      06-16-2012, 02:49 AM   #23
uwinlol
Drives: X6M
ok my bmw x6m today need to go service to see what is the problem is engine fault reduced power
      06-16-2012, 02:51 AM   #24
Biff Grissel
stankmouth
Biff Grissel's Avatar
Drives: fun
I had same thing and usually it's due to some faulty hoses that heat up and trigger that sensor due to vacuum leak in the system. BMW has an upgraded hose kit that ur dealer can install if this happens to u. Have them do a smoke test when u take it in.
      07-12-2012, 06:17 AM   #25
Dave Xdrive50i
Kuwait
Drives: BMW X6 5.0 TT
Originally Posted by edooo View Post
hey guys.
i have X6M,but i have warning in yellow,sth like this- Engine fault,reduced power,full engine power not longer availible,drive moderately,you can continue journey ,have the problem checked by the nearest BMW Service.
did you experience something like this ?
what do you think i should do?when i turn off the car and then start it it doesnt appear,but only sometimes when i acclerate hard
i have the same problem and don't have a clue what to do
HELP
      03-28-2013, 09:08 AM   #26
CrMcC
Drives: BMW X6
X6 engine fault warning light
Had my X6 35i in for 5th time for "engine Fault" ...State dealer started with replacement of Vacuum hose, then box of hoses, then refit hose which fell off (so they say) then pressure regulator, then $600 part not sure what, finally they checked fuel pressure and replaced fuel pump.
By the 4th visit I am getting annoyed ,,,spent $1100 on parts not necessary so BMW did the pump free which they costed at $1000. So $2000, about 4 weeks in and out of BMW 5 times, 2 weeks off road and its the pump. Not impressed with mechanics in Perth or their weegie board. Just put my money down on an Audi A6 Allroad, simply because BMW cant diagnose a problem with their vehicles...and they are the experts in WA
PS..Engine fault light came on under moderate acceleration/load..........seems to be fixed now with new pump but not willing to take any more chances with other problems which are likely to arise on 77,000 km vehicle which I have owned since new and maintained 100%...History is 2 break downs/ tows, HP fuel pump 10,000km ..brake auto hold failure and brakes seized at 65,000km and now LP fuel pump at 77,000km.
PS injectors done under BMW recall about 60,000km
      04-10-2013, 03:52 AM   #27
CrMcC
Drives: BMW X6
X6 engine fault
light came on 2 days after fuel pump replaced. Not prepared to send to BMW workshop for 6th time so asked for return of $1100 which was granted
Sold car and got an A6.........is Audi A6 Allroad any better ???? I hope so
      04-10-2013, 04:07 PM   #28
Leofrackles
Drives: X6
I have had that problem all they did was change my spark plug an my truck drives like new now
      04-19-2013, 09:16 AM   #29
CrMcC
Drives: BMW X6
Perhaps the BMW guys in Miami are smarter then the boys in Perth....would have been a cheap fix if they had changed the plugs and got it right first time
      06-02-2015, 10:45 AM   #30
Mre123
Drives: 09 135i
Had to have new turbos. Aux turbo pump also fails
      06-08-2015, 05:43 PM   #31
Erick79
Drives: 2012 X6
Same issue: issue identified as the fuel pump
