FORUMS
- 5
| 12-19-2012, 10:54 PM | #1 |
engine light after dp/tune
had dp and ecu tune with o2 off, now i have check light, read code as u0100: lost counnunication with engine control module/powertrain control module "a" and p0171: system is too lean,, i double check all wire and vacume hose and etc,,, any suggestion?
| 12-26-2012, 01:00 PM | #3 |
Your tuner should be able to tune that stuff out. With these mods I would recommend a dyno tune. Its worth your time and money, trust me. They will straighten out your AFR so your not running too rich or too lean.
2010 BMW X5 M Eurocharged: 12.298 @ 112.860 MPH Tune only.
2005 E55 AMG 11.93 @ 117 1/4 mile 7.75 @ 95 1/8mile tune, shorties, street tires. Sold |
| 01-16-2013, 01:52 AM | #4 |
Go right back to the shop who tuned your car. If all you did was a dp and tune you should be ok. A friend of mine has an x6 dp, eisenmann muffler and ESS tune since he bought it new and it now has 35k and no problems at all! Its a BEAST
| 01-16-2013, 08:17 AM | #5 |
spend so many hours search about this issue and went to few shops to get fix(got rip off ) i got tune and dp from aa, looks like there are gas leak between turbo and dp. after i installed new gaskets longft % drop. still bank 1 is bit high, i think i might need new dp, clamp and gasket again for passger side.
| Bookmarks |
