      11-21-2012, 01:22 PM   #67
bulldog x6
bulldog x6's Avatar
45
Drives: '16 MB GLE
Originally Posted by skalberti View Post
35i only requires 89 octane, not 93 anymore.
actually 91, not 89
      11-21-2012, 05:15 PM   #68
skalberti
skalberti's Avatar
Drives: 2017 Mineral White M3
Bulldog, if you have a 2012 35i, open the gas tank door and read the white lettering. It says 89 octane
It's good to be bad
      11-21-2012, 11:52 PM   #69
sunnygps
Drives: 2012 X5d
If it is 89 oct, then there is 40 cents difference between 89 and diesel where i live. That in itself will negate the mpg difference between the two.
      11-22-2012, 09:31 PM   #70
mastek
e36s54, e70x5d
mastek's Avatar
Drives: slow
You have to seek...
In my city, at different gas stations, I can find Diesel less then regular gas and more then premium gas on the same day.
Use the gasbuddy app
      11-23-2012, 12:44 PM   #71
JNoSol
JNoSol's Avatar
Drives: 750 MSPORT
Confirmed. My 2012 X5 N55 gas cap says the min is 89. However, my 2011 535i says the min is 91. I run 93 on both cars, I'm not taking chances of any knocking or pre-detonation.
      11-23-2012, 11:24 PM   #72
sunnygps
Drives: 2012 X5d
You have to seek...
I have been using the app for sometime now. It seems the most it fluctuate is between 30 and 40 cents. When I travel to NE, I try the app to what the difference is, it is generally 10 cents higher than 93 oct.
Anyways, I have 2010 x5 3.0 and get on an average 14 - 15 mpg and I have always filled it up with 93. I am looking forward to my 2012 diesel as it will be fun to drive.
      11-24-2012, 09:36 AM   #73
wsybert
wsybert's Avatar
Drives: 2009 BMW M3 Vert
If you do the math.... At your average 14.5 mpg, and 12k miles per year at $3.60/gal. That is $2979.00 per year.
If you assume the diesel will average 18.5 mpg, which I think is conservative, and at 12k miles per year and $4.00/gal, you would pay $2594.00.
The diesel would have to average 16.1 mpg, for the costs to be equal.
2014 JGC Summit 5.7
2009 M3 Vert (Fun in the sun)
2005 M3 Vert (Sold)
Too many more to list....
      11-24-2012, 01:45 PM   #74
ndabunka
Drives: 2012 X5 35d Sport Black/Black
It all depends on the WAY that you drive. If you like & USE the pedal on the right often reving above 4K RPMs, you are probably going to average under 20MPG. If you live in a city and only commute 5 miles a day and average under 15MPH on that trip (lots of stop & go), you might also average under 20MPG. However, if your average speed is more "typical" and shows around 30MPH (or higher) it would mean that you have a good mix of city & highway driving and by not revving over 3K RPMs, you should be able to average more like 24MPG with a new diesel. If you drive almost exclusively on the interstate (e.g. avg MPH is above 45) then some are reporting getting up to 26MPG. There are some who "claim" to be getting 29 & 30 MPG on exclusively interstate trips on flat terrain but IMHO you can take those with a grain of salt as most of those posts appear to be people trying to "brag" and anytime you see that, you HAVE to be suspect. My recommendation is that you use something more common as a point of calculation (like 22MPG) as that appears to be a level that almost everybody can obtain on these vehicles (look on independent sites like Fuelly for their averages).
In my area, Diesel was about 5 cents CHEAPER than the premium I use to run. Then we had these recent (last 2 months) of reduced gasoline prices and diesel in this area is now actually about 20 cents more than premium ($3.77/gal vs. $3.57/gal) so there will be annual (& even daily) fluctuations in those differences.
The difference using ~24MPG for the Diesel & your figures for an average of 12K miles/year is 827.5 gallons vs. 500 gallons ($1,885 vs. $2,979) so purely calculating fuel savings is more likely over a thousand a year. The REAL benefits to Diesel come in other areas like more towing power & better performance when going up mountain roads due to the huge torque advantage the diesel has over the petrol variants of these vehicles. Pair that with the CRAZY discounts that can place the cost of the Diesel versions LOWER than that of the gasoline versions and it seems like a no-brainier for some of us
      11-24-2012, 09:23 PM   #75
sunnygps
Drives: 2012 X5d
I agree with the mathematical differences between the 2 fuel types. My commute and driving style will not change with the diesel. So, I will come out ahead if the prices stay within 30 to 40 cents of petrol. I do recall that over summer the difference was 10 to 15 cents.
I bought the diesel for not only the mpg, but it will be fun vehicle to drive. I got the options that I wish I had in my 2010 petrol, such as active drive, muti-contour seats and HUD. Plus, to me the 2011 and newer X5 drove a little better and could be due to the changes made in 2011 model year. This could just be me.
My SAV is build and should be at the dealer this week. Can't wait to take delivery.
      11-29-2012, 12:30 AM   #76
CMH75
Drives: '11 X5 35d
Originally Posted by JNoSol
Originally Posted by NRG View Post
No pros period over the gas! MPG difference is a joke.
What is your average mpg and how much hwy driving do you do? I average around 20.5mpg with 70% hwy.
I found this thread: http://www.xbimmers.com/forums/showt...ight=x5+diesel
I'm averaging 21.7 mpg with 60/40 city/hwy post emissions system recall fix. Prior to that and for about 35k miles I averaged 23.8 with the same driving mix.
      11-29-2012, 12:50 AM   #77
Grayblack
Grayblack's Avatar
108
Drives: F85 X5M/E92 M3 LRP
Our x5 diesel is my wife's daily driver. The gas mileage is great, especially for the long road trips. However, I wouldn't be able to drive it everyday because I can't stand the diesel engine noise.
      11-29-2012, 11:51 AM   #78
sunnygps
Drives: 2012 X5d
I picked mine up yesterday. The diesel sound is a bit noticeable when idling, but goes away pretty quickly. To be honest, the only time I hear it is when the radio is off and I am seeking out for that diesel . Meaning, if I pay no attention, it will not bother me.
The true test will be when we take a family trip and my wife is sitting in the front passenger seat with the radio off... All she wants to do is talk - at normal volume and not raise her voice over the diesel growl.
It is my first diesel, so lets see how it grows on me.
      12-05-2012, 01:13 PM   #79
Gammaman
Drives: X5 35d
Just bought an X5 35d for my wife. She's getting 30 mpg in mostly rural/highway driving. Torque is great. A bit of clatter at idle, but overall I don't find the noise objectionable.
      01-19-2013, 03:02 PM   #80
hifiguy
Mthusiast
Drives: e46 m3
2010 X5 35d  [0.00]
2004 E46 M3  [0.00]
just to chime in from traffic-heavy LA, we're consistently getting 19/28 with +/- 1 mpg with front/rear AC on.
That's pretty great for a mid-size SUV, hell my m3 gets 19 city if i baby it and don't use AC, haha.
clear bra, ceramic tint 60F/50R, bel rx65, pss9, dixis, le-37, wheel stud conversion, yellow belts
      01-19-2013, 06:59 PM   #81
bikesinmud
Drives: X5d
Towed just over 6100lb from Edmonton, AB to Houma, LA with several stops at various cities in between. In total 4918km and driving at the speed limit. Used 2 gallons of DEF and averaged 23.1mpg (thats a 4.54l gallon). Love my X5d.
      03-14-2013, 08:48 AM   #82
markE90
markE90's Avatar
Philippines
47
Drives: AW X5 35d
Send a message via Yahoo to markE90
For me I get 18.2 mpg on my X5d driving 10 miles to work round trip. I use surface streets where there are alot of stop lights.
I only have 480 miles on the odometer.
      03-14-2013, 04:35 PM   #83
serge1
serge1's Avatar
Drives: X5 35d
2011 BMW X5 35d  [0.00]
Originally Posted by Skyfall View Post
I test drove both and ended up getting the '13 35i. I enjoyed both, but the increased insurance costs would negate the savings from getting diesel.
Insurance costs??
      03-16-2013, 08:50 PM   #84
tman68
Drives: e46 m3, e70 x5
I just picked up a 35d a few days ago and got almost 500 miles in one tank. I think its great so far. The torque is awesome!
      03-23-2013, 04:43 PM   #85
Midwest 535i
Midwest 535i's Avatar
Drives: 2016 535i
Congrats!!
LOVED my 011 35d - wish I still had it
Wife just picked-up 013 35i and I gotta say I'd have a hard time choosing between the two now...She's getting about the same MPG with just a few hundred miles on it as I'm getting on my 4 banger N20 this winter..
Go figure? But I drive the N20 in sport mode all the time - and it will pick-up some mpg when the weather warms
Enjoy the diesel - it's an awesome motor too!!
Current Ride: 2016 535i\Xdrive\Mediterranean Blue\Oyster Nappa Interior\Premium\Cold Weather\Drivers Assistance\Drivers Assistance Plus\Harmon Kardon\Multicountour Seats
Previous Rides: M235xi, X3, E92 M3, E70 X5 35d, X6 50i, X6 35i, E60 550i, E46 M3 Cabriolet, E39 540i, E36 328i
      03-24-2013, 04:03 PM   #86
howiedds
D.D.S.
howiedds's Avatar
17
Drives: 12 AW E70 X5d
NDABUNKA couldn't describe it any better... i currently get those figures
Current: Jeep GC Overland Hemi 4x4
TOTALED: 2012 AW X5d with Sport+Prem, (Heartbroken how she left me)
RETIRED: 2009 SG e92 M-Sport( I will miss you....)
      03-25-2013, 01:35 AM   #87
serge1
serge1's Avatar
Drives: X5 35d
+1.
I once got 30mpg over 15 miles of distance in my diesel, but what does it say? Nothing. True mpg is by averaging whole tank. For that particular trip (mostly highway), mpg came out to 25.5.
      03-25-2013, 01:58 AM   #88
Rekla
Hug the road... Carpe Asphalt
Rekla's Avatar
Drives: 2007 ///M Coupe
1,500 miles ODO, 23MPG average, 60/40 hwy/city. I pretty much get sticker MPG's @ 22 city / 28 hwy. love the torque, don't mind the cold clatter, had people walk up to me 'sir - that's diesel!' upon the second fill up. Lol
2013 X5-35d - Platinum Grey / Oyster; Premium - Sport
2007 BMW ///M Coupe
RETIRED 2006 TiAg E90 330i - Black leather - Alu Trim - Prem - Sport - NAV - Step - CA - Heated Seats
Tags
diesel, x5 35d
