FORUMS
- 5
| 05-01-2012, 12:28 PM | #376 | ||
![]() ![]() ![]() ![]() Drives: heavier cars are still boats Join Date: Jun 2007
Location: compensating a fat car with horsepower is like giving an alcoholic cocaine to sober him up.
I absolutely love the whole concept of it even the NA engine. What I'm saying is that the concept could be enhanced even further by the addition of FI to the boxer engine, and NOT because of max power BUT because of low to mid range torque. I would gladly trade max power for a significantly increase in torque across a wider rpm band (without compromising emissions standards, even enhancing them) because that's what makes for the perceived engine power output in a daily commute. I own a 1M and due to the massive torque available way down low in the RPM range, appropriately matched with tall gears, I don't need to rev the engine to maximum rpm to find myself saying everyday 'WOW... this thing really kick ass!!!' I now start to realize that Subaru must go the engine downsizing route also. To put it all into perspective, under the Toyobaru's hood a boxer engine version of the late Audi inline four 1.8 TFSI engine is all is needed :Only 170 hp... but constant form 3800 to 6200 rpm! And more importantly, 236.02 lb-ft... Yes, 236.02 lb-ft of torque from 1400 to 3700 rpm!!! (Mind you, my former Cayman with 265 hp only had 221 lb-ft of max torque @ 4.400 - 6.000 rpm from a NA 2.9-liter engine) ![]() Like the Toyota's proprietary D4-S fuel injection system in the Toyobaru's boxer engine that combines direct injection and port injection: Quote:
BTW, enriching the mixture at high load to reduce exhaust gas temperature (which can reach above 1000 degrees Celsius - not good for turbine blades) and also to reduce spool time are the two main reasons why I find my 1M not so-fuel efficient (and why I like superchargers )... the third, and a VERY important one, is aerodynamics... the car best resembles a fridge with four wheels, especially if it is AW... like mine.![]() Fortunately, the Toyobaru has the stance of a cat (instead of the bulldog like 1M). Last edited by GoingTooFast; 05-15-2012 at 04:58 PM. |
| 05-01-2012, 03:18 PM | #377 | ||
MotorTrend got 6.4secs in 0-60. http://www.motortrend.com/roadtests/...t/viewall.html Quote:
2012 Z4
| 05-01-2012, 08:38 PM | #378 |
The official time is 7.6 sec 0-100 km/h (0-62 mph).
For instance, the fwd Mini Cooper S Coupe which weighs roughly the same (1240 kg) as the Toyobaru officially does the 0-62 mph sprint in 6.9 sec. Is the Mini more powerful than the Toyobaru?! No. Does it have a larger displacement engine then?! No. So, what's the secret?! Well... the torque from the BMW/PSA (N18B16) turbocharged 1.6 L gasoline direct injection engine: Displacement.......1598 cm³ Bore x Stroke.......85.8/77 mm Output................181 hp @ 5500 rpm Max. torque/revs...177 (192*) lb-ft @ 1,600-5,000 rpm Compression.........10.5:1 *with overboost function. I could bet that some form (maybe with Toyota's D4-S fuel injection system ) of the Subaru Boxer 1.6L DIT (Direct Injection Turbo) engine will go under the Toyobaru's hood in the very near future... there's no way around it!![]() Last edited by GoingTooFast; 05-01-2012 at 08:49 PM. |
| 05-01-2012, 10:43 PM | #380 | |
Something seems to be wrong with the Edmund launches when compared to the Motortrend launch. It sounds like they launch at a lower rev or something as the tire screeched for much less. Official numbers-wise, we know that nobody really cares. And one'd have to know better than to compare Toyota/Subaru official numbers to Mini official numbers. If anything I'd compare numbers from the same magazine for the 2 cars. 6.4s on Prius ECO tires, that's exceptionally fast. If people really want straight-line speed, I bet you a good couple tenths can be shaved just by going with stickier rubbers to put more power down off the line. In regards to practical day to day usage. I used to drive a 1994 Honda Accord, which is some 100hp or something ridiculous like that. I never had any complaint in straight line speed in daily driving. Downshift and get into the power band. Why be afraid of rev? But regardless. This car is not about numbers. It's about fun, it's about driver improvement. Buy a Mustang or a Mazdaspeed 3 or whatever if power and torque is what one wants. It just isn't what it's about.
Ground Control Camber Plates w/ PSS. Ferrodo D2500 w/ Slotted Rotors on RBF600 Fluids.
| 05-02-2012, 12:09 AM | #381 |
Cpt. Buzzkill
>that feel when you can't stand seeing the same 15+ page thread being re-bumped over and over
_.[In a love/hate relationship with...] E92 335i: Space Grey|Coral Red|Aluminum Trim
![]() _________VMR V710s|M-Sport Rear Bumper & Rockers|M3 Spoiler|Golf-T__________Moved on to the misc. Later, brahs. |
| 05-02-2012, 04:33 AM | #382 | |||
![]() Sure you didn't care about the 306 hp @ 5.800 rpm or, more importantly, the 295 lb-ft @ 1.200-5.000 rpm. Some magazines even will tell you that those values are way conservative... but what would you care, right?! Oh... and the official 5.3 sec from 0-62 mph... you didn't care either. So, the only reason I can think of for you to have bought the 135i instead of the 165 lbs lighter and nimbler (@ 3208 lbs) 128i is... you like to waste money! ![]() Quote:
You should be asking Honda instead why did they drop their mighty F20C 9000 rpm capable engine, or the every other high revving engines for that matter. Quote:
![]() Last edited by GoingTooFast; 05-02-2012 at 08:03 AM. |
| 05-02-2012, 10:42 AM | #383 |
There is No Substitute
Drives: Audi A6, 997 GT3 RS, E90 335i Join Date: Apr 2010
7.3 seconds is pretty disappointing. I'm not sure that beats a Honda Accord sedan. I know it's not all about "0-60", but that time is pretty pedestrian.
'13 Audi A6
'07 Porsche GT3 RS '08 BMW E90 335i ![]() |
| 05-02-2012, 02:35 PM | #385 | |
There was really, simply no good 2+2 FR before the new 86 without paying at least the 128i price range. I thought about the Miata but it isn't cheap either, and I wasn't ready to have no back seats at all for the 2 or 3 times I need it a year. Reving does not have to mean higher speed. What I mean is, If you are in the pedestrian 4th gear at some 60km/hr or 40mph and you want torque and power, drop into 2nd. Yes you have to downshift, but that's what the upper revs and the gearbox is for. On the street, you'd have plenty enough power to do anything but racing red-light to red-light in almost any car out there (maybe not a Smart.....). Honda dropped their rev-happy engines because they don't make a sport/sporty car anymore... Referencing a disgrace such as Honda who dropped all their racing hertiage is the worst example one can come up with. My stance on the 86 engine is. Good if it give low end torque. But it's definately not necassary, and can probably be argued that it's not worth it if any other sacrifieces have to be made (weight, power response, COG, price, etc). And yes, given the same position today, I'd have bought a new 86 rather than a 1 year old 135i, especially when it's over 10k CAD cheaper. It'd be absolutely no brainer if it's a well kept 1 year old 86 vs a well kept 1 year old 135i (probably 15k in savings where I can put towards an entry luxury SUV as people carrier).
| 05-02-2012, 02:40 PM | #386 |
Where is the official time from?
2012 Z4
| 05-02-2012, 05:57 PM | #388 | ||
Here: The new Subaru BRZ (first page - last paragraph)
Google translator: Quote:
| 05-02-2012, 06:19 PM | #389 | ||
Do the math yourself... ![]() What I mean is: dropping into 2nd in your 135i obviously doesn't have the same effect than dropping into 2nd in the Toyobaru after you open the throttle @ 40 mph!!! With the 135i you can steer on the throttle from MUCH lower speeds - the throttle has complete authority over the chassis at low and safer speeds! For you to have the same kind of control from the Toyobaru's throttle you have to rev the engine at least to 6.5k - 7k rpm which means that in 2nd gear you hit higher speeds when compared to the 135i into 2nd gear @ 1200 rpm (where the max. engine torque just starts). Quote:
![]() Last edited by GoingTooFast; 05-02-2012 at 07:05 PM. |
| 05-02-2012, 07:00 PM | #390 |
I think this picture is worth a thousand words... this is why this car is just beautiful:
| 05-02-2012, 07:31 PM | #391 | |
2012 Z4
| 05-02-2012, 08:30 PM | #393 | |
| 05-02-2012, 10:29 PM | #394 | |
I'm not talking strictly about straight acceleration... I'm talking about steering on throttle control at low speeds. With the Toyobaru the rev limiter in 2nd gear kicks in at 59.2 mph... so, from 40 mph onward a very narrow usable window is left before you need to shift-up into 3rd increasing speed and losing both the low gear torque advantage and, what matters the most, the throttle authority over the chassis. Let me do the math for you using the above formula: 7450 rpm (BRZ's rev limiter) * k (const.) = 59.2 mph x rpm (rpm @ 40.0 mph) * k (const.) = 40.0 mph x = (40.0 mph * 7450 rpm) / 59.2 mph = 5033 rpm This means that at 40 mph in 2nd gear you don't even benefit of the Toyobaru's engine full potential because you haven't reached engine's max. torque yet which only appears at 6400 rpm. @ 6400 rpm the speed has already increased to (40.0 mph * 6400 rpm) / 5033 rpm = 50.9 mph So, you get the best useful window ONLY over 1050 rpm (7450 - 6400) with a max. speed variation of 8.3 mph before you need to shift up. Whereas in the 135i your best useful window extends from 1200 all way up to above 5000 rpm in each gear. Do you understand the difference now?! ![]() Last edited by GoingTooFast; 05-02-2012 at 10:42 PM. |
| 05-02-2012, 10:39 PM | #395 | |
If one is to say that the lack of torque across the power band makes this a boring car to drive in DD situations, then just buy an American muscle car. If someone wants the power and finesse, you can try Porsches at almost 3 times the price. But even then they don't have as low a COG as the Toyobaru... I view this car as a FR version of the Civic Si (as they are similar HP and similar price). But with low COG, FR and LSD for free~ Who can complain about that?
![]() Last edited by BiscottiGelato; 05-02-2012 at 10:47 PM. |
| Bookmarks |
