      06-17-2012, 08:30 PM   #1
zerrantoss
Drives: 2011 X6
H&R lowering height
I can't seem to find a thread that compares the ride height of 1.2" drop vs 2.0" drop.
I am thinking about lowering my X6 with 2.0" front & 1.2" back.
Many of our members' ride look really nice with a 2.0" drop.
However, I am just a little curious:
I did a measurement of the stock ride height, my gap between the wheel and the fender is about 3.5", both front and back.
If I upgraded to H&R 2.0/1.2, wouldn't that make it uneven? The front gap should become 1.5", while the back becomes 2.3".
The rear gap would be a lot bigger than the front.
For those who has installed 2.0 front/1.2 rear, do you see this "un-eveness" between the front and rear gaps?
zerrantoss is offline   Canada
      07-16-2012, 10:04 AM   #2
northern2020
northern2020's Avatar
Drives: '11 X5 M / '01 B5 S4
You will regret the 1.2/2 drop absolutely
Too bouncy and stiff, quite unsafe
| Vorsteiner front splitter | ADV-7 22" | ESS | Akra Catless DP's | Akra Evo Exhaust | KW V3 Coilovers | Lux V3 H8 | HR TRAK spacers 20mm |
| 2011 X5M | 2010 Escalade ESV | 2012 Audi S4 | 2001 Audi S4 |
northern2020 is offline   Canada
      07-17-2012, 08:09 PM   #3
Randy H
Drives: 2010 X6 3.5
I am also interested in lowering my X6. If the folks at a "tuners depot" web page are to be believed, the H&R Sport springs should ride fairly close to stock. So--- what is the basis for your statement that they would be too bouncy and stiff? I don't have experience so I am asking, not trying to be a smart arse.
Thanks!
Randy H is offline   Reply With Quote
      07-18-2012, 11:13 AM   #4
zerrantoss
Drives: 2011 X6
Thanks!
I just had mine lowered by H&R. It is just like you and other people suggested, the ride feels almost like stock. It may be just a bit more stiff, but not that noticeable. Perhaps northern2020 is referring to other brands.
      07-19-2012, 12:50 PM   #5
mariano305
Drives: x5 4.8 xdrive
I have a H&R 2" drop in the front and 1" in the back on my x5 and it's awesome the ride is not bad at all
mariano305 is offline   Reply With Quote
      07-20-2012, 02:16 AM   #6
GameTheory
GameTheory's Avatar
Drives: 2012 X6 35i
2012 X6  [3.50]
Lowered mine H&R. No problems, springs are great.
Give them some time to settle, they'll get softer.
GameTheory is offline   Reply With Quote
      07-20-2012, 11:02 AM   #7
BabyBlack
BabyBlack's Avatar
Drives: E46 M3 & E90 335i & E71 X6M
I dont have personal experiance with H&R spring, but I heard it feels a little bouncy when driving on highway speed, I guess its due to the oem shocks can't handle the lower ride, that's why I go with KW V3, and I love how its ride but the only down side is loosing the EDC.
BabyBlack is offline   Reply With Quote
      07-20-2012, 02:45 PM   #8
Medihummer
Drives: X6m 50d
That danymic drive thing is awefull i didn't try it yet on the x6 but the 550d with dynamic drive is by far the worst car i've ever driven. It is wiggeling around its central axis all the time while cruising on the highway. I think it is a shame bmw does dare to sell something that bad. Even my hummer feels like a sportscar compared to that. On the x6 50d i ordered i want to remove it by putting the kw v3 so to me the removal of the edc is the purpose
Medihummer is offline   Reply With Quote
      07-20-2012, 03:06 PM   #9
BabyBlack
BabyBlack's Avatar
I think you mix up the Dynamic Drive and the EDC(Electronic Damper control) which will just stiffen up the damper
      07-20-2012, 08:49 PM   #10
Jlam86
Drives: 2008 e70 4.8i
I installed h&r lowering springs earlier this week. I got the 1.2" drop but they went a little more than that. Almost like 1.5-1.75" after the car rested a bit in the springs. The links that came with the kit was set to 6.5cm which was suppose to give the rear a 1" drop. Upon Installation, it dropped a LOT more than 1". So I lengthened my links by .25cm more and now it is quite perfect.
As for the ride quality, rear is a bit more bouncy but barely noticeable. All in all, it rides very much like a stock vehicle but remains more flat going around curves at a high rate.
The install was fairly straight forward too. Pm me if you want more info. Hope this helps
Jlam86 is offline   Reply With Quote
      07-20-2012, 09:06 PM   #11
northern2020
Bottom line is when you drop the ride with only a spring - you are keeping the factory shocks which are now not designed to match up to the increased spring coil tension which leads to a stiffer ride.
The HR springs come in 2 drop sizes.
The more aggressive drop absolutely sucks arse. Massive bounce and too stiff
The less aggressive drop is ok - but still stiffer than stock.
I tried both and was unsatisfied.
I went with KW v3 as the other poster has done, and it's as comfy, more than stock and you can play with the ride height infinitely.
You can also adjust the dampening and rebound to be as stiff as hell or buttery smooth.
Bottom line is if you have a $100k truck don't cheap out some $200 springs.
This beast has evolved and is track ready with the KW v3.
Kinda like sex with a condom. Not bad until you take the latex off.
      07-21-2012, 03:12 AM   #12
mdrobc13
mdrobc13's Avatar
Drives: '12 BMW 550i
2012 BMW 550i  [5.00]
Send a message via MSN to mdrobc13 Send a message via Yahoo to mdrobc13
Had mine dropped about a week ago. Very nice. Went with H&R's with 1.2" front and 1.0" back and it is fine. Not to bouncy or stiff at all. Much flatter going thru corners also and dynamic handling such as curves and changing elevations. I just towed my other car 2200m with the X6 pulling all the way and no problems what so ever. Springs handled the job pretty well. After offloading the car carrier and car it was really good...could tell the difference in the ride. Overall happy I did it.
'12 F10 550i (DGM-II - Dinan Stage 4/Intercoolers & Shockware, H&R Springs, Eisenmann Race Exhaust, Hamman CF rear difuser, Giovanni "Lindo" Graphite 20")
'10 e71 X6 35iDrive SAV (Space Gray) - Gone
'06 e85 Z4 M Roadster (Black Metallic) -Gone
'08 e92 M3 coupe (Sparkling Graphite) -Gone
mdrobc13 is offline   United_States
Forum Jump
