Login
04-27-2011, 10:04 PM | #1 |
2016 X5 30d
![]() 217
Rep 1,702
Drives: 2016 MW/F15 30d
Cheapest way to get a better sound on X6M
I know this thread belongs more to the exhaust forum, but since this is the most visited between all sub-forums, just wanted to share the experience with you
Yesterday I did a small mod to the 2 vacuum valves on each one of the inner exhausts of the X6M, now all 4 exhaust tips remains open at all times ( when stock the 2 inner valves don't open until the car reaches some speed about 3000 RPM's) The result is a real low frequency "V8 sound" when you start the car and drive at very low RPM's, is more like a "subwoofer sound" nothing loud. Here some links to YouTube videos I made before and after the modification, also a couple of pics for better understanding. I'm VERY satisfied with the new sound results. Now my car sounds like it has BIG-balls......sound from video does not make justice, was taken with my iPhone. Before and after videos here: Before: After: ![]() ![]() Last edited by motex; 05-02-2011 at 03:59 PM. Reason: moved from other forum |
04-29-2011, 06:21 PM | #3 |
![]() 1
Rep 39
You could do the zip-tie mod. Look underneath the exhaust and there should be a "valve" connected to a tube. Undo all the screws then zip tie the end of the valve toward any nearest "hook" or any openings. Go with a high-temp zip tie if you're concerned.
I did a zip-tie / golf-tee mod on the 35i and it sounds wonderful.
2011 X5 xDrive35i Sport Activity
2007 X5 3.0si |
04-29-2011, 07:20 PM | #4 | |
![]() 8
Rep 190
04-30-2011, 12:16 AM | #5 |
![]() ![]() 9
Rep 163
Google
05-02-2011, 01:44 PM | #7 |
2016 X5 30d
![]() 217
Rep 1,702
I will say YES because my X6M is almost identical to a 335i, so I asume that your 5.0 must be the same.
You can do a sound test to check the difference, just get a set of pliers and turn the lower mechanism 1/4 in order to open the valve, inmediately you will notice the difference, if you get a person to help you, you will be able to open both and see how great it sounds in low RPM's Good luck ! |
05-02-2011, 03:18 PM | #9 |
2016 X5 30d
![]() 217
Rep 1,702
05-03-2011, 01:52 AM | #11 |
Rep 27
even though you're getting a bit better sound by disfunction the vacuum value, you're losing low end torque for sure, the acceleration is obviously much slower from my past experience
and also the vacuum value is powered/activated by a tube connecting to the vacuum head, won't it be easier just unplug that and zip tie the tube? |
05-03-2011, 10:43 AM | #12 |
![]() ![]() ![]() ![]() ![]() 70
Rep 608
sawzall makes everything better....quick and easy
05-03-2011, 12:40 PM | #13 |
2016 X5 30d
![]() 217
Rep 1,702
You were right, after more than a week of use, I felt that lower end torque was low, so today I reversed the job. One more thing that found is that if Eisseman is doing the X6M exhaust including the vacuum valve, it most be for some reason......at least I enjoyed the low subwoofer sound for a couple of days.......
05-17-2011, 04:42 AM | #14 | |
Rep 27
05-17-2011, 05:29 PM | #15 |
2016 X5 30d
![]() 217
Rep 1,702
03-31-2013, 07:54 PM | #17 |
Rep 3
any updates on this mod? I doubt you lose torque because the flap opens when you press the M button, so it's designed to open for louder exhaust when the M button is pressed.
2010 X6M Space Gray
2007 335I Black |
04-03-2013, 06:38 PM | #18 |
![]() 3
Rep 53
The 50i sounds pretty sweet stock... deeper growl then the M. I swapped out the pipes on my big V-Twin for a much better sound and have also done the muffler/header swap on a couple of cars but I have to say the stock sound on the 50i is pretty cool.. The only reason I would swap is performance gain..
04-18-2013, 02:11 PM | #19 |
![]() 3
Rep 174
Thank God someone else understands this! A turbo needs as little back pressure as possible to run at its optimum, which is why the "M" setting opens this valve up.
05-04-2013, 04:26 AM | #21 | |
![]() 3
Rep 74
05-08-2013, 10:32 AM | #22 |
![]() 18
Rep 242
it sounds like a machine gun. So loud and nice. but i couldnt take it for long..had it taken off after a couple of weeks. there is definitely droning, and that "expensive quiet ride" quality was taken from the car. If I were to change it again id go for the sport so i can use the M button to open the flaps..uknow more choice. but damn she sounds good with the race.
