      01-05-2013, 02:26 PM   #1
pturecki
Drives: 2011 BMW X5 M
BMW X5M battery issue
Hi everyone
I'm asking all of you for an advice regarding the problem with my car battery.
I have 2011 BMW X5M with 18.500 miles on it with warranty. For the first time last year I noticed the "increased battery discharge" sign, I took my car to my dealer and they told me that I forgot to remove my radar detector from the slot (this is not true because I never leave it on and once the car is off it doesn't work anyways) It happened again few weeks ago and I noticed it happens always when it's cold outside. Now they told me that the key was in slot and I left my ignition on. Which again it's not true since I have a keyless entry system (smart key) so I NEVER use a key slot. They charged the battery and they told me that if it happens again they can't charge it because one of the cells is dead.
Basically they don't won't to replace the battery saying that this is my fault.
I know that there is a problem with the battery and I read that some people had it replaced. Have you ever had a similar issue and how was it resolved.
Any ideas of how to prove them that there is a battery problem.
Thanks
pturecki is offline
      01-05-2013, 02:29 PM   #2
mrmomo313
mrmomo313's Avatar
Drives: 2012 X5M
the search feature is your friend... anyway here is a big thread discussing this problem:
http://www.xbimmers.com/forums/showt...tery+discharge
2012 X5M
Dinan Stage 1 ECU/Dinan free flow exhaust (black tips)/Dinan suspension/Agetro M700 22"/Gloss black grill and side markers
Future: Dinan stage 2 (when available)
mrmomo313 is offline   United_States
      01-07-2013, 07:31 PM   #3
buckeyewalt
Drives: 2011 X5 50i
Originally Posted by pturecki View Post
Hi everyone
Thanks
I feel for you man,,,know what you are going through because I went through the same thing with my 2011 X5 50i....started with the "increased battery discharge" message,,,took it in,,,they charged the battery and said it was good to go,,,next morning,,,same thing,,,,took it back, they "deep charged" it and said it was good to go,,,,2 days later,,,same thing. This time I took it in and they kept for a week,,,replaced a few modules, charged it and said it was good to go,,,,,next day same thing,,,this time,,not only did I return it to the dealer,,,I also called BMW and filed a complaint. Bottom line without going into boring details,,,,they kept my vehicle for 90 days,,,replaced numerous modules, sensors,,door handles, battery, alternator, some kind of a generator, rear heater control, wiring, new nav screen,,,the bottom line as to what the problem was,,,according to them the radio. Even though it was turned off,,and "sleeping"...it really was not! The total bill was just north of $13,000 which included labor and was covered under warranty. I got a new 750 to drive and then got a 35d to use after 45 days in the 750...not too hapy aabout the experience,,but at least it was fixed. That was over 5 months ago and no issues since!
buckeyewalt is offline   Reply With Quote
      01-10-2013, 01:14 AM   #4
doug_999
Drives: 2012 X6 50i/2011 1M
As noted, it is a common issue - right around the miles you have on the truck.
I had a CTEK 4.3 and put it on in the Recondition mode over a weekend. Have yet to have the problem again. I highly recommend this charger (did not at first!).
http://www.amazon.com/CTEK-56-864-Ba...words=ctek+4.3
2012 Vermillion X6 50i -CWP, Vent Seats, Tech, Sport, Premium Sound, Premium, Active Steering, 3 rear seats, BMW Apps, Space Saver Spare
2011 1M, Black loaded sans sat radio
doug_999 is offline   Reply With Quote
      01-10-2013, 01:51 AM   #5
5seriesHB
In The Game!
5seriesHB's Avatar
Drives: 12 535 Msprt/12 X5 5.0 Msprt
Question
ummm if that happened to me id be out of that vehicle already! can u say buy back!
pm if u ever run into this scenario again! i hope not
Cheers
Rob
It will all work out in the end....and if it hasn't worked out yet, its not the end!
2012 Titanium Silver Metalic w MSPORT+Prem Sound+Tech+Cold Weather+Top/Side Cameras+ BMW Apps
2012 Space Grey Msport 50 X5 Premium+ Premium Sound+Cold Weather +Soft Close Doors
5seriesHB is offline   United_States
      01-10-2013, 02:19 PM   #6
buckeyewalt
Drives: 2011 X5 50i
Cheers
Rob
I'll keep you in mind......thanks....
      01-10-2013, 03:49 PM   #7
Spaceballs
Spaceballs's Avatar
Drives: 2010 X5M
I had this issue recently, and fortunately for me, a BMW engineer was at the dealership when this was occuring. They put in a new battery, and it still happened the next morning when the tech started it. Turns out the determined it was the IBS cable, which was replaced a few weeks back and (knock on wood) its been fine since. I even left it out for a week when I went on vacation, so it didn't get started for a week and sat out in 5 degree temps, and it has been fine.
'10 Space Gray, Cinn Int.
Spaceballs is offline   Reply With Quote
      01-15-2013, 03:51 AM   #8
BimmerJeep
Drives: E70 X5 2007 3.0 Diesel
battery low
I have had ,similar problems. Battery is every other day low. Starting is a a tuff business in cold weathers.
thx for the info, IŽll check with my dealer to see if this cable could be the source in my car. I have to charge it once a month now :/
BimmerJeep is offline   Reply With Quote
Forum Jump
