      03-09-2011, 05:31 PM   #1
bleudyno
bleudyno's Avatar
75
Drives: 2010 Melbourne Red X6///M
2010 X6M  [9.50]
2010 X6M  [0.00]
K&N filter for X6M installed. DIY with pictures
Ordered this two days ago and got it today. Install took me about 5 minutes. Total took me a little longer since I took pictures for the DIY. Thought this might help anyone that might need it. Haven't taken the car for a spin yet but I doubt that I will be able to really feel a big difference. Will update later.
Here's the DIY
OEM airfilters in orange, K&N on top
First, Remove the 4 silver screws along the top pane
l
Next, on both sides of the air box there is a ball mount. Simply pull up on this area with a prying tool (a flatheard screwdriver would also suffice) The upper piece should pop up
Lift directly upward
This what is underneath
Now there is another piece that needs to be popped up.
The top panel comes off but you don't need to take it off. It will pop off without taking the piece off
Same thing underneath
Now you can take the front piece off the car
Make sure you un hook the clips underneath. There are 4 that run along the bottom of the piece, unhook them and you can pull the piece free
OEM Air Filters
K&N
Now just do everything in reverse and put everything back together. FIrst make sure that you hook all 4 hooks along the bottom:
Then firmly press down on all three points that you popped out earlier. With pressure, they will pop back in. The screw in the 4 silver screws and all done! Viola!
X6///M Melbourne Red/Merino Black leather MODS: Matte black grill, Tinted head lights, Euro clear side reflectors w/ tint, Tinted white stip on tail lights, 22" Iforged Legacy Convave (Matte black center with Gloss black lip) RPI Race exhaust, Vorsteiner CF front lip, CF rear deck lid spoiler, CF rear diffuser, vented CF race hood, RPI intake scoops UPCOMING MODS: RPI software tune
      03-09-2011, 09:37 PM   #2
roentgen72
Drives: 2011 X6M
thanks. I will try this soon. WHere did you get the filters?
      03-09-2011, 10:47 PM   #3
BabyBlack
BabyBlack's Avatar
27
Drives: E46 M3 & E90 335i & E71 X6M
nice writeup with detail pics diy. Do you actually feel any difference?
      03-10-2011, 01:50 AM   #4
Iluxa
Drives: X3 M40D; X7 M50D
thx 4 the write up ))
      03-10-2011, 11:44 AM   #5
scottjays
Starfleet Command
scottjays's Avatar
315
Drives: 2020 X5 M50i
anyone with a 50i want to post pics as nice as OP? I looked at my 50i doesn't look the same obviously. The M looks easy compared to what I am looking at with the 50i
      03-10-2011, 11:46 AM   #6
itsme123
Drives: 2013 MCB F10 M5
Nice write up! Anyone here suprised that the filter is so tiny?
      03-10-2011, 02:45 PM   #7
scottjays
Starfleet Command
scottjays's Avatar
315
I am looking at realoem.com
http://www.realoem.com/bmw/partgrp.d...05&hg=13&fg=20
I don't see the non M 4.4L (the 50i N63 engine) as having the air filter elements KN is now selling. anyone else know where the air filter elements are in the 50i?
      03-10-2011, 04:46 PM   #8
bleudyno
bleudyno's Avatar
75
2010 X6M  [9.50]
2010 X6M  [0.00]
http://www.realoem.com/bmw/showparts...72&hg=13&fg=20
#2 on the diagram
      03-10-2011, 10:02 PM   #9
scottjays
Starfleet Command
scottjays's Avatar
315
Originally Posted by bleudyno View Post
I see #2 but maybe I don't understand what I am looking at. doesn't look anything like the M DIY. I thought the filter element is the same. doesn't look from my untrained eye it fits anywhere. how is #2 on diagram the same as
http://www.realoem.com/bmw/showparts...40&hg=13&fg=20
Maybe the 2011 engine is somehow different from the 2010 50i? nah!?!?
      03-11-2011, 04:51 PM   #10
scottjays
Starfleet Command
scottjays's Avatar
315
bump??
      03-12-2011, 09:53 AM   #11
STIto335
Drives: a car
Does the X5M/X6M have additional charcoal filters?
      03-14-2011, 10:31 AM   #12
itsme123
Besides the ones directly behind the airfilters? No.
      03-14-2011, 12:56 PM   #13
newdadkel
newdadkel's Avatar
Drives: 2011 X6M CBM
bluedyno, any difference that you have noticed while driving?
      03-14-2011, 01:00 PM   #14
bleudyno
bleudyno's Avatar
75
2010 X6M  [9.50]
2010 X6M  [0.00]
To be honest, I don't feel much of a difference - but then again, I haven't really pushed the car at all since I put it in. Its traffic everyday of the week to and from work. Maybe this weekend I can go for a nice drive and I'll give you an update later.
      03-14-2011, 08:01 PM   #15
newdadkel
newdadkel's Avatar
Cool
      03-16-2011, 04:27 AM   #16
vet927
vet927's Avatar
Drives: 10 Carbon Black Metallic X6M
good stuff, let us know the difference after a good run on it, thanks!
      03-16-2011, 12:46 PM   #17
itsme123
To feel the minor difference that the filter makes, you need to know where to look for it. The car needs to be driven in manual mode instead of letting the automtic transmission shift. Besides the obvious gain in WOT, the gain will show up in the snappiness in transition between throttle positions. Example: going from 10% throttle in cruising to 70% throttle, the car will feel snappier in response vs the old restrictive filter. You'll also need to do this when holding a gear at an RPM, say 4000k. The automatic transmission shifts too early during normal driving conditions to let the driver feel much of a difference after the minor gain in HP. The gain in HP in WOT is not too much either because of the % gain in HP is so small in relation to how much the car have already. a 3 HP gain on a 150 hp car is a lot in ration vs a 3 HP gain in a 555 HP beast . But extra HP is extra HP. I'll take it any way I can
      03-17-2011, 08:22 PM   #18
JIMX681
JIMX681's Avatar
120
Drives: 2022 X5M Comp
It is a pain in the balls to get to the filters in the 50i. Alot needs to be taken apart to open up the airboxes. I attempted to change them today but it got dark and I had to put it back together. The entire cover from the top of the engine to the bottom of the windshield needs to be taken off. Really gay compared to how simple it is for the M.
      03-19-2011, 07:41 PM   #19
LANDLORD
Turbo Engines are Fun
LANDLORD's Avatar
Drives: 2010 X6M Monte Carlo Blue
What is the size of the torx screws on the ///M housing?
      12-03-2011, 10:29 PM   #20
BMW1986
BMW1986's Avatar
Drives: 11 M3 E92 ZCP JB/PS & BLK
So these fit for the 5.0i or they don't? LOL
11 E92 M3 DCT Jerez Black ZCP...Eisenmann, Dinan, Fabspeed, IND, LUX
      12-04-2011, 08:15 AM   #21
m 135
m 135's Avatar
Australia
25
Drives: Gtr,135i,M235i,XR6 turbo
Do not think so,i like to change these myself more often even just the oem parts,but in the 50i it looks like a big job compared to the 135 i had and even the x6m,not sure why they made it so different for an engine that is very much the same in design ?
      03-13-2012, 01:32 PM   #22
Richard7
Drives: 2012 BMW X5m
Thumbs up Thanks
Thanks for the air filter replacement instructions.
You are the Man Bleudyno!
