FORUMS
- 5
| 01-14-2013, 01:14 AM | #1 |
In The Game!
Drives: 12 535 Msprt/12 X5 5.0 Msprt Join Date: Mar 2012
Black Kidney Grille Install
So i installed the black Kidney grilles a few days ago and thought i would share my experience.
Super easy.... just have a soft touch so u dont snap the clips! These are the BMW performance Black Kidney Grilles glossy on the outside and matte on the inner rails Part# for left and right grilles B34651-71-2-150-246 B34651-71-2-150-247 Pop your hood, and then look carefully at the grille on the inside of the hood. Tthere are some tabs on the outside of the grille, that is what is holding the grille against the metal of the hood. There are about 3 tabs on the bottom and one on each side. You need to release those with a putty knife(5serieshb used a purdy thin putty knife no tape) or large flat screwdriver with some electrical tape on the end so you don't scratch anything. You only need to do this for the outter tabs, the inner tabs hold the black slats into the outter black trim, and you don'need to touch those Once you have released the outter tabs, then just push the grille out towards the front of the car, starting with the bottom of the grill first. Repeat for the other grille I have a link with pictures http://www.bimmerfest.com/forums/sho...22#post7311522
It will all work out in the end....and if it hasn't worked out yet, its not the end!
2012 Titanium Silver Metalic w MSPORT+Prem Sound+Tech+Cold Weather+Top/Side Cameras+ BMW Apps 2012 Space Grey Msport 50 X5 Premium+ Premium Sound+Cold Weather +Soft Close Doors ![]() |
| 01-14-2013, 10:31 PM | #4 | |
Vanilla Gorrilla
I used my fingers as well and found it quite easy that way.
X5 Diesel, Lowered & Tuned/Sierra Z71 "All Terrain" Lifted & Tuned/700hp 3.8L Twin Turbo G35
| Bookmarks |
