FORUMS
- 5
| 07-17-2012, 08:24 AM | #2 |
![]() Drives: GTR, X5 50i & F10 550i M-sport Join Date: Apr 2006
Yes. Boost is a big factor, but there are other differences. There have been a number of posts on this, but to summarize: the intake is completely different allowing improved airflow at the top end, different turbos (twin scroll and slightly larger on the M), different spark plugs and engine management, some exhaust differences, and likely different internals with lower mass (and a resulting lower compression ratio allowing higher boost).
2011 Nissan GTR Red/black - HP Logic tune/midpipe - "Lightning"
2012 BMW X5 50i M-sport Dinan stage 1 Space gray/black - "Thunder" 2012 BMW 550i M-sport Jet black/black - "Black Cloud" Gone but not forgotten: '12 X5M, '07 AM SuperVantage, '05 Boxster S, '01 BMW M3,... |
| 07-17-2012, 12:56 PM | #3 |
"different internals with lower mass (and a resulting lower compression ratio allowing higher boost)" .......???
As an Engineer of some 32 years this is a new 'concept' of the engines internal mass affecting compression ratio.?? Do you mean lower compression ratio pistons per chance.? |
| 07-17-2012, 01:50 PM | #4 |
Sorry, I thought it was self-explanatory that the lower compression ratio was from the pistons. The parenthetical comment was was supposed to add on to the features of different internals, not lower mass. Let me re-write it so that is easier for the engineers to understand...
Different internals FOR less rotational mass (and resulting lower compression ratio ((due to the pistons (((which are also lighter))), which allows higher boost to be used safely))). And the pistons are lighter. And different.
| 07-17-2012, 10:31 PM | #6 | |
| Bookmarks |
