      12-08-2012, 11:54 AM   #89
doug_999
Drives: 2012 X6 50i/2011 1M
Originally Posted by Franco62 View Post
Were you noticing anything out if the ordinary with the radio ?? I have a 12 X5M and the radio doesn't keep the station in memory it's even changed the presets
Silly comment, but just in case - remember those are set to the key being used. So if you swap keys, the presets change too.
2012 Vermillion X6 50i -CWP, Vent Seats, Tech, Sport, Premium Sound, Premium, Active Steering, 3 rear seats, BMW Apps, Space Saver Spare
2011 1M, Black loaded sans sat radio
doug_999 is offline   Reply With Quote
      12-08-2012, 01:30 PM   #90
Ridiculous
isn't it?
Ridiculous's Avatar
Drives: tiag 2011 X6 5.0
Send a message via AIM to Ridiculous
Have had this happening on my 11 X6 5.0 for over a year on and off. The dealer originally said it was a faulty negative terminal. I have this issue now and plan on asking for the AGM battery.
Ridiculous is offline   United_States
      12-14-2012, 12:11 PM   #91
kennewman
Drives: 2010 X5 4.8i
My 2010 X5 4.8i is in for service right now for both the "High Battery Drain" issue as well as "Remote Battery Discharged" message.
I don't think they're related.
We'll see if the dealer replaces the battery, and if so, with an AGM battery or not....
kennewman is offline   Reply With Quote
      02-01-2013, 11:47 AM   #92
cpsquare8
Drives: 135i
Old Thread - great information for the issue. Officialy PUMA has noted on the reprogramming the car yesterday-"unfavorable driving profile." Hmm, nothing to do with the car taking 30 minutes to go into sleep mode.....
cpsquare8 is offline   Reply With Quote
      03-02-2013, 07:31 PM   #93
750 XLR
750 XLR's Avatar
Drives: BMW X5d 2009 alpine white
the battery on my X5d 2009 has been replace three time since december 2012, and it still went dead after one week at parkandfly montreal, any idea on the possible reasons for the drain ? it got cold but never bellow -5 celsuis. really getting to be a problem. can anything be done ?
750 XLR is offline   Canada
      03-02-2013, 08:41 PM   #94
dmk08
///Maniac
Drives: e90 m3
2008 BMW M3 E90  [0.00]
I went to test drive a 2011 50i today and it had this alarm going off. Needless to say I just walked.
dmk08 is offline   Reply With Quote
      03-02-2013, 11:45 PM   #95
Sylvan Lake V35
Vanilla Gorrilla
Sylvan Lake V35's Avatar
Drives: X5 35d
Looks like Canadians have the worst luck with batteries...mine actually had a few high discharge warning a few months ago the SA told me its common here because of when we start it in the cold we run too many accessories at once fans on high, steering wheel heater, seat heaters ect mine is always parked in a heated garage or under ground parking and is rarely left outside for more than a few hours. It however hasn't went dead or failed to start on me yet.
Anyway my question is, is it hard on the battery to trickle charge it? If they say the computer needs to programmed with a new battery or the vehicles charging schedule will shorten the life of the battery wouldn't charging the battery basically have the same effect?
X5 Diesel, Lowered & Tuned/Sierra Z71 "All Terrain" Lifted & Tuned/700hp 3.8L Twin Turbo G35
Sylvan Lake V35 is offline   Canada
      03-04-2013, 12:16 AM   #96
x5mad
x5mad's Avatar
Drives: BMW 135i M Vert, BMW e70 X5
Almost exactly 1 year on from my post, an update.
Since the new AGM battery there have been absolutely no problems. This is despite using the X5 much much less and not putting on the trickle charger.
So the new AGM and reprogramming of the alternator has done the job.
x5mad is offline   Reply With Quote
      03-04-2013, 03:51 PM   #97
chrisnyc
chrisnyc's Avatar
Drives: bmw x5 50i
Same here; i bought my 2011 x5, with this message;
dealer claimed it is because the car was parked on a lot for a long time; i took it back to them, since it was a CPO; the diagnostics said "battery is flat"; they have replaced it with an Exide battery at no cost.. no more message since then..
chrisnyc is offline   United_States
      03-05-2013, 01:53 AM   #98
northern2020
northern2020's Avatar
Drives: '11 X5 M / '01 B5 S4
Shat!
I received the new AGM in my ///M but no reprogram of the alternator....if I tell the dealer will they know what to do?
Fortunately truck is parked and trickle charged since new battery installed so I can't attest to the new AGM
| Vorsteiner front splitter | ADV-7 22" | ESS | Akra Catless DP's | Akra Evo Exhaust | KW V3 Coilovers | Lux V3 H8 | HR TRAK spacers 20mm |
| 2011 X5M | 2010 Escalade ESV | 2012 Audi S4 | 2001 Audi S4 |
northern2020 is offline   Canada
      03-06-2013, 11:27 PM   #99
Danny1388
Drives: 2011 X5 M
Could this be caused by a battery problem?
I recently got a 2011 x5 m..Does anyone know why my halos/tail lights would not light up when clicking the unlock button on remote? They were working for awhile they suddenly stopped. The welcome light settings are on and lighting is also set on auto...could it be battery problem? it did indicated "low battery" and "increased battery discharge" but went away......feedback please?
Danny1388 is offline   Reply With Quote
      03-12-2013, 10:47 AM   #100
750 XLR
750 XLR's Avatar
So my X5d has been at the dealer for two weeks now they have replace the battery and cheek for any drain, they still don't know where the drain is coming from, they even have BMW Canada engineering on the problem now
      03-12-2013, 11:42 PM   #101
Sylvan Lake V35
Vanilla Gorrilla
Drives: X5 35d
Can you charge the battery through the boosting points under the hood or should you go right to the battery?
      03-12-2013, 11:50 PM   #102
cybervinn
cybervinn's Avatar
Drives: 2011 X5 M
2011 BMW X5 M  [5.00]
I was told to charge through the contact under the hood if I needed to by the dealership. No need to go to the battery. I also experienced the High Battery Drain message and when I brought my vehicle in they replaced my battery under warranty. They attributed the failed battery to too short of distanced drives.
cybervinn is offline   United_States
      03-12-2013, 11:55 PM   #103
Sylvan Lake V35
Vanilla Gorrilla
Drives: X5 35d
Mine is more preventative, my wife does lots of short trips so I hooked my charger to it and it read 25% so I left it for a while and it only came up to 50% I left the charger on but I had to go out of own for work so I will have to ask my wife what % it showed in the morning.
      03-13-2013, 05:30 PM   #104
doug_999
When my car read that, certain things stopped working (Comfort Access, the fan inside the car, the lights inside the car, etc). The dealer said that is on purpose and occurs after the high battery drain message.
I have not updated my post here recently but my high battery drain message would appear - but only in times of extreme cold. The dealer ended up replacing the battery but it was still giving the message. Then ended up tracing it back to a bad cable. The work order says "Replace Battery Positive Cable" however the part says "1 12-42-7-603-567 Battery Cable, Negative IBS:611030"
And that is what they had told me - the IBS cable had a short in it.
      03-13-2013, 10:03 PM   #105
750 XLR
750 XLR's Avatar
Well maybe tomorow Will be the end to the drain saga, the dealer said today that they have maybe found the problem (again, fourth time lol ) now it's a sensor for the transmission that causes the wake ups and the drains, still don't know what the cost of the repairs will be if its finish tomorrow, but two weeks at the dealer, I am scared
      03-17-2013, 11:50 PM   #106
ToothDoc
Drives: 997.2 TTS, IS-F, X5M
Uh oh... noticed slower starting... and got the "High Battery Drain" light. We'll see what the dealership says tomorrow. Told my wife to ask for the black battery instead of the white battery. We'll see what happens.
ToothDoc is offline   Reply With Quote
Forum Jump
