      10-29-2012, 12:08 AM   #23
Antoans4
Antoans4's Avatar
Drives: 2012 X5Diesel & 2011 335is
Please do a before and after dyno with the JBD
      10-29-2012, 01:45 AM   #24
NRG
NRG's Avatar
Russian Federation
-83
Drives: 2012 X5 35d
Originally Posted by daltonnnn
My JBD controller came in!!! Sweet!!! Now, I wonder if I should dyno before and after??
I wish they would have upgraded to USB....
Shove it to a 100% and go... It best felt after 50% of throttle input.
Retired: 2005 N52 E90 330i Sport 6AT
Retired: 2007 N54 E92 335i Sport 6AT
Current: 2012 M57 E70 X5 xDrive35D
      11-05-2012, 10:51 PM   #25
daltonnnn
U.S. Navy Officer
daltonnnn's Avatar
Drives: F80 M3, X5d, MSM, Clubman S
Send a message via AIM to daltonnnn
Just got my new door moldings painted and installed. Will upload photos later
** Go Navy! **Go SF 49ers!!!** Go SF Giants!!! Go Warriors!!!!!**
      11-07-2012, 07:06 PM   #26
daltonnnn
U.S. Navy Officer
daltonnnn's Avatar
Here are the photos I took with my camera phone so far. Overall, I'm happy with the change. It wasn't a big change, but it looks great.
As I type this, I'm getting a clear bra installed. Tomorrow, I am going to dyno the 35D stock and with the JBD installed.
      11-07-2012, 10:40 PM   #27
zibawal
Drives: 2012 X5D
I got a JBD installed! How do I get dynoed? What is the process? Pls advise
      11-08-2012, 11:32 AM   #28
ndabunka
Drives: 2012 X5 35d Sport Black/Black
What do you mean (USB) and why? The connector is ODB and that is REQUIRED to connect to the car. How would you even make use of USB? Is there some type of separate serial interface for connecting a PC to the unit? If so, you CAN get a serial to USB converter, right?
      11-09-2012, 03:01 AM   #29
NRG
NRG's Avatar
Russian Federation
-83
Drives: 2012 X5 35d
By USB he probably meant the BT type of cable that connects through USB to computer.
      11-09-2012, 12:46 PM   #30
ndabunka
Correct. I stated that above. I asked what it connected to the computer with if it WASN'T a USB. He hasn't yet responded, right?
      11-09-2012, 12:59 PM   #31
daltonnnn
U.S. Navy Officer
daltonnnn's Avatar
All I meant by that was the older connection is just old and clunky. USB would have given me a better warm and fuzzy.
      11-09-2012, 10:17 PM   #32
ndabunka
Maybe a speaking past each other here. Let me try this...
***** Please answer question BELOW this line ********
WHAT IS THE OLDER CONNECTOR? 9-pin serial?
***** Please answer the question ABOVE this line ******
      11-10-2012, 03:17 AM   #33
daltonnnn
U.S. Navy Officer
daltonnnn's Avatar
Yes. The older connection I was referring to was the serial portion. I wish it was obd to USB. That's all.
On another note, I did my dyno yesterday and I'm happy with the results. With the JBD at 100%, I made 230 HP and 345 torque at the wheels. I'll post up my graphs later when I get the chance. IMO, I don't feel a difference in the car because its the X5d already feels flippin fast, but the numbers show a 30hp/30tq gain at the wheels, which is nice. My current setting for the car is 80% now.
I also got my new exhaust installed too, which ill post photos of that later too. Unable to get the dyno for this since it got installed today. No difference in sound, but in terms of flow, it is way better than stock and much lighter too. No official weight numbers, but it's definitely lighter.
      11-12-2012, 09:18 PM   #34
Antoans4
Antoans4's Avatar
I wonder if we could get a flash and also JBD to get more power
      11-13-2012, 12:08 AM   #35
daltonnnn
U.S. Navy Officer
daltonnnn's Avatar
I'm sure it's possible, but with a good flash or tune, you'll be able to control everything from there, unless you want to change your fuel settings quick.
      11-13-2012, 01:13 AM   #36
NRG
NRG's Avatar
Russian Federation
-83
Drives: 2012 X5 35d
You can, if the flash does not modify the fuel rail pressure parameters. That what the piggyback/JBD does. I would stay away.
      11-13-2012, 01:17 AM   #37
NRG
NRG's Avatar
Russian Federation
-83
Drives: 2012 X5 35d
What dyno was used. The numbers after JBD@100% are extreamly low. Terry's numbers are around 310HP at the wheels. Btw how did you pickup the TQ reading signal?
      11-13-2012, 03:49 PM   #38
Antoans4
Antoans4's Avatar
So the mix between two won't be a good idea, i was thinking about doing evolve and also JBD, but if thats the case ill just do JBD
      11-14-2012, 12:16 PM   #39
daltonnnn
U.S. Navy Officer
daltonnnn's Avatar
The dyno they used was Superflow. All readings were taken from the in-ground rollers. After their at the flywheel conversion of 1.35, flywheel HP is 310 and torque was 465. Torque is on the lower end because when they rolled into full throttle, the tranny would want to shift from M4 to M3 by itself.
What dyno did Terry use?
