your headlights and have them installed. Not a hard task to install more so to cut your expensive headlights and seal them back up correctly.
I purchased the CREE 20W from EBAY for $77.00 shipped and they are better than the LUX V3 I had. Not sure about LUX V4 but I am sure they are equal if mine are better than V3.
      01-25-2013, 03:24 AM   #8
Rob32R
I am extremely keen on purchasing the LUX V3 AE's until you mentioned this above so could you please send me some picture of these Angel Eyes you mention above fitted to your X5 whether they be day or night shots please.
Appreciate the advice mate.
Thanks in advance.
      01-25-2013, 09:16 AM   #9
skunkd
skunkd's Avatar
Drives: 2004 STI 2008 BMW M5 2004 530i
There are no v4's that guy must have never had LUX V3's to begin with... Lux v3's are awesome. Period.
skunkd is offline   Reply With Quote
      01-26-2013, 06:35 PM   #10
APLINE_997
Drives: 997 Turbo
Skunkd - I heard there were a set of V4's coming out to be brighter so don't assume that I never had the V3's.
MTEC V4's. Same difference to me.
Also.
http://www.e90post.com/forums/showthread.php?t=712501
Keep your assumptions to yourself. I have no need to lie about owning LED's. Just because I made a small error I must have lied about it. Really?
I appreciate your helping me out on the Springs tips for the X5 but don't appreciate you calling me a liar. I am ALPINE_X5 on XOUTPOST. You PM's me about springs installation.
      01-26-2013, 07:16 PM   #11
APLINE_997
Drives: 997 Turbo
ROB
Here are some pics.
It was too cold outside for me to setup my good camera to take better night shots. I did make some changes on my small camera to capture the rings only without the harsh brightness you generally get. It was toned down so the brightness is less than actual but you will get a good feel for them.
I also included the normal shots where the lights overpower the lens but that gives you a sense of their brightness as well.
      01-29-2013, 12:37 PM   #12
LuxAngelEyes
LuxAngelEyes's Avatar
Drives: 2006 325xi, Sparkling Graphite
These type of angel eyes are actually quite a bit dimmer then the LUX h8 V3 angel eyes and as well they dim to about 1/3 total brightness when you turn on the headlights.
LuxAngelEyes is offline   United_States
      01-29-2013, 02:27 PM   #13
smyles
Drives: X5
None of the aftermarket options will look even close to LCI; notice how almost no one publishes daylight pictures - the outer rings are nearly invisible, regardless whether it's cheap ebay, mtec, lux, whatever...
smyles is offline   Reply With Quote
      01-29-2013, 02:51 PM   #14
mrmomo313
mrmomo313's Avatar
Drives: 2012 X5M
heres some pics in the day of lux from last winter.
go LUX or bust, best option imo
2012 X5M
Dinan Stage 1 ECU/Dinan free flow exhaust (black tips)/Dinan suspension/Agetro M700 22"/Gloss black grill and side markers
Future: Dinan stage 2 (when available)
mrmomo313 is offline   United_States
      01-29-2013, 02:59 PM   #15
mrmomo313
mrmomo313's Avatar
Drives: 2012 X5M
ps I took those with my crappy blackberry camera
2012 X5M
      01-30-2013, 12:57 AM   #16
Rob32R
Have settled for a set of LUX H8 V3 Angel Eyes. Hands down from I have read and heard they are the premium LED Angel Eyes you can buy at the moment. All I'm trying to work out now is whether the Australian delivered E70 X5's pre-LCI came with H8 Angel Eye bulbs from the factory.
If SOMEONE CAN CONFIRM THE ABOVE QUESTION THAT WOULD BE GREATLY APPRECIATED
Nice X5 M mrmomo313
      01-30-2013, 03:15 AM   #17
BMW_E70
Drives: E70
I had MTEC AE and am very happy with them..IMO, you cant go wrong with either MTEC or Lux..I was wanting to get Lux but at that time Lux was out of stock..
Rob32R, My X5 is pre LCI and they use H8 for AE..mine is 2009 35d..not sure if others are the same..hope that helps
Cheers
BMW_E70 is offline   Reply With Quote
      01-30-2013, 06:21 AM   #18
Rob32R
Good to see another X5 member from Australia on board. Are you from Sydney?
I did look at the MTEC AE's and when priced next to LUX they were pretty much the same in terms of price bracket of the sub $200 mark. My BMW X5 is a 2007 E70 pre-LCI which is pretty much exactly the same car as mine being a diesel.
It be good to get all the Aus X5 members together.
      02-04-2013, 01:26 PM   #19
Patrick66
Patrick66's Avatar
Drives: 2013 x5m
Day time running
Hi
I have a 2013 X5M. thinking about adding daytime running lamps from Bimmian and mounting them in the tops of the intake vents. Has anyone tried this and if so, we're there any problems? (E.g. Programming issues, etc)
Thanks
Patrick66 is offline   Germany
      02-04-2013, 04:10 PM   #20
Jimshorts
Jimshorts's Avatar
Drives: x5m
Love your truck Momo your like my twin except for the rims. I like yours better.
2010 BMW X5 M Eurocharged: 12.298 @ 112.860 MPH Tune only.
2005 E55 AMG 11.93 @ 117 1/4 mile 7.75 @ 95 1/8mile tune, shorties, street tires. Sold
Jimshorts is offline   Reply With Quote
      02-04-2013, 06:27 PM   #21
mrmomo313
mrmomo313's Avatar
Drives: 2012 X5M
thanks Jimshorts, we rep the best color for this truck IMO. these rims are my winter ones, I use the same wheels you do in the summer so we are twins haha
2012 X5M
      02-05-2013, 12:09 PM   #22
LuxAngelEyes
Thanks for those pictures, they look great!
Forum Jump
