Bimmerpost for iPhone and Android have just been updated with a host of bug fixes. If you've ever had trouble logging into it in the past, give it a try now!
      07-23-2012, 11:49 PM   #1
Dmack
Drives: Bmw x5
E70 4.8 pump noise when stationary
My 08 4.8 X5 is making a strange pump like whirring sound after driving and then coming to a stop at traffic or lights etc. once you take off it stops. It sounds like a pump or similar sound. Not linked to engine rpm. I noticed if you turn off the AC while it's making the noise it will stop. So may be related to that, but what could it be that it's switching on at low rpm or stopped speeds? Any ideas?
Is there some engine vacuum pump or similar?
I have the service manual DVD but its so hard to learn about the car, more a reference of u already know what's there.
Thanks
      07-24-2012, 01:03 AM   #2
StephansonTieu
X5 Enthusiast
StephansonTieu's Avatar
Drives: 2001 BMW x5 3.0i
2001 BMW X5  [4.50]
That might be your AC compressor. Should get that checked out before damaging it, kinda pricey.
Good luck!
      07-26-2012, 07:27 PM   #3
Dmack
Drives: Bmw x5
im taking it in this morning to get looked at, strange that it only happens when you come to a stop though...
      09-09-2012, 01:27 AM   #4
Dmack
Drives: Bmw x5
Didn't end up dropping it of to the dealer as the noise wasn't present that day, but after trying to find the source myself first, i discovered an oil leak from the vacuum pump, mounted to the front of the engine, right hand side bank.
this fits with my vacuum pump noise suspicion.
now i will get the dealer to investigate. since i have a smoking gun to point them too.
Ill let you know how it goes.
      12-28-2012, 07:16 PM   #5
Dmack
Drives: Bmw x5
As an update, the vacuum pump replacement cured the noise.
      10-18-2013, 03:48 PM   #6
westgo33
Drives: 08 X5 E70
I have a similar pump like pulsating noise, that seems to be associated with the HVAC...which parts (pump) were involved in the fix? Thanks!
