06-05-2012, 02:02 PM | #1 |
Rep 14
Rattle sound in my X5
Hello everyone
This is my first post here I have a 2010 X5 4.8 and I live in Egypt And as some of you may know the roads here aren't perfect Because of that and the hard ride of the 20" I am suffering from an annoying rattle sound couming from the back side if the car and I can't determine from where exactly The sound mainly appear when the rear axle is not even (on wheel is higher than the other) I have paid many visits to the agency here with no apparent source for the sound Did anyone suffer from a similar problem and what r ur suggestions Thank you |
06-05-2012, 03:24 PM | #2 |
Rep 14
Thanks for your response
But the sound is more metal based rather than plastic rubbing The agency went so far that they removed the whole trunk upholstery and reinstalled it but with no result |
06-05-2012, 04:27 PM | #3 |
Rep 389
Is the sound more of a one-time click when weight of the vehicle shifts?
In my 35d, I hear this "metal on metal" click when taking a sharp turn at slow speed. Also happens when one wheel goes over speed bump. |
06-05-2012, 04:57 PM | #4 | |
Rep 14
but since the roads here are not paved well i hear the sound several times which become annoying is it normal though ???
06-06-2012, 09:28 PM | #5 |
Rep 75
Try the D latch that your tailgate locks into. I searched for ages and I found this to be loose. I still need to take it to the dealer for tightening but after managing to secure it temporarily the annoying rattle disappeared.
The D latch is the metal bit that protrudes from the lower section of the tailgate (top section latches on to the bottom). I hope this helps. |
06-09-2012, 07:12 AM | #7 | ||
Rep 14
The sound is exactly as serge 1 described i think it is something in the suspension but the agency confirms that noting wrong with them and the mystery sound still exist
06-11-2012, 10:42 PM | #8 |
Rep 75
horas I had the same sound when making a low turn speed as well. I suspect on my car it was the D metal tapping against the lock. If you have checked it and it is solid then so be it.
I thought there was something wrong with my suspension too and received the same response from the dealer. The other thing you could check is the metal D that the back seat locks into place as well. Try some electrical tape on that. |
06-13-2012, 02:09 PM | #9 | |
Rep 14
I will check them and refer back
06-13-2012, 02:14 PM | #10 | |
Rep 389
Is D-metal = metal on D pillar? |
06-13-2012, 08:15 PM | #11 |
Rep 75
I believe the official term for the "D" I am refering to is a door striker. The one that is giving me problems is the striker attached to the bottom section of the split tailgate. My fix involved forcing whatever could fit (paper,tape) in between the striker and back plate to stop the striker from moving up and down. I will need to go to the dealer to get them to tighten up the striker for a permanent fix (access is via the plastic cover on the inside of the lower tailgate). Simultaneously I wrapped electrical tape around the striker that the back seat (middle row) latch locks into. I should have done my tests one at a time but this was a long frustrating road. I am laying the blame however on the split tailgate striker as that is the only one that moves and strikers are meant to be secure. Plus when I do manage to keep it secure the noise goes away [this took me almost two years to find]
06-15-2012, 01:55 PM | #12 | |
Rep 389
06-18-2012, 02:52 PM | #14 | |
Rep 389
I have an ocasional clunk during weight sift, while RU's problem is rattle on bumps. I also tried to pull the D-latch and it doesn't move. Took off the plastic trim from the upper part of the tailgate and drove. Still heard the clunk ocasionally. It's something else.. |
09-24-2014, 01:06 PM | #15 |
Rep 389
^^ Just an update for above. The clunk was fixed by realigning lower tailgate (horizontally and vertically) and wrapping some tape around D-shaped latch on lower tailgate.
09-25-2014, 12:42 PM | #16 |
Rep 11,136
Interesting, as I have a similar noise when the vehicles flexes. For example, when I turn into my local gym, there is a steep but short hill the vehicle needs to climb at a 45 degree angle (not the steepness of the hill, but rather the angle of entry). When the vehicles flexes like that, I hear a similar metal "pop".
09-26-2014, 12:29 PM | #17 |
Rep 389
Where is the pop sound coming from? Some people reported bad welds in various pillars - you may want to make sure that's not a case.
In my case, the sound was specifically coming from tail gate. I was so annoyed that went as far as riding in the trunk like a dog, while my wife drove over bumps |
09-26-2014, 10:44 PM | #18 |
Self Proclaimed Roundel Junkie
627
Rep 1,593
I would do this as well.
2018 F15 X5d Carbon Black/Nutmeg Individual- Oil Burner Tow Rig
2013 E82 1M3 Carbon Black/Black- S65/DCT Track Toy 2013 F25 X3 35i Alpine White/Chestnut- German American Family Hauler Past: '11 E91 335is, '11 E90 M3, '10 X5M, '14 328d, '03 330i Dinan3 ZHP, '04 330i ZHP, '12 X3 35i |
