FORUMS
- 5
| 01-22-2013, 03:38 PM | #1 |
I just got all 4 tires changed and i need to reset my TPM. Only problem is that my iDrive doesn't work. Sometimes it does usually in hot weathers. (idk why) I was wondering if there's another way to reset it without using the iDrive. I have a 2007 X5. I would appreciate the help. Thank You.
(I hope the technician didn't install my TPM's the wrong way) (let me add these new tires aren't run flat tires)
Laughter is the BEST medicine.
| 02-02-2013, 09:42 PM | #2 |
Drives: 2007 328i, 2007 X5 Join Date: May 2011
I drive, check the fuse behind unit, see video how to remove I drive then check for that fuse. I went from a potential 1500 fix to a 1.50 fix then when your I drive works you can reset tmps
| 02-05-2013, 07:32 AM | #3 |
Thanks for the help. I already got it reseted my iDrive works sometimes and then stops. I will look into taking care of the fuse when I get the time. Thank you
| Bookmarks |
| Tags |
| bmw x5 forums, idrive, tpm, tpms sensors |
