      11-23-2010, 07:05 AM   #1
Mean_M3
Drives: 2009 E92 coupe
Question Squeky noice from the rear seats
everytime I go over uneven road or a bump...I hear a rattling noise from the left passenger seat in the back....it disappears when someone is sitting in the back, anyone had the same experience? thanks in advance...its really annoying and I dont want to go back to the dealer if I dont have to....
      11-23-2010, 11:43 PM   #2
GeraG
Drives: X5, X6
I had similar problem and found out that the noise came from rear sets folding locks. Just put some tape on the 'clutch' and the noise should be gone
      11-24-2010, 09:17 AM   #3
BigBobDeuce
Drives: 2012 BMW X6M
2012 BMW X6M  [0.00]
I had the same problem, and found that it was two fold: the center console needed to be tightened in place, and the right passenger door panel had worked its way a little loose.
Now I have a horrible rattle coming from the front passenger seat. I think it has something to do with the plastic trim around the edges...
      11-26-2010, 11:37 AM   #4
Mean_M3
Its actually the right passesnger seat....which one is the clutch? is it that brown/ black thing sticking out from the top by the headrest that disappears once the set is properly pushed back? I do fold my seats a lot so is that causing it? thanks
      11-26-2010, 11:38 AM   #5
Mean_M3
How did you fix the loose door panel? did the dealer fix it?
      11-26-2010, 09:50 PM   #6
BigBobDeuce
2012 BMW X6M  [0.00]
To fix the door panel, I remove the bottom screw(s) and popped the clamps loose up to about the metal accent strip. Then I just reseated all the clamps and replaced the screws. I am, quite frankly, stunned that it worked.
      11-26-2010, 10:04 PM   #7
Mean_M3
Interesting, I think I will try the dealer 1st...? did you ?
