      12-30-2012, 02:38 PM   #23
fatmatt0116
Hooligan
fatmatt0116's Avatar
Drives: 2014 Porsche Cayenne Turbo S
I'm going to put the 21" oem 215s on this spring, replacing the 18" 210s. I'm debating whether or not springs will still be necessary once I put these on. Thoughts? It doesn't have the sport suspension but I thought the 21s would help improve some of the boatish ness of the present setup.
2011 X5 5.0 Dinan - SOLD
2007 Imola Red Z4 M Coupe -SOLD
2004 Navy Blue BMW 325Ci
      01-02-2013, 08:43 PM   #24
exfyvem
exfyvem's Avatar
10
Drives: 2012 X5M
can't stand this anymore, KW's goin on next week.
2012 X5M, 2012 Panamera Turbo, 2011 Maserati Granturismo S (sold), 2006 Range Rover HSE
      01-02-2013, 10:59 PM   #25
Die Wolfe
Die Wolfe's Avatar
10
Drives: '12 535i Msport/'13 X5///M
Thata boy! I'll head that route unless I go with Dinan since I'm a badge whore haha
      01-02-2013, 11:32 PM   #26
Omar@VelosDesignwerks
Omar@VelosDesignwerks's Avatar
Drives: Different Ones
Send a message via AIM to Omar@VelosDesignwerks
Let me know if you need help with a quote
You won't regret it by the way!
      01-03-2013, 02:48 AM   #27
northern2020
northern2020's Avatar
Drives: '11 X5 M / '01 B5 S4/ 15 328d
Excellent....!
| '10 Escalade ESV | '12 Audi S4 | '01 Audi S4 | '15 328d Xdrive M-Sportwagon |
      01-03-2013, 02:49 AM   #28
northern2020
Dinan = more expensive HR's with less drop + bushings
      01-03-2013, 10:26 PM   #29
SerbX5
Serbia
Drives: E70 X5M
hahaha.. I feel yah man. I swear though, take 10 minutes and unscrew the rear links, make them a tad longer. The results are night and day.. my ride still is low. I love it right now.. and I was cussing about how much I hated it for the last month. It drives just like stock.. I'm not exagerating.
E70 X5M | BMW i3 | B8 S4
      01-05-2013, 03:03 PM   #30
Boosteeddc
Drives: 2010 x6m
Roughly how much higher did you set the rear links. Like is the rear sitting as high as the front or higher? I got mine installed on my x6m lastnite and dumped the rear. It's now not drivable
      01-05-2013, 04:18 PM   #31
SerbX5
Serbia
Drives: E70 X5M
Yah.. thats what happened to me. It was terrible. Just go in there, adjust them a bit.. spin them twice full circle when extending the links. You'll thank me later and it will still look great. Takes onlyo 10 minutes.. not hard at all.
      01-05-2013, 08:39 PM   #32
skunkd
skunkd's Avatar
12
Drives: 2004 STI 2008 BMW M5 2004 530i
make the fender height equal front and rear from the ground. The ride is like stock!
      01-05-2013, 08:51 PM   #33
Boosteeddc
Drives: 2010 x6m
So that's the best setting for these springs huh. Thank you
      01-06-2013, 04:53 AM   #34
KrisHorton
Drives: E70 X5M and E60 M5
Right now I've got the height at 29.5" ground to fender and 30.5" in the rear and it rides great! I might drop the rear to 30" but that's about as low as I'd consider going. The ride is stiff but no longer bouncy or overly hard.
      01-07-2013, 02:15 PM   #35
skunkd
skunkd's Avatar
12
yea maybe a 1/4 to a 1/2 inch higher in the rear than the front. I forget exactly what mine were.
It's best to keep the stock rake angles. as far as headlight aim etc.
Just measure stock height and match the front drop with the rear adjustable links.
      01-27-2013, 02:22 PM   #36
Sylvan Lake V35
Vanilla Gorrilla
Sylvan Lake V35's Avatar
Drives: X5M & X5 35d
Some useful info in here, i just did a 200mile road trip with my family and evryone agreed it needed to go back to stock it was so bouncy it was uncomfortable even on the hiway.
I was around 32-32.25" before now I am 29.75-30" all around I am going to adjust the rear links today after reading this...I sure hope it helps.Thanks guys.
X5M, Eisenmann exhaust, 22" HRE wheels, catless down pipes, Stage II tune/X5 Diesel, Lowered & Tuned
      01-27-2013, 03:36 PM   #37
skunkd
skunkd's Avatar
12
I just went to measure mine for you with a yardstick
Lowered on the H&R 1.2" springs and adjustable rear links I'm sitting at 30.5 inches front and rear fully settled in (over a year). The ride is like stock. You must have the 2" springs. I would raise your rear to match mine and change our the front springs for the correct ones. You will love it!
here is a picture of mine:
      01-28-2013, 12:25 AM   #38
Sylvan Lake V35
Vanilla Gorrilla
Thanks for the replies Skunkd.
      01-28-2013, 10:34 AM   #39
cleanX6m
Drives: 11 X6M, 13 ls460 Fsport
people with kw3, how does the edc plays into affect?
      01-28-2013, 11:14 AM   #40
5seriesHB
In The Game!
5seriesHB's Avatar
Drives: 12 535 Msprt/12 X5 5.0 Msprt
Talking
You can say that again...Whore
It will all work out in the end....and if it hasn't worked out yet, its not the end!
2012 Titanium Silver Metalic w MSPORT+Prem Sound+Tech+Cold Weather+Top/Side Cameras+ BMW Apps
2012 Space Grey Msport 50 X5 Premium+ Premium Sound+Cold Weather +Soft Close Doors
      01-28-2013, 11:16 AM   #41
APLINE_997
Drives: 997 Turbo
CleanX6M - No EDC is combined with the KWV3 since you are replacing the EDC with the KW COILOVERs and you will have to dial in the height/rebound/compression manually. The EDC Delete is an option for a few hundred more or you can do without the option but you will get the warning light. Not sure if you can code it out of the car.
      01-28-2013, 12:28 PM   #42
vitiokas95
Drives: 2001 M5, 2008 E90 M3, 2010 X5d
If anyone will be selling their H&R springs, let me know. I am looking to lower my X5d. Mine is not self leveling, thought.
      01-28-2013, 11:03 PM   #43
northern2020
EDC delete is the way to go - no error codes etc.
Beauty of KW v3 is that you can dial in your own preferred dampening / rebound instead of only the Factory settings.
I have my KW fit at their recommendations which is 50% (In middle of adjustable settings) and its much smoother than stock - almost too cushy -
I need to stiffen it up prior to the spring track sessions
      03-09-2013, 10:55 PM   #44
JLed79
JLed79's Avatar
29
Drives: Fast, very very fast...
Originally Posted by Jesse@MBRP
I have the 1.2" drop springs on my E70. The ride is like factory and the drop was nearly 1.8" after they settled.
Your car looks great. I'm doing the same thing to mine. I just powder coated my 214s black with a red strip around the rim edge. I'm going to plasti dip the step sides black too. Lowering springs are next.
